Underbrace install
Old Oct 23, 2009 | 02:18 PM
DatFIT's Avatar
Underbrace install
I'm trying to install the under brace i got from tanabe... like this one...
Tanabe USA Inc. - Sustec Under Brace
Before I go ahead, I went on to search some DIY. But failed. I know I have to take off the plastic piece under there. I also read the A-arm part. Are the bolts on the A-arm torqued to certain lbs? And when putting them back on do I have to re-torque them in, including the under brace...
thanks
Old Oct 23, 2009 | 03:51 PM
Evotech8's Avatar
Pretty straight foward install.
Remove only the two front A arm bolts, line up the underbrace with the hole, and torque to 51 ft.lb. I recommend you use a washer on the bolts before torquing down as the tanabe underbrace is made of soft aluminum. And make sure you have the wheels on the ground before tightening to pre-load the suspension.
Old Oct 27, 2009 | 12:22 PM
DatFIT's Avatar
Okay great... but one question. how exactly can you have the wheels on the ground and be under the car at the same time. Don't know, but I'm not a skinny person lol... and there's no way I'll fit under there lol
Old Oct 27, 2009 | 03:47 PM
Evotech8's Avatar
Use ramps or blocks under the front tires.
Old Oct 27, 2009 | 03:48 PM
shazaam's Avatar
use a drive-on lift to get under it n still have pre-load. or raise the car up n have the wheels on something...dunno what'd be safe tbh, maybe 4 ramps or blocks with jackstands underneath the frame just in case?
Old Oct 27, 2009 | 11:59 PM
Type 100's Avatar
There are certain lifters that lift the car by the wheels on metal planks, so spring pre-load is maintained. The wheel alignment place I go to has them.
Agreed on the drive-on ramps as well.
Old Oct 29, 2009 | 11:56 AM
DatFIT's Avatar
Kool thanks guys... I been lagging lately and I haven't installed it (work) But I will go to some shops over the weekend and pick me up some ramps.
Old Oct 29, 2009 | 04:56 PM
yah, watever you use dont use cinderblocks under your tires. they will eventually collapse! hahaha.
Old Oct 30, 2009 | 02:20 PM
DatFIT's Avatar
LMAO collapse or fall... whichever comes first
808duece
Hawaii Community
Feb 7, 2009 10:57 PM
garseeahh
Aug 11, 2008 08:38 PM
GD3_Wagoon
16
Jun 11, 2008 10:34 PM
joshua27
23
Dec 20, 2007 08:10 PM
fit4kris
Tanabe Racing Development USA
17
Oct 16, 2007 12:19 AM
