Wheel stud replacement?
Tire shop that last had my wheels off cross-threaded one of the wheel studs.
Has anyone ever replaced a wheel stud or have an idea of the process?
This thread on the 2008+ Fit says that the studs must be pressed out of the hub: https://www.fitfreak.net/forums/2nd-...pppplease.html
Would that apply to the 1st Gen Fit as well?
Thanks
Thanks
i think is not a DIY procedure, studs are integrated to the hub by applying pressure and i dont think studs are sold in retail. i have one stud broken on my left front wheel, i was concerned at first, but then see there is no problem running with only three bolts. im expecting change all the hub like i did for my rears.
but if you want to try, first you need to find a specific stud and the uninstall the wheel hub, (is far more complicated on the front than the rear ones), and then send to a workshop for the installation. and after that im not sure if the fix will work for long (if it works)
NOTE: Old car models used to work with this fix, so you will find lots of people given you the repair advice.
I've never had to do this on a Fit, but had it done once on my wife's old Chevy Cavalier. At the time we were stranded in another city and the stud sheered off when I was taking off the wheel to put on the spare. Anyway, I was surprised how little a shop charged me to do it when we got the new tire. it was was something like $50.
SilverEX15
01-20-2019 11:30 PM
Phoenician
10-05-2016 12:08 AM
