Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Vendor Marketplace Forums > AJ-Racing.com
AJ-Racing.com
AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 12-16-2007, 02:36 AM
Fit of RAGE's Avatar
Honda Fit Forums Moderator
Fit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to live
DIY: T1R B-Max Carbon C-Pillar bar install
Here it is everyone! Since I was the 1st on the list to get one, figured that I'd post the DIY. (8 steps)
1) I'm only going to show 1 side of the install. The other side will be exactly the same. Here's the driver side rear seat belt assembly. Your's will not look like mine. I cut mine so that the previous c-pillar car I used, the J's Racing one, would fit with the cover piece on.
take off the cover. It just pops off.
2) The seat belt is held on by a 14mm bolt.
Take the bolt off:
3) DO NOT forget how the bolts go together. You DO need to disassemble the washers and bolts to install the bar:
4)
Now, i find that it's easier to do it this way, but it's not necessary. I disassembled the c-pillar bar.
5)Then install the bracket for the c-pillar bar:
here's a pic from another angle:
DO NOT TIGHTEN THEM FULLY!!! Leave then loose so that it's easier to adjust if you need to later.
6) Ok, now for the hard part. The c-pillar is adjustable. What you need to do, is figure out the length of the bar. As you can see it's too short.
Here's the original length:
Here's the length after I've adjusted it:
Notice that the adjustment nut is backed TOTALLY off so that the bar is easily adjustable later if needed.
7) Stick the bolt through once you've figured out the proper length. Then tighten everything down. (seatbelt bolt and the c-pillar bar to bracket bolt.)
8) Last step, adjust the actual bar, the carbon part, to put a little bit of tension on the frame, tighten down the adjustment nuts (the ones that button up to the bar) and you're DONE!
Thanks AJR for the putting 1st on the list! Love you guys!
Sponsored Links
  #2 (permalink)
Old 12-16-2007, 02:54 AM
Quote:
Originally Posted by GD3-L15A View Post
Dude, i LOVE your DIY's!!! They're So clear!! even i can do it!
Thanks Buddy! I'll try and do more. I should have done one for the headlight swap!! DAMN!!
  #3 (permalink)
Old 12-16-2007, 03:03 AM
vince's Avatar
vince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to livevince relies on Rep Points to live
Looks good im jelous
  #4 (permalink)
Old 12-16-2007, 03:05 AM
Quote:
Get one, you work there!!
  #5 (permalink)
Old 12-16-2007, 03:07 AM
vince's Avatar
no im not baller enough to buy cf everything man
  #6 (permalink)
Old 12-16-2007, 03:21 AM
Combo's Avatar
Combo can only hope to improve
another wonderful guide
hows the feel? any difference?
btw u got ur cf hood yet?
  #7 (permalink)
Old 12-16-2007, 11:06 AM
Thanks! the hood isn't in yet, hopefully before Christmas!
  #8 (permalink)
Old 01-18-2008, 05:31 AM
FELIXY69's Avatar
FELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to live
how come i have more washers then you ? weird !!
__________________
One Cool Daily Driver
Honda tuning is a LifeStyle
Nissan tuning is to go stupid FAST !
Goals for 2009
Wide Fenders --> DONE
Airbags --> 3/4 DONE
Wide Wheels --> 9.5 +5
~~B00sted Wide Body NobleSSe fit~~
Rep me if you like
thank you !
  #9 (permalink)
Old 06-18-2008, 11:12 PM
jdmfit88's Avatar
jdmfit88 will become famous soon enough
Send a message via AIM to jdmfit88
nice write up. got my c-pillar and only took me about 5-10 mins.
__________________
Mugen(Visors, Door Sills, Oil Cap-Red, Radiator Cap, 2 Reserve Tank Cover, license plate Frame, Rear Wing Spoiler) CF Manifold Cover, Benen Rear Tow Hook, ASPEC Axle-Back Exhaust, 20% Tints, LED TailLight Red/Smoked, All Red Hazard Switch, PassSide Visor w/ Mirror, Type R Key Cover, C-Pillar Strut Bar, T1R B-Max CF Intake, Type R Emblem Rear, Takata shoulder pads, Progress Springs & Tokico HP Blue Shocks, Weapon R Engine Damper
  #10 (permalink)
Old 06-18-2008, 11:22 PM
zRollerskate's Avatar
zRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to livezRollerskate relies on Rep Points to live
Send a message via AIM to zRollerskate
i love the rubber gloves... my fit and scary movies are my faves... so you kinda put the 2 together =P
  #11 (permalink)
Old 07-04-2008, 06:55 PM
Red Iron Crown will become famous soon enough
Forgive me, but I'm unclear as to what this part is supposed to do. Is it about chassis rigidity? Aesthetics? A place to hang clothes?
  #12 (permalink)
Old 07-05-2008, 03:22 AM
Quote:
chassis rigidity
  #13 (permalink)
Old 07-15-2008, 03:24 PM
F.IT's Avatar
F.IT will become famous soon enough
Quote:
Originally Posted by Fit of RAGE View Post
chassis rigidity
Damnit! I ordered the T1R carbon clothes hanger by mistake
  #14 (permalink)
Old 08-06-2008, 03:26 PM
Gbaby2089's Avatar
Something Awesome???
Gbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to liveGbaby2089 relies on Rep Points to live
Does the Fit feel any different once this is installed?
__________________
  #15 (permalink)
Old 09-09-2008, 05:16 PM
alexfree05's Avatar
alexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to live
Send a message via MSN to alexfree05
me2!!!
do i need to cut the cover like yours?
because i can't put it back after installing it
__________________
FS: Tein S. Tech lowering Spring!
  #16 (permalink)
Old 09-09-2008, 05:50 PM
It's a daily driver so I don't feel much difference. Yes you'll have to cut the covers to make the cover pieces fit
Quote:
Originally Posted by alexfree05 View Post
me2!!!
  #17 (permalink)
Old 06-21-2009, 03:24 PM
trancedsailor's Avatar
trancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to live
Send a message via AIM to trancedsailor
anyone have any ideas on how to cut the seatbelt part so I can access the bolt? I'm scared to do this.
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
1994 EG2 B16A3 acquired 9/3/09
  #18 (permalink)
Old 06-22-2009, 05:04 PM
AJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to liveAJR Jay relies on Rep Points to live
Send a message via MSN to AJR Jay
You can use a small hack saw if you'd like, or if you have a sharp exacto knife, you can cut the plastic peices.
Regards,
Jason @ AJR
__________________
A&J Racing International
#155 - 1991 Savage Rd.
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
  #19 (permalink)
Old 07-17-2009, 04:41 PM
Black3sr's Avatar
Black3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to live
Fit of Rage - are you saying not really worth it unless doing some serious cornering? If so crap as I have one in transit.
Oh well it makes a nice clothes hanger for the old folks when traveling( I being one of the old folks).
Tranced sailor.. I will use a Dremel and Exacto knife to trim away from the top down til it is FITted. It looks like only the inner piece needs trimming.
bill
__________________
''Life's tough......it's even tougher if you're stupid.''
My site - http://black3sr.com/
  #20 (permalink)
Old 07-21-2009, 12:18 PM
Black3sr's Avatar
Here is a pic of my install. Yes it is a cheaper C bar but it will hold clothes OK -)
I just used a hoby razor saw to cut top piece off.
It is helpful to have a third hand to start the bolts back in.
__________________
Reply
Tags
bar, bc, benen, bmax, carbon, cf, cpillar, diy, gd3, install, js, pillar, racing, strut, t1r
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LDO's Nokia Pedal Install, Mod, and Dead Pedal Fab LDO Fit Interior Modifications 17 07-13-2008 01:42 PM
DIY - Door Sill install Chikubi Fit DIY: Repair & Maintenance 19 09-11-2007 08:43 AM
Ats/across (carbonetics) Carbon Lsd Impressions lanakano Fit Trix General Discussions 12 02-06-2007 11:45 AM
DIY - Door Sill install Chikubi Fit DIY: Repair & Maintenance 0 06-04-2006 12:12 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
