What you think about this custom HKS intake?
Old Sep 6, 2009 | 12:20 AM
supafly50's Avatar
Hi, I've just had this custom made intake for my 2007 jazz/fit and it uses a HKS filter. It's the first time I've made any engine mods, I just wanted to know what you guys thought from the look of it.
Also, this might sound like a stupid question, but after driving for around an hour, i opened the hood just to have a look see and the tube was really hot - this is normal right? of course, cos it's in the engine bay so it's bound to be hot? i was just wondering because i've read quite a lot about trying to get cooler air into the engine, but there's not much you can do about the actual intake getting warm by being near the engine right?
Below are some pics of the new intake (don't mind the dirtiness/dustiness/messiness!! ):
Old Sep 6, 2009 | 12:49 AM
rvall004's Avatar
damm thats one dirty engine bay...intake looks aight
Old Sep 6, 2009 | 01:27 AM
im the fit's Avatar
Well its the right size piping, just make it look pretty!
Old Sep 6, 2009 | 02:49 AM
supafly50's Avatar
lol, i know.. it's pretty embarrassing how dirty it is . another stupid question - how would you go about cleaning the engine bay??
Old Sep 6, 2009 | 04:28 AM
Cat's Avatar
Cat
Ok here is my 2007 Honda Fit Sport engine bay:
I show my Honda in the import class at local car shows so the bay has to be spotless. I use a damp microfiber with just a dot of soap not much at all to wipe it down and then a damp cloth to clean it up and then a dry cloth to get it shiney. I do an engine detail anytime the car is washed. You can get grit and small rocks between the lip of the hood and it can leave scratches if you don't clean them up. Also use a dry q-tip for small areas. I take a sweeper to the hood liner and make sure to wipe down the underside of the hood and hinges each time. Hope this helps but your intake looks pretty good.
Cat :x
Old Sep 6, 2009 | 04:33 AM
Super Mario's Avatar
Clean up your wires too if you can too, lol. They're all over the place!
Feel a difference in performance?
Old Sep 6, 2009 | 10:05 AM
Fitting's Avatar
That shiney intake stand out so much in your dirty engine bay.
The pipe is aluminum so it will heat up from being in the engine bay.
Old Sep 6, 2009 | 01:38 PM
supafly50's Avatar
cat - wow, thanks a lot for the detailed answer!! ur engine bay looks sweet! you gave me some inspiration to get it clean, lol. cheers!
super mario - i know, the wiring is a mess, will get that sorted when i clean up regarding performance.. i feel the car is a little more responsive, it doesn't take as much "foot on the pedal" to get going, and in the higher rpm range it feels there's a little more acceleration... though these things are all very subtle. sounds nice tho! i also got a spoon n1 cat back exhaust plus a new header, but i've read those things probably won't add any kind of performance (right?)
Old Sep 8, 2009 | 11:57 PM
Jazz it up!'s Avatar
aluminum pipes make it hot. i made a DIY cold air intake with the hks filter. it's posted somewhere.
Old Sep 24, 2009 | 10:12 AM
docjim2's Avatar
It's real cute
I like the look... but as you will find out: the engine bay is much too small and you will find the engine heat will make a difference. After all the radiator is right infront of the intake.
I had a SSI and the intake engine temp was off the charts. Put the OEM back in with a K&N filter. Changed battery at the same time and let the engine idle for over 5 min. Just the OEM intake made a 30 degree diff in the intake temp.
Just think of all the money I wasted for the aftermaket intake!
What about your engine stutter??
Old Sep 24, 2009 | 10:56 PM
supafly50's Avatar
so after you put the OEM intake back on with the K&N filter, did you notice any difference in performance?
i'm not too sure what you mean by engine stutter? sorry
Old Jan 28, 2010 | 10:57 AM
ku8o's Avatar
wat about mine ??
Old Jan 28, 2010 | 11:42 AM
Black3sr's Avatar
Or don't open the hood!!! I do not go to the detail CAT does but every so often I will use Armour All wipe to clean up some at least.
Old Feb 10, 2010 | 01:56 PM
docjim2's Avatar
looks kinda expensive... and gets how hot??
Back to OEM and K&N OEM replacement filter for me!
Old Feb 14, 2010 | 03:43 PM
danger69's Avatar
Try to get a ram air hoooked up to draw cooler air from the fender well. Thats how the stock ones is setup.
mikow
18
Oct 30, 2023 02:29 PM
hydesg
Apr 20, 2017 07:28 AM
alabastersilverjazz
15
May 23, 2008 09:49 PM
mkht78
Dec 29, 2006 09:23 AM
dale.spencer@cox.net
Oct 12, 2005 12:30 AM
