Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Vendor Marketplace Forums > AJ-Racing.com
AJ-Racing.com
AJ-Racing specialize in Japanese high performance automotive parts for both street and circuit use. Our extensive knowledge and experience with Japanese tuning products allows us to bring you the best Japan has to offer.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 04-25-2008, 06:13 AM
claymore's Avatar
claymore is a jewel in the roughclaymore is a jewel in the roughclaymore is a jewel in the rough
Quote:
Originally Posted by DynamicFit View Post
13.7 to 13.9 AFR is pretty damn safe in my opinion, in fact you probably are making even better power than most of us if you are running an AFR close to that on a naturally aspirated motor. 12.0 A/F is something you might want if you are running a turbo or other F/I, but as you are only N/A even 13.9 A/F is pretty reasonable considering ideal combustion is 14.7.
Your motor is fine.
Dynamic Fit is RIGHT on target. Nothing to worry about AND making more power and better fuel economy. (N/A only)
  #22 (permalink)
Old 04-25-2008, 11:45 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Raaaaaaaaaay. is an unknown quantity at this point
Quote:
And also demolishing the pistons and/or piston rings.
14.0 AFR's are lean as hell. Its what cars run when driving around not under any load.
And running lean doesnt always mean more power.
__________________
- KillerFit #2 -
- iFrame -
  #23 (permalink)
Old 04-26-2008, 02:40 AM
cavie187's Avatar
Avid FitFreak Poster
cavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to livecavie187 relies on Rep Points to live
I was going to say it, but i am sick of arguing.
__________________
**Name = Dave**
Last Stop For Exhaust Clips!!!! Videos Inside <--Click me!!!
Quote:
Originally Posted by kelsodeez View Post
haha yea dude ive taken out four airbags in my car and i say turning off your car while you are rolling is too unsafe.
  #24 (permalink)
Old 04-26-2008, 03:18 AM
Spooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to live
What does all this mean? so I should remove my T1R test pipe or what? I don't want to destroy my car so early
  #25 (permalink)
Old 04-26-2008, 04:07 AM
claymore's Avatar
There was no mention of 14+ readings ( where did you come up with 14+ readings ?????) 13.7 IS FINE (under all conditions) and WILL NOT DAMAGE INTERNAL PARTS INCLUDING PISTONS, PISTON RINGS, OR PISTON RING LANDS running N/A.
Running the CORRECT A/F ratio will always make more power than an INCORRECT one. The correct one is the closest to 14.7 (perfect) without detonation or preignition under all conditions load or no load ALWAYS (running N/A).
  #26 (permalink)
Old 04-26-2008, 04:09 AM
claymore's Avatar
Quote:
Get it tested as long as it's 13.7 or less under all conditions THAT IS FINE NO NEED TO REPLACE THE PIPE.
  #27 (permalink)
Old 04-26-2008, 02:33 PM
Posts in the NUUDE
Quote:
Where did you get 14.0+ AFR's? I simply said 14.0 AFR's. Nothing higher. When I mentioned anything higher I was comparing how high the AFR's were under load as to what cars run when NOT under load.
And 13.7 and 14.0 isnt a big difference. Either way its damn close to 14.0 AFR's.
Every car is different. Some detonate sooner than others. How do you know this is correct with the Fit?
__________________
- KillerFit #2 -
- iFrame -
  #28 (permalink)
Old 04-26-2008, 02:53 PM
AJ PwR Jr.'s Avatar
Platinum Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
The AFR number that I was mentioning were based on with all T1R parts installed so lets say , if you have stock header, bpipe and intake , the test pipe alone will lean it down a bit to give it some more power.
13.7~13.9 is a very safe AFR but the fact, the L15A engine stopped to make power after 13.5.
I think most of you didnt realized that when the stock Fit on partial throttle, the AFR is at 14~15 range so with the mods, there's nothing to worry about ruining the engine unless detonation.
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
  #29 (permalink)
Old 04-26-2008, 04:27 PM
Posts in the NUUDE
So with the cat-delete, I/H/E the fit lost power than due to the leanness?
I want a header, but not if Im going to loose power. And I want the T1R header.
I still want a tune also. Maybe adding the header and a tune will gain a good amount?
__________________
- KillerFit #2 -
- iFrame -
  #30 (permalink)
Old 04-26-2008, 05:33 PM
AJ PwR Jr.'s Avatar
Every different manufacturers got different designs for their own exhaust so AFR reading will nto be the same but if you run full T1R, fuel management is recommended with the test pipe.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #31 (permalink)
Old 04-27-2008, 01:43 AM
claymore's Avatar
Gee that shut them up when AJ confirms the numbers.
And I know that all cars are different that's why I said:
"The correct one is the closest to 14.7 (perfect) without detonation or preignition under all conditions load or no load ALWAYS (running N/A)."
did you not understand that???
  #32 (permalink)
Old 04-27-2008, 02:49 AM
Right as of now, I run my fit with the t1r intake, t1r test pipe, t1r bpipe, t1r 50s.. and stock header. The car runs quite lean assuming a lot of power made. But do I need a fuel management? I use #87 and have no clue on AFR. But it should be pretty damn high.
  #33 (permalink)
Old 04-27-2008, 06:26 AM
ericman20's Avatar
ericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to liveericman20 relies on Rep Points to live
Yeah same question. If I run Fujita SRI/Stock Header, B-Pipe/Spoon N1 with a T1R testpipe, will I need a fuel management?
__________________
2008 Honda Fit Sport - Sold
1999 Honda Civic SiR - R.I.P
1992 Honda Civic CX - DD/Track - D16Z6-T
13.052 @ 115.97 mph
  #34 (permalink)
Old 04-28-2008, 03:05 AM
claymore's Avatar
No to both fuel management questions. You both should be fine with the parts you have installed. If you are that worried (over nothing) get your A/F ratio checked or try "reading" your spark plugs for signs of leaning out.
  #35 (permalink)
Old 09-09-2008, 03:04 AM
ericman20's Avatar
Bump.
I'm wanting an answer for this question too, I'm running
T1R Testpipe/T1R B-Pipe/Spoon N1, and soon to be with T1R Response Header.
Will we need fuel management? Will Greddy E-Manage Blue work out for tuning this setup?
__________________
13.052 @ 115.97 mph
  #36 (permalink)
Old 09-16-2008, 10:15 PM
AJ PwR Jr.'s Avatar
It is always nice to have fuel management to fine tune the setup that you have on the car. With I/H/E + TP, it is not lean enough to cause any detonation to cause any damage to your car.
__________________
#155-1991 Savage Rd
TEL: (604)279-0329
  #37 (permalink)
Old 09-17-2008, 05:28 AM
ericman20's Avatar
Thanks for the reply!
__________________
13.052 @ 115.97 mph
  #38 (permalink)
Old 11-19-2008, 12:47 AM
pepep is an unknown quantity at this point
does the af ratio in partial throttle differ from the af ratio in WOT?
why is 14 considered lean? I always thought that running lean is above 14.7. please enlighten me.
"the test pipe alone will lean it down a bit to give it some more power." - i also thought that running lean is for better fuel economy and not power.
please forgive me for my noob questions. I'm new to this topic. my mods are: T1R intake, 5zigen headers, 2inch header back exhaust w/ resonator and spoon axle back. No cat converter.
Oh and by the way, Jason was very helpful and accommodating during my purchase of the intake. he painstakingly answered all my questions. excellent service guys.
Thanks
  #39 (permalink)
Old 05-28-2009, 04:44 PM
jdmspoonfit is an unknown quantity at this point
i have the T1R response headers, T1R test-pipe, Spoon B-pipe, and Spoon N1 axle back. Will it gain some hp with the test-pipe, or as some may said it will actually lose hp.
btw what fuel management system would you recommend. please advice
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Car Falls Off Dyno!!! tonyd3773 Off Topic Discussion 0 03-30-2008 12:01 PM
HPC Dyno Day~10/27/07~South Florida Ist-sctlvrdl Car Shows, Events, and Contests 1 10-12-2007 01:33 AM
Dyno Numbers, Dyno Numbers, Dyno Numbers jits14 Fit Engine Modifications, Motor Swaps, ECU Tuning 1 01-27-2007 06:20 PM
T1R Intake DYNO #2 AJ PwR Jr. AJ-Racing.com 28 01-22-2007 08:39 PM
1987 CRX questions Shark Other Car Related Discussions 9 06-08-2005 10:16 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
