Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Vendor Marketplace Forums > AJ-Racing.com
AJ-Racing.com
AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #41 (permalink)
Old 02-22-2007, 02:08 PM
lanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to livelanakano relies on Rep Points to live
By adding the ETD and mounting it to the crank pulley side of the engine with the other end mounted to the chassis, wouldn't one be adding (an uncommon to OEM) torsional stress to the engine/trans mounts? I don't believe that all of the forward and aft energy goes into the ETD shock. I believe that some of this energy is deflected and shows up as torsional stress on the engine and trans mounts. Engine mounts are designed to stretch and compress and to accommodate some torsional stress. However, I believe that we'll see higher engine/trans mount failure with the ETD. Although the shortening of the service life of them won't be significant. In addition, they are pretty easy to r/r.
If you are worried about your engine mounts you might want to add Claymore's homemade ETD into the equation. I think your enigine mounts will be more happy with an ETD on the crank and flywheel side of the engine v. just on one side.
I've had ETDs on other cars and like Leonine and others (above) believe they offer real performance benefits to cars (i.e. wheel hop, smoother shifting, etc.). In addition, auto manufacturers use them on their OEM applications too. Why didn't our Fits get them - probably cost savings.
FYI Below is a pretty good write up on Club EL re: the pros and cons of the ETD.
http://forums.clubel.ca/showthread.php?t=22114
  #42 (permalink)
Old 02-23-2007, 09:52 AM
Wave's Avatar
Wave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to live
Tagged for interest in this.
Wallet ready(as long as it fits with a Cusco front strut tower bar).
__________________
  #43 (permalink)
Old 02-23-2007, 01:03 PM
B( * Y * )BIES's Avatar
B( * Y * )BIES is on a distinguished road
Send a message via AIM to B( * Y * )BIES
Quote:
Originally Posted by claymore View Post
- The only way to stop engine twisting and movement is to use TWO dampers one on each end, or find the point 2/3s down the engine where the center of the balance for forces from both ends of the engine is found and use one damper BUT it will now be behind the engine making the installation difficult for most shade tree mechanics and therefore hard to sell to the general public.
Claymore, I like your entire post and would like to add a thought to the above quoted part. First off let me say that I don't suggest this thought unless you're seriously stripping the car for race purposes. Nor do I claim that ALL race cars do this! We could use solid engine mounts to eliminate any engine movement thus eliminating the need for ETD's.
Can someone please direct me to a picture of the engine that is using 2 ETD's. Thanks!
Oh and one more comment...
Quote:
dj_buddahi - just dont see this item practicle on a car that cant get 100whp without extensive mods, this part would makes sense if replacement mounts came with it and you had an engine that needed it
a 1.5 liter engine does not need this part just yet , i would rather get more under suspension pieces.
dj - though your opinion is well taken (and I'm not picking on you) I'm sure there are many Fit owners who would claim that more under suspension pieces would not be practicle since the car does not need it. In conclusion... no car needs any modifications of any kind. It's how the owner of the car preceives the things he/she wants in, on, and/or out of the car.
__________________
  #44 (permalink)
Old 02-23-2007, 03:12 PM
In re: reply #44 to this thread B(*Y*)BIES wrote "Claymore, I like your entire post..."
Hmm... I'll hold back my comments on this. However, maybe Claymore will respond.
  #45 (permalink)
Old 02-27-2007, 07:57 PM
ginofultano is on a distinguished road
will that damper protect me from the dreaded tank slapper?
  #46 (permalink)
Old 02-28-2007, 04:52 PM
Quoting from a different thread re: TQ Damper: Dickson wrote that according to Ichishima the first batch of AJR exclusive TQ Dampers "should be ready in March." Dickson also mentioned that AJR "will for sure host a groupbuy on these once they are available."
Dickson or Ben can you tell us what the status is on the first batch?
  #47 (permalink)
Old 04-12-2007, 11:13 PM
Sleeper is on a distinguished road
you got pm
  #48 (permalink)
Old 04-13-2007, 10:52 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
sLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to live
Send a message via AIM to sLiVeRwOrM Send a message via MSN to sLiVeRwOrM
its past march
__________________
If it moves, try to race it. If not try to eat it.
  #49 (permalink)
Old 04-16-2007, 11:59 PM
AJ PwR Jr.'s Avatar
Premium Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
The prototypes that we have been testing, one of the braket broke off so we have spent a few weeks time just to develop a new one. All the information has been sent back to Spoon so they are manufacturing them now.
I hope to see them by the end of May.
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
  #50 (permalink)
Old 04-17-2007, 10:27 AM
gettinafit will become famous soon enough
"The world tends to unfold as it should...." "Innovative Mounts" stock replacements is probably going to be the only way to go!
__________________
ImportFest 2007
http://www.fitfreak.net/forums/car-s...tml#post196608
  #51 (permalink)
Old 04-17-2007, 10:31 AM
leonine's Avatar
leonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to live
Took the words right out of my mouth. But it sure looks purdy.
__________________
Check out the transformation over the past 3 years.
http://www.facebook.com/album.php?ai...7&l=cd5f9d6b0a
  #52 (permalink)
Old 05-11-2007, 07:35 PM
AJ PwR Jr.'s Avatar
Update
Hi all,
The final prototype has been done because for the past prototypes, we got problems with the bracket which kept breaking. It's finalized and they are in production now.
Here are some update pics :
-We have tested it with Spoon and J's Racing Strut bars and there are not fitment issue with the E.T.D.
-Another view
Thanks
Ben
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #53 (permalink)
Old 05-11-2007, 07:39 PM
Ben,
Please PM Price. I'll be your guinea pig because I have confidence in AJR and Spoon to manufacture this bracket so that it doesn't break.
Lance
  #54 (permalink)
Old 05-11-2007, 08:57 PM
AJ PwR Jr.'s Avatar
Quote:
Originally Posted by lanakano View Post
Ben,
Lance
Hi Lance,
I will let you know when they become available.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #55 (permalink)
Old 07-30-2007, 12:19 AM
Twilight is on a distinguished road
Any news on this yet?
  #56 (permalink)
Old 07-31-2007, 02:19 AM
AJ PwR Jr.'s Avatar
Quote:
We are trying to speed up the process but we are having some issues with the bracket being not strong enough. We are working on it and will come up something pretty soon.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #57 (permalink)
Old 08-03-2007, 11:37 AM
hehehe maybe its time to bring out those reinforced titanium brackets hahaha
  #58 (permalink)
Old 08-17-2007, 07:24 AM
dickiez's Avatar
dickiez has a spectacular aura aboutdickiez has a spectacular aura about
Send a message via AIM to dickiez
Quote:
x2 on that
__________________
GD3 Squad Member #72
  #59 (permalink)
Old 08-17-2007, 11:34 AM
Illusive's Avatar
Administrator
Illusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to liveIllusive relies on Rep Points to live
Send a message via MSN to Illusive
Sounds like you need a Mechanical Engineer I might be able to make some rough calculations and run some simulations, I just need some more pictures of the bracket, where it is breaking, what type of material is being used, what type of screw is being used including material, and approximately how much force the damper is exerting on the bracket. If you can't approximate that, I just need to know the specs of the damper and the approximate travel of the engine when torque is applied, I can do the proper calcs from there.
__________________
  #60 (permalink)
Old 08-17-2007, 02:38 PM
dickiez's Avatar
Quote:
with that?
can you help me with my Vector Statics Homework???
__________________
Reply
Tags
damper, edmund, engine, install, installation, opak, racing, spoon, torque
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Header xtreme General Fit Talk 5 05-30-2009 03:12 AM
'Mythelogy' lightened crank pulley redz jack Fit Engine Modifications, Motor Swaps, ECU Tuning 180 04-11-2008 07:49 PM
Spoon ENGINE MOUNT TORQUE CANCEL DAMPER SpoonFitGD3 Fit Engine Modifications, Motor Swaps, ECU Tuning 10 07-18-2007 04:27 PM
Engine Torque Damper sLiVeRwOrM Fit Engine Modifications, Motor Swaps, ECU Tuning 8 07-27-2006 08:51 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
