Civic engine wash
Old May 4, 2005 | 04:44 PM
nash123
Guest
Posts: n/a
Civic engine wash
Hi,
Own a 99 Civic EX. I am an engineer and had to visit construction
sites for inspection. My engine has a lot of mud, it is covered and
needs a good wash.
What is the best way of doing this? Is pressure washing OK? How about
electrical and other hoses/connections? Should I do a wash when the
engine is completely cold or somewhat warm?
Any suggestions? The engine really needs a wash (I even got mud in the
cooling fan) but I am hesitant to do a pressure wash.
Thanks.
Kevin McMurtrie
Guest
Posts: n/a
Re: Civic engine wash
In article <1113699837.011802.200580@l41g2000cwc.googlegroups .com>,
"nash123" <bulent74@gmail.com> wrote:
> Hi,
> needs a good wash.
> Thanks.
Cover the oil and alcohol based fluid tanks and the transmission vent
with rags or plastic because a strong stream of water hitting them will
require an immediate fluid change. Wash with a normal garden hose and
garden nozzle. Don't direct forceful streams of water at bearings or
electrical connectors.
Ron
Guest
Posts: n/a
"nash123" <bulent74@gmail.com> wrote in message
news:1113699837.011802.200580@l41g2000cwc.googlegr oups.com...
> Hi,
> needs a good wash.
> Thanks.
Do it when the engine is cold, you have the risk of cracking the exhaust
manifold. I cover the dist cap, alternator and fuse box with a plastic bag.
Spray engine cleaner on the engine only (avoid the paint). Rinse with the
water house with no water pressure, jut let the water run. When you finish,
warm up the engine. Let it cool down, dry it with rags and then wipe the
plastic parts and hoses with a little bit of armor all.
User1
Nov 14, 2017 07:52 PM
EXT
Jun 18, 2012 12:57 AM
pilozm
Mar 6, 2012 04:17 PM
Fit 4 JeLLie
Jan 12, 2010 02:38 PM
Fijoy George
Sep 20, 2005 12:30 PM
