J's LSD maintenance schedule??
I was wondering if you guys could tell me how often the differential oil on the J's Racing LSD needs to be changed?
And does the differential oil replace your transmission oil or do you still need both?
And if they don't replace eachother do you have to remove the transmission from the engine to replace the differential oil?
And how often do you have to repair/overhaul the J's racing?
Also do you know how the J's Racing maintenance schedule compares to the ATS Carbon LSD maintenance schedule?
I'm asking because i want an LSD mainly for street use, maybe drag/autox in a couple years and I've been looking at the Quaife LSD and although it sounds good it does have it's draw backs compared to a clutch type LSD, so I'm trying to outweigh the bad points of each type. It's easy to find the good points, but a lot harder to find the bad points.
