REMOVE CAT or High flow CAT?
Old Aug 26, 2009 | 12:00 PM
clanbuster's Avatar
if i want to concentrate on 0-30 mph Low end power,
should i totally remove the CAT for better accuration or
change to High flow CAT?
Some ppl said this or that is better.
L15A with turbo 0.5bar only
Auto gear.
Old Aug 28, 2009 | 08:12 AM
FITGD3's Avatar
Dont remove your CAT as you will lose low end power.
You need back pressure so better go for high flow cat and twin loop exhaust.
my 2c
Old Aug 29, 2009 | 03:28 AM
DOHCtor's Avatar
Backpressure will kill HP/Torque!! What you need is the BIGGEST pipe that will let the exhaust FLOW enough at HIGH RPM's without being a RESTRICTION, yet, being SMALL enough so that it still have GOOD exhaust gases VELOCITY!! 60mm will be too much for a 1.5l Fit that revs at 7K RPM!
-Too BIG = Flow at High RPM's but low Exhaust gases Velocity at low RPM's = Less scavenging effect = Loss of Low End Torque!
-Too Small = High exhaust velocity at Low RPM's = Good Low End Torque but Little flow at Upper Revs = Loss of Top End power!!
Personately, 50mm pipe with 1 or 2 good quality perforated core Resonators (Maybe 3 if you delete the Cat!), a good straight thru Muffler and a Header with a Merged collector! Forget about the Louvered cores resonators and mufflers that adds turbulence and restriction to the exhaust stream...
Marko!
Old Aug 31, 2009 | 02:03 AM
clanbuster's Avatar
Thank you.
I think i have to put back my CAT. I felt no power during 800 RPM to 2500 RPM. at high speed, I feel nothing change.
Normally i don't race and mostly travel to work only.
So , conclusion, remove CAT is not the way for city drive.
it will slow u down ALOT ALOT ALOT.......
Old Aug 31, 2009 | 12:45 PM
DOHCtor's Avatar
Anyway a modern cat is only a restriction to a small degree!! Depending on the size and length, it should only add about 1 to 3Psi of back pressure!!
Marko!!
Old Aug 31, 2009 | 12:55 PM
dewthedew's Avatar
hi-flow megan downpipe all the way! I love mine.
Old Sep 16, 2009 | 01:20 PM
clanbuster's Avatar
Problem again.
After installed back stock CAT, i improve back my Low torque and lost alot of my torque and higher RPM.
1) should I change to high flow Cat? what will happen? lost abit torque at low RPM and gain abit at high? ( half half gain)
2) install Control value before CAT, when higher RPM, the control v/v will auto open
3) install Control value after CAT, so that still have abit of back pressure.
Old Sep 16, 2009 | 02:51 PM
dewthedew's Avatar
do it install dumb valve after cat
Old Sep 21, 2009 | 03:45 AM
jazzista's Avatar
Ehm, pardon, what is a dumb valve?
cnordt24
14
Sep 22, 2014 07:10 PM
Maty J
Aug 31, 2013 02:06 AM
clanbuster
Oct 21, 2009 01:01 PM
07fit12
Jan 4, 2009 12:13 PM
dudley
Jan 29, 2008 10:38 AM
