Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor Fitfreak.net take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
I pulled the steering wheel apart last week. There is a place for the contols and a dummy filler block in there but no extra wiring in the airbag clock spring. You would need to 'reassign' the dimmer wire and just ground the cruise button dimmer wire to the horn ground wire so they will not dim anymore. Honda only uses one wire for audio controls so you can use this now unused dimmer wire and cut it at the car side of the clock spring and run it to the radio. There should be an empty pin in the harness.
