Function:
Just a note about the JDM foot lights. I really like the idea of the unit, when the door is open it will light up together with the room lights and the lights just as bright as the LED dome light. When you close the door it will get dimmer (similar to the room light fading out). The lights will light up(dim) when you have the headlights on
Installation:
The harness design is intellegent. Basically everything is plug and play. You will need to drill two holes to mount the LED light.
Here's some pics for the harness where it plugs into the fuse box.
**I removed the green plug off the fuse box and plugged into the foot light harness and there's a harness plug which plugs back to the fuse box.
**This is where the green plug which plugs in back to the harness.
**The gray plug directly plugs to the fuse box.
I will take more pics tonite and who what you guys what it looks in the car
Thanks
Ben
