Rear Garnish question
Old Oct 24, 2009 | 11:39 AM
inxsole's Avatar
does anybody know how to remove the rear garnish that holds the H emblem on the trunk on a GD because I'm planning remove the emblem. I've seen the mod section of the forum and couldn't find a related thread to this.
Old Oct 24, 2009 | 11:59 AM
DreaMv's Avatar
if you want remove the emblem, look here.
https://www.fitfreak.net/forums/fit-...lots-pics.html
its a few pics down
Originally Posted by NIGHTHAWKSI
to do the rear badge, look between the hatch and opening handle you can see 2 white pins sticking down (not in my pic) but they are in that area. break them off using a flat headed screw driver and tapping on it with a hammer. it will not take much force to break them. once both are broken, the badge will pretty much fall off
anddd you can buy the mugen replica rear garnish i guess
Old Oct 24, 2009 | 12:31 PM
inxsole's Avatar
I've read that DIY thread before, but i'm actually asking how to completely remove that whole garnish piece.
Old Oct 24, 2009 | 12:40 PM
JDMchris.com's Avatar
I run THIS
you pop off the liner on the inside and theres some bolts and clips then it just pops off.
Old Oct 24, 2009 | 01:50 PM
inxsole's Avatar
can you show me what you're talking about with pictures?
Old Oct 24, 2009 | 02:26 PM
I run THIS
Remove #20 clips then pull off #1 panel and that will give you access to the garnish bolts/clips
I think theres 2 bolts and 4 clips, then it comes right out.
Old Oct 24, 2009 | 02:57 PM
score04w's Avatar
like jdmchris said, about 2 bolts and a bunch of clips, a little muscle and it will pop right off. to get the interior trim piece off, there are two push pins on the under side and then take the handle part off at pry the piece off with some muscle.
Old Oct 24, 2009 | 06:49 PM
inxsole's Avatar
I got those two pins on the underside of the interior (one actually broke for some reason).
But the problem now is the handle I dont want to break that so I'll need more help on this one.
Old Oct 25, 2009 | 10:33 PM
score04w's Avatar
take two screwdrivers and youll notice two tabs on the handle, pry those towards you. you wont break them, the handle will just fall out then
Derbers
Aug 17, 2013 03:26 PM
uRabbit
13
Aug 17, 2010 09:32 AM
AnlDyxp_GD3
Mar 24, 2010 12:59 AM
07fitsport
Jan 12, 2008 11:55 AM
SiLvErFiT2007
Apr 15, 2007 01:18 PM
