subwoofer install
Old Jun 30, 2010 | 10:27 PM
mhopper's Avatar
subwoofer enclosure in spare tire. DIY
I just built this type box for my 09 sport with an mb quart shallow 10. It rocks! I'll get some pics up later.
Honda S2000 Subwoofer Install - Guides - Car Audio and Electronics
Old Jul 1, 2010 | 10:54 PM
mhopper's Avatar
more pics to follow....
Old Jul 1, 2010 | 11:06 PM
mhopper's Avatar
The enclosure lifts easily from the spare tire, yet fits snug enough that it does not rattle or move. In the tutorial in the link above, enclosure is bolted in with the wing nut of the tire. I molded over the wing nut so that the tire removal is simple and normal.
Old Jul 6, 2010 | 09:41 PM
mhopper's Avatar
new trunk floor and sub grill.
Old Jul 6, 2010 | 09:43 PM
mhopper's Avatar
trunk floor and grill closed.
Old Jul 6, 2010 | 09:44 PM
mhopper's Avatar
Amp location allows the use of EVERY INCH of trunk space. (Very important to me!)
Old Jul 6, 2010 | 09:46 PM
mhopper's Avatar
A little bit of cleaning up to do on the wiring, but here is the whole picture.
Old Jul 6, 2010 | 10:11 PM
Perrenoud Fit's Avatar
Hey mhopper,
Man all I see is little red X's we like to see ur work. Maybe an album @ ur page you can add up to 100 pix!
Old Jul 6, 2010 | 10:26 PM
mhopper's Avatar
thanks! lemme see if I can fix it.
Old Jul 6, 2010 | 10:52 PM
mhopper's Avatar
do the pics work now? they are a bit blurry, but I think they are there.
Old Jul 6, 2010 | 10:55 PM
NipponFit's Avatar
very nicely done. how did you mount the amp so that you utilized the trunk space?
Old Jul 6, 2010 | 11:08 PM
mhopper's Avatar
Thanks for the compliment!
Under the type right hand corner of the top amp is a body support or rib. The amp rack is three pieces of wood cut to fit the contour of the plastic panel. The wood was glued together and and covered. Then it was attached with only 1 screw through the panel into the rib. VERY little damage to the car! I'll try to get a clearer picture tomorrow.
I worked in car stereo for 12years as an installer and was a 3 time IASCA finalist and podiumed in the CMAA pro division back in the day. I have done better work, but i'm not competing anymore so there are some rough ends. When I get more time I'll improve it. I have hertz components in the front. They are OK, but I have heard better. That may be the next change. I went old school on the amps because they fit well and the sub amp can be bridged to 2 ohms. They are extremely clean sounding. I have a brand new tarantula 4 channel, but I decided to go old school.
Any suggestions are appreciated.
Old Jul 29, 2010 | 05:57 PM
statikeffeck's Avatar
wow this is really nice. So you're not using the spare tire itself as the enclosure... you just created an enclosure (fiberglass???) to fit snugly within the spare tire? this is an amazing install, you should try to rename the topic to "subwoofer install inside spare tire" to make it more accessible.
I would love to do this in my Fit.
Old Aug 1, 2010 | 10:13 AM
mhopper's Avatar
Thanks for the compliment. If you look at the start of the thread, there is a link for a tutorial that is step by step. You can do it! Be brave and give it a shot. The only thing I did differently was I did not bolt the enclosure down. You would have to remove the sub from the enclosure to change a flat. I simply molded it over the bolt. Then, instead of carpeting the bowl of the enclosure, I sprayed it with 4 coats of undercoating. The enclosure sits snuggly in the rim and the undercoating keeps it from rattling and vibrating.
Old Aug 1, 2010 | 11:20 AM
apexanimal's Avatar
approximately how large is the volume of the enclosure?
and i can't quite tell, but did you surface mount the sub? how much clearance was there between the top of the enclosure and the rear floor?
nice work
Old Aug 1, 2010 | 06:30 PM
mhopper's Avatar
If you look at where the trunk floor sits, on the the left and right side there is a lip the floor sits. There is another lip around it that is a little higher and wider (mine is an 09),. I cut a new trunk floor to sit on this upper lip. It gave me about another half inch of clearance.
Old Aug 1, 2010 | 06:33 PM
mhopper's Avatar
the enclosure is approx. .6 cubic feet
Old Aug 2, 2010 | 02:28 PM
apexanimal's Avatar
^thanks
{10 char-coals}
Old Aug 17, 2010 | 10:20 AM
EDJ82's Avatar
Great work!
Old Aug 17, 2010 | 06:49 PM
fitted08's Avatar
thats sick i like the hidden look like that, i was never a fan of stereo speakers or amps just thrown all over, nice job
