View Single Post
  #42 (permalink)
Old 10-24-2009, 02:16 PM
SS RICH SS RICH is offline
SS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to liveSS RICH relies on Rep Points to live
I spent most of the week using the Greddy TI c with the silencer in.
With the silencer in proved to have a more negative effect on the performance of the car.
SOUND was not much more than stock, so it becomes a matter of looks at that point for me at least.
What was annoying with the silencer in is if you accelerate quickly you have a sound of air being forced through the small opening of the silencer or it may be air seeping from the seams on the outer circle of the silencer as it is not a sealed fitment.
The effect on the delivery of power seemed to be as follows
Was able to recover some of the bottom end which I liked.
The meat of the power seemed to be at approx 2,500 to 3,800 then the car would fall flat and then began to pull again around 4,500 to 5,500 and then fall flat again.
As I noted in my earlier posts my goal when adding the exhaust was to compliment the more linear powerband in the stock form.
Silencer out I feel is the inverse of stock, good midrang to top end vs good bottom to minimal top.
Silencer IN just makes it very spotty with power and flat spots throughout.
One thing I did notice was when removing the silencer there was a lot of the fiber packing sitting at the mouth of the exhaust.
My thought is that the silencer creates a lot of turbulance inside the exhaust canister (silencer in) which would most likely explain the inconsitant power band.
I am going to install the stock unit agian this weekend and give my final comparisson.
AS I noted in my previous post that the car sounds great with the silencer out but the audible searching for the lock up converter or 5th gear can be annoying and would more than likely be the reason why Honda does not reccomned the HFP exhaust for the automatic transmission fits
It would appear as if the touring or chambered exhusts are the better choice
like kechan tried to explain to me in the beginning of this thread. however the 4 to 500 price to me is just not worth it. Adding a fancy exhaust tip May be the best solution as the Fit is good for what it is in stock form and dress up seems to suit it well.
SS RICH
