DIY: GE LED Third Brake Light Install
Old Sep 15, 2009 | 08:12 PM
AtticusFit's Avatar
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
Ok here you go:
First pop the hatch and locate the third brake light and remove the back cover
Grab a 10mm socket and remove the two 10's on both side of light.
Pop light out by squeezing the two tabs, unplug the white connector and fish the wires out of the light housing
Use a small flat head and remove the red reflector(two tabs on each side)
Unplug the tiny 5 pin white connector, then unclip the tabs on each side of light that cover the led board electronics
Remove the white connector from the FIT led brake light and fish the two wires through the small opening on the light, then reconnect the wires to the connector to the second and four pin
Now connect the led connector to the connector you unplug earlier, tuck the plugged in connector under cover and snap back.
Reconnect main plug and reverse beginning steps, and your done
I hope this DIY is helpful and if you have any questions please dont hesitate to ask.
Old Jan 9, 2010 | 02:27 AM
john21031's Avatar
This is quite awesome write up. Surprised noone said anything since September? Comon people, the guy did all this work and it looks sharp.
Old Jan 9, 2010 | 12:33 PM
AtticusFit's Avatar
thanks for reading......
Old Apr 2, 2010 | 11:16 PM
Irish4199's Avatar
That looks amazing!! Did you say where you got that part?
Old Apr 3, 2010 | 10:36 AM
AtticusFit's Avatar
i have some if you want one.
Old Oct 12, 2010 | 05:30 PM
Funktion's Avatar
wow thats pretty sick
Old Dec 15, 2010 | 01:56 PM
GetAfit's Avatar
Worked liked a charm! Thanks bud
Old Jan 1, 2011 | 12:10 PM
Eamper's Avatar
I would love led third brake like that. But something that doesnt say fit
Old Jan 2, 2011 | 12:36 AM
AtticusFit's Avatar
i have JAZZ.......
Old Jan 2, 2011 | 12:39 AM
Eamper's Avatar
I want somethin thats not words, something like rolls of LEDs
Old Jan 2, 2011 | 01:21 PM
naMtiF's Avatar
Doesn't this forum have moderators that can delete this spam crap that has all of a sudden been coming into the threads?
WTF
Clay
Old Jul 4, 2012 | 03:46 AM
Bluflu's Avatar
NICEEE that looks really well put!!!!
would having your third brake light say "FIT" or any other words attract cops?
Old Jul 6, 2012 | 06:02 PM
running's Avatar
I'd be interested in that, do you still have any? and how much? you can pm me for that if you want.
Thanks
I'm still not sure which gen I have, will that work or "fit" on either?
Old Jul 28, 2012 | 10:44 AM
Black3sr's Avatar
I finally installed one.
THe DIY was a big help.
A couple small points. On the exisiting light what you are doing is removing the lens only. The LEDs remain but are disconnected.
The new light comes with a small plug with the two wires attached. You need to disconnect them from the plug in order to snake them through the housing. The slot in housing id rather tiny. I was able to bend down the bit of aluminum that is in the space enuf not to break it but allow the wires to go through.
Old Jul 28, 2012 | 11:23 AM
sean5995's Avatar
Does the JAZZ brakelight work the same way.
Old Jul 28, 2012 | 11:50 AM
Black3sr's Avatar
I don't see why not
Old Jul 28, 2012 | 11:58 AM
running's Avatar
Very nice, Legal?
Old Jul 28, 2012 | 06:34 PM
Black3sr's Avatar
Originally Posted by running
Very nice, Legal?
Why not? It is red. Where is Elgin?
Old Jul 28, 2012 | 08:00 PM
running's Avatar
IL if our goveners our any example
Old Aug 4, 2012 | 10:01 PM
wontfit's Avatar
Now, where did you get it, and how much?
