AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
If only I had the money for this. Also a quick question I thought you guys were making 2 kits Type R and Type S, is Type R the faster one or did you drop that project all together and plan on releasing one kit for now? I havent been keeping up with the FI threads so I might have missed it.
The Type S (E-Manage Blue) has been discontinued. Only the previously named Type R (E-Manage Ultimate) is offered now by AJ Racing.
__________________ Mugen - T1R - J's Racing - Spoon
Fitfreak.net Admin! Fear the PINK WRATH! =)
Got a question? I might have an answer, drop me a PM if you need help!
- KillerFit #10 - KRAFTWERKS Kit Owner #5
The Type-S kit already has the ability to run higher boost so the Type-R option is justa boost controller + a different map.
We will be hitting up the dyno in April and will have results by then.
__________________
--------------------------------------------- A&J Racing International #11-12840 Bathgate Way Richmond B.C. V6V 1Z4 TEL: (604)279-0329 Email: info@aj-racing.com URL: www.aj-racing.com Your JDM parts and Honda Tuning Specialist
Now with the bigger injectors and the more aggressive maps, is there any chance it would be getting starved for fuel from the fuel pump. Do you recommend upgrading the pump or is the stock pump sufficent?
okay.. got some serious questions cuz i've got the 4g's saved up for some booooostin action but i'm still debating between the KWSC (which is taking foreverrr) and the T1R kit. Let's get some things cleared before i order:
1) Where are the turbo oil inlet tap going to be? Right now i have a sandwich plate for my oil pressure gauges so can i use one of the existing openings? Where is the oil feed outlet, is it going to be a oil pan tap? i don't see any info regarding that.
2) What's going on with the windshield washer bottle? will the new one be included as well?
3) How much is the total + shipping to CA? How about a partial sponsorship? =]
So I guess there is no more Carb Legal version then huhh?
I cannot afford to get poped.
Once I have time, I will get working on it. Please wait.
So far, no problems with stock fuel pump. You can replace it but I will say not necessary.
__________________
Is it possible to get the Emanage tuned for 10 pounds with this kit, and then add a 10 psi wastegate spring? That would seem the simplest solution. Just run the 10 psi map at 6 psi, and add a heavier wastegate spring when you feel like murdering your clutch.
__________________
'07 MR Fit Sport MT
Aspec axle back, Megan Racing B-pipe
T1R Turbo kit, 6psi
Greddy E-Manage Ultimate, tuned by yours truly (and yes I'm damn proud of it!)
The most modified fit in Michigan!!
(that I know of)
After seeing all the things that needed to get modified or were missing from Marcus' kit, I'm not impressed. Really don't like the injector setup at all either.
That's something possibily we can do.
We just got the injector clips made up so the injectors from now on will be plug and play.
__________________
I need this after my gtr is done!!
sponsor me sponsor me !!!
I can't sponsor a baller like you You should sponsor me back lol .
__________________
so let me get this straight..almost the whole kit is plug and play, no modifications required? except for removing the fogs but i think i might get different piping b/c my buddy had the same problem with his prelude and the stock front bumper. please correct me if im wrong, because if im not then you got a NEW customer just gotta wait till i get back to the states!
I dont think I saw any mention of International Fits/Jazz. What changes have to be made for these kits to fit on those?
We have fitted the Turbo kit with JDM Front end and there are adjustment need for the front intercooler pipe.
Technically NO. It is not 100% plug and play, there are modifications needed for the install such as, trimming the bumper, minor trimming on radiator support and oil pan drilling for oil return.
__________________
