Help to turn off ABS alarm
Old Oct 11, 2006 | 01:58 PM
TAKUSITO's Avatar
Unhappy Help to turn off ABS alarm
Hi:
Recentley I needed to change a front wheel bearing. We took the disc brake housing to do the change. After reassembling the wheel, the light of ABS turned on. I have tried disconnecting the battery for 15 minutes, checked lights and run the car for a few miles and the light still on. Do anyone have had this sort of problem?
Thanks and keep Fit-in
Old Oct 11, 2006 | 04:10 PM
quangalang's Avatar
ooooooh you damaged your ABS sensors. go back and check all the wiring to the sensors to see if they are cut or damaged
Old Oct 11, 2006 | 04:43 PM
TAKUSITO's Avatar
We just moved the sensar away from work area without disconnecting it. We will again the wires.
Is there any method to check the sensor. We just touched one.
Thanks,
Old Oct 11, 2006 | 05:17 PM
quangalang's Avatar
i dont know of anyway to check the sensor but may be a brake shop does or a dealer
phoenity
Oct 20, 2016 05:39 PM
jdDC
Dec 30, 2015 02:52 PM
Unclebobby66
Jan 2, 2014 10:22 AM
Santiad
Oct 17, 2011 02:55 PM
untx3
Aug 16, 2007 02:29 PM
