Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Vendor Marketplace Forums > AJ-Racing.com
AJ-Racing.com
AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #141 (permalink)
Old 03-10-2007, 10:48 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
03DSM-RSX has a spectacular aura about03DSM-RSX has a spectacular aura about
Send a message via AIM to 03DSM-RSX
Quote:
Originally Posted by damnu View Post
oil return on a SR20 goes into the block, so NOT ALL oil returns are tapped to the pan.
SR20DET's are boosted stock, hence factory setups are different from aftermarket. I guess i have to edit to where "aftermarket turbo setups are returned to the pan"
__________________
"Neg-rep'd by Claymore" Crew
03 DSM RSX Base Automatic-287whp/240wtq.....new build this summer
05 RS 1.0 TRD S/C tC - 283whp/200wtq 12psi + 35 dry shot
06 WDP TL A-Spec
07 VBP Fit Sport Auto-Totaled
07 WDP RDX w/ Technology Pkg
08 Vapor Metallic Saleen Mustang S281 3-Valve #25
08 Ford Expedition EL XLT
  #142 (permalink)
Old 03-12-2007, 03:56 AM
quangalang's Avatar
quangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to live
My 2 cents: Since the L15's oil pan is aluminum i would assume that it is thick enough to be drilled and tapped then screw in a AN fitting, unlike the B-series motors where the oil pan was just thin steel. i don't see a point in the need to weld an oil return fitting on the oil pan welding cast aluminum isnt that easy let alone one saturated with oil.... idk im just throwing it out there. hehe
  #143 (permalink)
Old 03-12-2007, 05:04 AM
TomiGunz is on a distinguished road
Quote:
Kind of what I was thinking. If a oil filter can let oil pass through it without leaking I'm sure a fitting will work just fine.
But as 03DSM-RSX says, "it's better to weld". Most shops charge about $20 bucks to do.
I would do either way since it's just a oil dump line.
03DSM-RSX, I'm not sure who would put a banjo style connector on the oil pan side of the oil line, so I think you were probably thinking of the wrong type of connector. Just a straight connector to the oil pan so the oil can dump into the pan would be just fine.. this is what I believe..
  #144 (permalink)
Old 03-12-2007, 10:41 AM
jits14's Avatar
jits14 has a spectacular aura aboutjits14 has a spectacular aura about
When you look at Tig welding aluminum, it aint gonna be cheap. Plus you will have to find an aluminum connector too cause you cant weld aluminum to steel.
__________________
_________________________________________________
  #145 (permalink)
Old 03-12-2007, 12:47 PM
I was aware of that. If we did have to weld, I'm sure the T1R kit will come with a connector.
Friend of mine has a R/C boat. The bottom fin on his engine broke. The shop charged him very little to weld that peice back on. Yes it was aluminum.
But I won't say anything more until Ben lets us know what the kit will come with...
  #146 (permalink)
Old 03-12-2007, 01:25 PM
do129 is on a distinguished road
I got a question for the turbo kit, i live in melbourne australia, and yes of course im really interested with the turbo, after done so much research on turbos, does this turbo kit fit in my jazz? what i meant is my jazz is an australian version, will it perfectly fit in? or i need modified some parts? for example aus jazz brake fluid bottle is located on the left while the us version is on the right will this be a problem on installing the turbo? the piping? and all other stuff? Thx
  #147 (permalink)
Old 03-12-2007, 03:28 PM
03DSM-RSX's Avatar
the pan is aluminum, so you'd use an aluminum 10AN male fitting. it'll weld right on.
yes, the aluminum pan is much thicker than the thin steel ones. So welding MIGHT not be needed. But if available then do it.
here are pics of an a2 oil pan, very similar to that of the FIt's pan.
drill and tap for a 1/2 - -10an fitting and screw the bitch in...no welding needed and no nuts in the oil pan...
there is a cap on the fitting b/c the owner does not have the turbo on yet.
you can also see the white teflon tape.
something anyone can do themselves.
as for oil residue on while welding, when you remove the pan, you clean the pan out with brake cleaner. Oil washes right off and pan will be nice n dry.
this is what a banjo return line/fitting looks like. A banjo bolt replaces the stock oil drain bolt and goes into the stock oil drain location, which is at the very bottom of the pan. Not very effecient for turbo oil drainage.
Greddy has used this type of return line on the RSX, not sure about other cars, but this caused a LOT of problems for the users. Most replaced their oil lines with the tap/weld method. Problems included blown oil seals, leaking turbos, oil in charge pipes, excessive oil burn, and even car fires. Greddy's latest turbo kits no longer use the banjo fittings.
__________________
06 WDP TL A-Spec
  #148 (permalink)
Old 03-12-2007, 04:01 PM
nothx is on a distinguished road
thanks for the info, i can definitely tap a hole for the plug myself, i'd probably buy a new oil pan to do it on so once i had all the parts for the turbo, i could get right to business.
  #149 (permalink)
Old 03-12-2007, 11:40 PM
quangalang's Avatar
Another possible problem i see is, since the stock oil pump produces around
70-90 psi, and turbos only need roughly half that(correct me if im wrong), should we have to run an oil pressure regulator or something so it wont leak through the turbo seals and wreck the turbo over time?
  #150 (permalink)
Old 03-13-2007, 12:30 AM
AJ PwR Jr.'s Avatar
Premium Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
For the oil return line, you will need to take off the oil pan. You will need to drill a hole and bolt the fitting on. It will be different than the Greddy one but something similar.
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
  #151 (permalink)
Old 03-13-2007, 01:08 AM
damnu is on a distinguished road
Yeah i can totally see why the banjo bolts are bad, since the return line is gravity driven, a banjo fitting seems to restrict flow causing all the for mentioned problems.
Youre suppose to use a restricter on the oil inlet line to restrict flow for the turbo. Depending on the type of turbo, a different size restricter is needed. Ball bearing turbos need less oil flow than journal bearings.
  #152 (permalink)
Old 03-13-2007, 01:43 AM
03DSM-RSX's Avatar
^yup. generally, the manufacturer who supplies the turbo kit provides the oil feed line that provides the fine mist of oil the turbo needs. I'm sure AJR will provide everything needed.
If not, Fast-turbo.com specializes in all turbo accessories and lines. they fabricate oil line kits for all types of turbos and cars. you can pretty much get anything you need from them.
__________________
06 WDP TL A-Spec
  #153 (permalink)
Old 03-13-2007, 02:10 AM
Quote:
Thanks for the info.. now we'll have someone off our back =)
  #154 (permalink)
Old 03-16-2007, 08:17 PM
Senior Member
firstshadow will become famous soon enough
Send a message via AIM to firstshadow Send a message via Skype™ to firstshadow
official dynos next week maybe... thats what i heard.
__________________
  #155 (permalink)
Old 03-17-2007, 12:02 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
sLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to live
Send a message via AIM to sLiVeRwOrM Send a message via MSN to sLiVeRwOrM
What happened to the other dynos?!
The first ones were on a mustang dyno so I dunno if they can be fully trusted..
__________________
If it moves, try to race it. If not try to eat it.
  #156 (permalink)
Old 03-17-2007, 03:48 PM
AJ PwR Jr.'s Avatar
We are curretnly fixing the boost creep problem and we should be hitting the dyno next week sometime.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #157 (permalink)
Old 03-20-2007, 12:35 AM
gn-it&rn-it's Avatar
gn-it&rn-it has a spectacular aura aboutgn-it&rn-it has a spectacular aura aboutgn-it&rn-it has a spectacular aura about
will this turbo set-up be compatible with AT Fits??? Suggest tranny upgrades?? and can I add nitrous later down the road???
  #158 (permalink)
Old 03-21-2007, 12:18 PM
dj_buddah is on a distinguished road
i am curious ben are you guys going to make turbo exhaust or will the ones you currently have out provide enough back pressure?
also with the kit i am not clear, are you going to provide the Greddy e-manage with this? if so will the seprate greddy boost controller be an option?
  #159 (permalink)
Old 03-21-2007, 02:00 PM
daviddahlb is on a distinguished road
Hey Ben,
An important issue is oil starvation during high speed sweepers. Since you have experience with this and the oil pan, do you think it needs baffles added to ensure oil pressure? Because it makes sense to add these baffles when I've got it removed for the oil fittings...
Thanks!
__________________
www.solo2.com
www.skunk2.com
  #160 (permalink)
Old 03-21-2007, 02:32 PM
AJ PwR Jr.'s Avatar
Quote:
This Turbo kit will be competible with AT. Reinforcing the tranny with running low boost is not necessary but it is always good to gave drivetrain components reinforced.
Nitrous is something that i don't recommend. It wears down your engie quickly.
The T1R 50S will work with this turbo. Actually the 50S sounded a lot quieter comparing to a stock engine. Having a bigger exhaust will make the Turbo spool slower but at the same time you will gain a few more hp,which means the Turbo will lag and we don't want that.
Quote:
Hey Ben,
Thanks!
When I was trying the Fit with stock engine, I don't have any issues with that but ofcourse with more power things will be different.
By looking at the oil pan and the oil pick up, since the oil pan depth is so deep on the Fit and and I don't think there will be any issue about that.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
Reply
Tags
kit, t1r, turbo
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Turbo 1.5L Honda Jazz Nasty Gurl Fit Forced Induction Forum 48 04-30-2009 01:32 AM
2007 civic lx auto sedan or 2007 fit sport auto? oneduduboy Other Car Related Discussions 13 03-04-2007 12:22 AM
fit turbo tumbleweed80 Fit Forced Induction Forum 6 12-15-2006 11:27 PM
Sleeping turbo? Ragnarok0mega Fit Forced Induction Forum 7 12-04-2006 10:37 PM
New Honda Models for 2007 ActionJG Front Page News 16 10-05-2006 05:40 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
