AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
Welcome to Fit Freak!
Welcome to Fit Freak,
Where does it go? Can anyone link a picture of where they installed it. I installed my stabilizer though. Piece of cake. Is there a pdf to show where i install the earthing too? I didn't buy that yet or the booster.
try post #70 on page 4 of this very thread.
__________________
5/15/06--Black Sport 5AT
Volk GNR, T1R intake, JDM bits
55K+ miles and zero problems
Installed the stabilizer. Haven't notice any change in the acceleration and I have noticed power spikes and losses. Don't really know if it is working. Hoping the gas mileage shows otherwise.
Turns out that after I installed the voltage stablizer, my gas mileage was atleast 7% worse!!! I will leave it hooked up for one more tank of gas, but if I get the same terrible mileage the next time, I'm removing it. I don't know how or why it would make mileage worse. Any ideas?
Any change in general weather conditions out there in NJ before and after the VS? could be barometric pressure, humidity, temp. etc. Tire pressures OK?
__________________
Reason: had another thought
Could you PM me a price on the stabilizer and booster? Shipped to 97321. I think I will build the earth kit on account, my wife doesn't like the blue...
Perhaps a silly question, but will adding these three have any effect on my warranty?
Also, could I get a PM with the price for all three to 63385?
It will not. Btw, PM sent
__________________
--------------------------------------------- A&J Racing International #155-1991 Savage Rd Richmond B.C. V6V 0A4 TEL: (604)279-0329 Email: info@aj-racing.com URL: www.aj-racing.com Your JDM parts and Honda Tuning Specialist
I just bought all three and will be doing a complete comparison of a before and after test to see how much extra L/100km I get. Same driving style, same gas, same tire pressures...only variable is weather, but that is an every day thing and you can't control that. Currently running my tank of gas without the stuff, will probably take another week or two for an accurate comparison.
I got a question. The ground Kit is the same as the Voltage stabilizers? made the same things?
They are different. The ground kit is to ground out the electronic noise and the Voltage stabilizer is to regulate the voltage.
Quote:
I never did get a PM. Could you please re-send?
Thanks!
Sent again
__________________
Quick update on my test. It's looking promising...I was getting about 425km/tank of gas with city driving WITHOUT the mods. I made the mistake of leaving my A/C on for 1/3 tank AFTER I put on the mods which I thought would hinder my mileage. To my surprise, it's looking good. I passed the halfway mark at around 280km on the trip odometer. I usually pass the halfway mark around 250km. Like I said, this is a farmboy look at this, so I will have to wait for the final number after some more driving...will let you all know how it goes...
Currently on 2nd tank of gas. Got 460km on my last tank. Took it right to the "E". I'd estimate I gained about 10-20km on the last tank of gas. I'll see how much better it'll do this time around
I was wondering what fuse (# on the panel) everyone has pulled to replace the power source for the ignition booster. My mileage has gotten worse and I want to make sure I put it in the right spot. In addition I was wondering about one of the grounding points on the earth grounding system. The instructions have one of the wires connecting to the headlight housing. How will this work since the housing is plastic?
I double checked the earlier post by AJ Racing and they stated to install in ACC fuse. That is #27, and that is where mine is. Well, at least I can cross off that one
lol I better go check mine...I honestly can't remember the number...I hope I put it in the right place :s
mynute 1, is #27 on the main fuse board or is it the one off to the side?
I have an EU version Fit and I bought the ignition booster. When replacing the fuse in the under dash fuse box, i notice that there are two fuses, one named ignition coil front, and the other ignition coil rear. which one should i replace?
thanks.
thanks.
Either one will work but we normally use ACC fuse.
__________________
