View Single Post
  #156 (permalink)
Old 09-26-2009, 03:12 PM
zm1341 zm1341 is offline
zm1341 is an unknown quantity at this point
plugs to Connector B
Thanks for doing all the leg work on this. It's something I've wanted to do for a long time. I just did it last weekend, and thanks to your help, it went smooth and turned out perfect.
As for soldering to Connector B I found an alternative. I have some background in RC planes. I purchased 3 wire servo plugs from tower hobbies. They slid on the pins smooth and snug. If you buy two of them one goes over three pins on the top ( two shorted together and on to a capped unused wire) and the other three pins on the bottom ( all used separately). It made the job easy for someone who was never a good solderer.
Airtronics Servo Plug w/Cable 3W Z
Tower Hobbies part number LX0947
Qnty = 2
Thanx again for the post.
