View Full Version : Fit Suspension & Brake Modifications
Pages : [1] 2 3
  1. Ventilated rear drum
  2. Wanted : front driver shock.
  3. Defect rear disk conversion T1R
  4. Fastbrake rear brake??
  5. Stock Height - Negative Camber?!
  6. Underbrace install
  7. KW V2 coilovers
  8. Springs for Comfort?
  9. stock vs aftermarket - for reals? handling?
  10. Dropping
  11. Help!! driver side axle popped out.
  12. Weired noise...
  13. For those using T1R Dampers / Shocks
  14. Carbing products
  15. UK Jazz sourced rear disc conversion
  16. Lowering springs thread
  17. big brake, better pads or rear discs?
  18. Ground control coilover sleeves!!!!
  19. Where else to get panducky rear sway bar bolts?
  20. Cusco Compact Zero2 Coilover available for the Fit
  21. Brake Pedal not firm..
  22. Function & Form Coilover
  23. springs that have the biggest drop
  24. Front higher than rear?
  25. Slamming the rear?
  26. AutoPower Industries (roll bar)
  27. Break-In Period for new springs
  28. Need alignment today! I'm in Azusa
  29. Honda Fit Rear springs fit Toyota Yaris
  30. 3 Max GD3 4pt front strut!!!!!!!!
  31. Spring rate question.. low coil vs coil over
  32. AirBag Compressor Noise
  33. Brake kits for 15" wheels?
  34. Possible Stupid Question.... OEM/Aftermarket Installation
  35. Brakes Squeaking went to Honda...
  36. skunk 2 springs with 4omm off 17in rub?
  37. Cusco Zero GT Style Coilovers
  38. rear camber kit?
  39. skunk2 springs. what sz tires to run?
  40. Need opinions on what to do with T1R S-dampers
  41. D2 Racing 6 Piston Front Brake Kit
  42. Tanabe front under brace
  43. HFP Exhaust Scrapes .. Suggestions?
  44. Rear suspension replacement - same height but stiffer ride.
  45. Need smoother ride
  46. Will 11" rotors fit under 15x7 +40?
  47. Weapon-R Trunk Cage installation
  48. STock Springs.. which side?
  49. HELP! Did I just Ruin my Ride?
  50. Springs and Struts Different Brands (can it be done)
  51. ? For GE8 Cusco FSB owners
  52. fastbrakes rear disk conversion
  53. Stainless Steel lines for GE8
  54. Springs that won't lower the car
  55. New Springs on stock Struts
  56. Just installed brand new Standard Performance Coilovers
  57. Shock selection.
  58. Aftermarket Damper Question
  59. anyone make a urethane bushing kit
  60. camber, rain...
  61. Info on suspension on GE8
  62. Integra Type-R front disc brake installation
  63. Cutting springs
  64. SPC camber bolt / shim help !!
  65. probably beaten to death.
  66. tweaking caster
  67. t1r v2 or eibach sportlines?
  68. coilovers? who has them?
  69. what is the right lowering springs for me?
  70. Is front brake piston tool needed?
  71. megan coilovers install afterward...need help
  72. Ingalls Camber Kit Review
  73. springs n extras...
  74. alignment after front lower arm bar install?
  75. Can't decide, need opinions! (Skunk2 Springs vs. Tanabe DF210s)
  76. Showa Coils??!
  77. GD to GE suspension?
  78. Scratched up Seibon CF front lip
  79. Anyone heard of these guys?
  80. Strut bar mounting brackets
  81. rotors, slotted or drilled, what is better, whats the difference.
  82. Any 1 using BC coilover
  83. I have T1R dampers please help me choose which springs.
  84. Are Fit <-> Jazz brake rotors interchangeable?
  85. Noob Question Regarding Camber Bolts...
  86. WeaponR trunk cage- need help!
  87. OEM Rear Disc Conversion?
  88. Increase Rear Roll Resistance By Increasing Stiffness Of The Beam
  89. replace one rotor (not the pair)?
  90. M&M Honda REAR lower arm bar?
  91. why is the rear higher than the front?
  92. J's Racing Rear Strut Bar Review
  93. rear camber fix for lowered suspensions
  94. 03 Base Model Rotors
  95. Question about stock struts
  96. Better replacement caliper?
  97. home made rear shock tower brace
  98. To all you suspension have a question about the rear suspension of the 07-08 fit
  99. New brake pads help
  100. To all you suspension peoples, weird question. im sure the answer is simple.
  101. Springs
  102. tein super wagon coilovers
  103. what set of coilovers should i get?
  104. bored at work, so i made this
  105. T1R strut bars & c-pillar
  106. Upgraded Brake Pads?
  107. Tanabe DF210 vs GF210
  108. 4 hours of work + 2 greasy hands = 1 lowered Fit
  109. opnion on eibach sportline kit
  110. TL Brakes on a fit.
  111. ????? Skunk2 universal coilovers ?????
  112. C-Pillar Bar (Have you purcahsed from...)
  113. AMR Engineering Statement *READ*
  114. Which damper? t1r or hts?
  115. If I want to start autoX
  116. Progress sway bar hardware . . .
  117. Tokico's HP Opinion
  118. Might have to return to OEM coils
  119. springs 2009 help
  120. front under brace or front strut tower
  121. Coil Spring Spacers? Anybody
  122. Need Input on brakes
  123. 09 Springs
  124. Help! Brake problem
  125. Finally GEtting My Tanabe DF210 Installed...
  126. Nagisa Fender Braces
  127. Anyone have a price on OEM shocks and struts?
  128. Truth about Lowering springs and Oem Shocks?
  129. New rims caused rusty rotors
  130. Is my suspension ruined?
  131. Drag racing setup question
  132. spring/shock question
  133. Bumpstop - S-Tech Tein
  134. bad toe?
  135. OEM brakes gone 47k, then...finially get this done....
  136. Lowering Spring Install.... Does anyone know...
  137. Contact information for the USER ---> GIMMIE
  138. Help with Pro-Cs
  139. Help Choosing Coilovers
  140. Looking for Cusco F&R Sway Bars GE8
  141. need bolts for progress RSB.....help!!!
  142. Help with lowering springs -> Swift vs Tanabe
  143. Shaking ride after changing coilover.
  144. Install Shops in SoCal?
  145. Where to get my Springs installed in so cal... ???
  146. Knocking/rattling noise in the suspension?
  147. Replacement Calipers
  148. c-pillar bar
  149. Progress auto, stupid or not?
  150. t1r dampers/springs or new tires..?
  151. Cusco v. Tanabe front under brace...
  152. ultra racing fender brace install
  153. T1R S-damper install question
  154. warped rotors or new pads??
  155. Air bag set up Questions ---> labor
  156. k sports
  157. Eibach Pro or Swift lowering springs?
  158. Another Tanabe ?
  159. Project MU pads(pics inside)
  160. Spring Help. I don't know what I'm doing.
  161. BC coilover for 09 fit
  162. Buddy Club N+ Coilovers
  163. Tanabe gf210
  164. GE8 Lowered with Tanabe DF210 Springs
  165. Some help in MA?
  166. Camber for HONDA FIT GD3
  167. Installed GTSpec Bars Front and Rear Cage
  168. Questions on Tokico HP (blue) Shocks
  169. ADJUSTABLE coil springs (not coilovers) What?
  170. Sprint Lowering Springs??? Anyone have them installed?
  171. Brake Pad
  172. T1Rs are on finally...
  173. GD full dampers on a GE?
  174. How low ?
  175. JDM Spoon Suspension Setup Install
  176. Spring install help
  177. Turning rotors when changing pads
  178. GE front brakes on a GD?
  179. t1r dampers...or kbee coilovers
  180. Brakes clicking after install
  181. GE8 camber bolts
  182. J's roll center adjusters
  183. >>> Spring <<<
  184. ultra racing front lower brace (pics)
  185. T1R coilover help
  186. search for front lower arm bushing
  187. Negative Camber?????????
  188. Progress RSB with hitch, is it possible?
  189. Spring Perch for GE8s
  190. need some advice!
  191. Brakes from Civic Type-R EP3
  192. My Fit Sport isn't very sporty
  193. T1R coilover install?
  194. Tokico HP Shocks vs. T1R S-Spec Damper Kit
  195. I Want Bags.
  196. skunk2 pro c
  197. Any pics of sportline springs with 15"?
  198. clicking noise when turning wheel?
  199. Comfortable Setup
  200. Best Lowering Springs ?
  201. Shorter Sway Bar End Links.
  202. Ksport slammage!
  203. Alternative to Panducky bolts
  204. ultra racing 4pt lower brace..install
  205. Need help with T1RS coils
  206. Ohlins anyone
  207. Getting T1R S-Coil springs on my BOM
  208. Question about front springs
  209. Does any one know?
  210. Review: Brembo sport slotted rotors/Porterfield R4-S pads/shoes
  211. JDM Room Bar ......MY WAY
  212. SPC Camber bolts for jazz
  213. electrohydraulic shocks
  214. Urathene bushings?
  215. Specific Set Up Question
  216. Installing eibach sportlines
  217. T1r bmax coilover question
  218. gauging interest DIY legend brake caliper install.
  219. Eibach Sportlines
  220. -3 Camber Hubs
  221. looking pic of 09 FIT C pillar bar
  222. Passenger side grinding while braking?!?!
  223. Tanabe GF210 w/ Tokico HP shocks
  224. different springs on coilovers
  225. how much weight can coilovers hadle?
  226. Progress RSB worth it??
  227. used coilover (stance)...not to happy
  228. spoon sport damper & spring
  229. install my progress springs or buy some coils
  230. "Diagram" of stock struts?
  231. NEED HELP! wheel stud torqued out (GD3)
  232. Squeaking Noise in the Engine Bay
  233. New tockico's?
  234. SPC camber bolt install question.
  235. Help! ABS Light On.
  236. j's racing fcr rotors ???
  237. Who will be in for custom swift spring? (not Coil-over)
  238. Progress Auto Rear Anti-Sway bar Qs
  239. C-Pillar bars
  240. Ultra Racing chassis braces?
  241. blox vs t1r front sway bar
  242. Does anyone make adjustable front sway links?
  243. skunk2 vs t1r
  244. Help me decide...
  245. Rear shoe upgrade?
  246. Stance GR+ coilovers
  247. Question: Tanabe GF210 Springs w/ Stock Shocks
  248. ETD Vs. Mounts
  249. replacement Progress RSB bolts
  250. Rear Sway Bar Questions
  251. Creaking/popping noise coming from front wheels
  252. Skunk2 vs D2 vs Cusco
  253. spc front/rear camber kit........
  254. T1R Rear Disc Brake Conversion Problem!
  255. People with Skunk2 Pro-C's, help please.
  256. 2009 Sport with VSA!
  257. J's Racing C-Pillar Review for Fit/GD3
  258. Awful Skreeching sound from brakes
  259. Anyone with Ksport Coilovers????
  260. Torque Damper + Strut Bar question
  261. T1R Front Sway Bar for Fit/GD3 - Review
  262. Swift Coilover Springs
  263. I forgot...please tell me this is normal.
  264. Anyone rocking roll cages?
  265. Adding Springs to a 08 Fit
  266. Rotors ?!
  267. Endura-tech review!!
  268. What springs should i get?????
  269. Tein S Tech ??
  270. coilover help!!!!
  271. front AND rear sway bars together???
  272. Tein s.tech springs
  273. Setting up Skunk2 Pro-C coilovers question
  274. What is the difference...
  275. Just bought some endura-techs!
  276. Hopw many people have Endura-tech. coilover???
  277. Coilovers for 09
  278. T1R S-Spec Damper Kit - Honda Fit/Jazz 06-08 (GD3/GD4)
  279. Coilover Choice
  280. coilover spring rate
  281. Coilover Opinions
  282. AMR 8way adjustable coilovers
  283. Panducky bolts for Progress RSB
  284. Enduratechs w/ Different Springs?
  285. Beatrush suspension parts
  286. Brake Pedal Click?
  287. 2008 Factory Alignment Specs? Help!
  288. Need help installing springs, bolt wont loosen
  289. Air bags ---> Picture Thread
  290. GE8 Big Brake Kits
  291. Im in need of 1 Front Strut and 1 Rear Shock
  292. JDM coilovers vs. USDM coilovers
  293. D2 Coilovers
  294. C8 Coilovers??
  295. Front sway bar VS Rear sway bar VS Front&Rear
  296. caliper brackets ?
  297. Who's gonna be the first?
  298. Coilovers?
  299. Just installed Vogtland springs
  300. Rotors (Blanks) - OEM or aftermarket?
  301. Coilovers on Ebay - $600
  302. T1R Stainless Brake Lines: Firmer pedal?
  303. Should you install lowering springs yourself?
  304. What size brake bleeder screw?
  305. Best spring with 16s on?
  306. Suspension questions...
  307. Help!
  308. Just installed Tanabe Front Strut Bar
  309. Progress coilovers
  310. Progress Springs for the 2009 Fit
  311. k-FACTORY Aer00ver -3 camber kit
  312. Coilovers
  313. Tein basics
  314. Progress Rear AntiSway Bar for '09 Fits
  315. Spring Opinions
  316. So whats everyones opinion?
  317. helper and assist springs
  318. what shocks/struts to go with skunk2 springs?
  319. Lowering Spring for 2009 Fit sport?
  320. back brakes... help help ...plz
  321. bilstein shocks/coilovers
  322. GD3 - Do JDM sized brade pads fit USDM?
  323. ***The Official "HANDLING" Thread***
  324. Tokico HP's
  325. Rear ride height
  326. Vogtland German Fit Springs?
  327. where to buy a cusco lower arm bar?
  328. Rear camber
  329. need some advice on springs
  330. so...how lowcan i go
  331. cutting the rear bump stop??
  332. quick questions...
  333. squeaking with progress RSB
  334. Brake pad replacement question.
  335. lowering spring/camber kits/shocks
  336. F/S-Progress Rear Sway Bar-New In Box
  337. need help installing springs
  338. Spoon Strut bar Ebay find!!!
  339. installing t1r springs
  340. Custom coil-overs?
  341. Nf210
  342. spc front camber bolts
  343. GE8 point me to the springs please!
  344. Alignment Question
  345. next lowest drop from skunk2 springs?
  346. Max temp for OEM pads?
  347. popping please help!!!
  348. The Life of the Shocks...
  349. New set up in the works
  350. Eibach pro kit
  351. Is it ok to install H&R sports spring 29330-1 for GD3 Jazz/Fit
  352. Absolute Novice when it comes to almost any mod. Can someone please help me out
  353. How many miles on ur springs/ help me with my choice
  354. progress swap bar question
  355. Megan coilover installed ---> feed back
  356. WTB: Springs!!!
  357. Best/Ideal coilovers for $1000
  358. Rear disc conversion
  359. Where to buy Tein S. Tech Springs
  360. Mugen Suspention anyone seen this before?
  361. Swift Spring Install
  362. After-market pads for the Fit
  363. Springs on Ebay?
  364. Lowering car
  365. Brake Assist? is it possible to obtain?
  366. Tein Springs Help
  367. Anyone have pics with Tanabe GF210 springs with 17x7 size tire rims with 205/45tires?
  368. Wheels+ springs question
  369. has anybody use ground control coilover
  370. Skunk2 spring noise help!
  371. Endlink noise
  372. am i going to rub?
  373. What Springs Have The Lowest Drop???
  374. Anyone Know When 09 Springs Will Be Available?
  375. Will the 09 USDM shocks fit on older fits?
  376. ultra racing braces w/ prices 10% OFF
  377. Brakes issue
  378. Most Comfortable Springs?
  379. diameter of coilover struts
  380. Stiffer but not THAT low ;)
  381. Tokico HP struts/shocks on ebay
  382. how hard is it to install coilovers on the fit
  383. Ksport coilovers????
  384. T1R B52 CO vs Skunk2 Pro-C CO
  385. ebay polished front strut bar pics
  386. Pic Request: SSM Sport Dropped on Springs with Stock Wheels
  387. Tanabe GF210 vs Eibach Pro-Kit
  388. raising the strut tower mounts
  389. how do i get the rear springs out?
  390. Pulling 1.0 g
  391. Skunk2 full coilovers
  392. T1R B52 Damper vs Mugen 5way Kit
  393. 2008 & 2007 Fit springs...
  394. looking to buy springs, question: what type and where from
  395. Tokico D-Spec Shocks?
  396. Sorry guyz but I too am a newbee and need your expertese...
  397. nEED help installing Megan coilovers
  398. Getting hassled over my lowering springs re: car inspection
  399. Eibach Pro Kit
  400. Leak Around the Rear Shock. Inside Car
  401. Firm up suspension while maintaining stock ride height?
  402. oh man!!! soooooo sexy!!!!
  403. Blox Front Sway Bar CHEAP!!!!
  404. Torque Settings For Struts
  405. Front wheel hub dustcap?
  406. what do the J's Racing Roll Center Adjusters do?
  407. 5 Lug conversion
  408. Progress Springs
  409. Progress Rear Sway Bar Install ??
  410. Springs which ones better?
  411. Megan Street Coilovers
  412. Smallest Drop
  413. Vibration after install...
  414. rotora slotted rotors
  415. JDM Damper/Strut Compatible with USDM?
  416. 17x7's with +45 offset with 205/40/17's what springs to get?
  417. KYB Suspension
  418. Torque for suspension
  419. Low profile sway bar bolts?
  420. Tanabe GF210 on stock Rims
  421. Cutting springs?
  422. Coilovers (lowest)
  423. mugen sport suspension
  424. QUESTION: Front & Rear Anti-Sway Bar
  425. EP3 rear disc conversion...
  426. t1r springs are making noise!!
  427. Suspension squeeks/noise
  428. T1R coilovers with front sway bar Problem !!
  429. Can someone help me???
  430. Do JDM front lower arm bars fit USDM fits?
  431. SUGGESTION: i want to lower my Springs just a little bit...
  432. Starting a Lowering Springs Pic Thread.
  433. Ground control
  434. underbrace
  435. a ton of questions??
  436. Front Sway Bar
  437. alignment after springs?
  438. Springs for the 09's... how long?
  439. X3E Brake Pads: Long Term Review
  440. Does anyone have the Buddy Club N+ Spec Coilovers on their Fit?
  441. Does anyone have the KW Variant 2 Coilovers on their Fit?
  442. oneven lowering?
  443. debating on springs
  444. Brake Color
  445. Back to Stock
  446. Front end clearance
  447. Bouncy Ride....Help Fix
  448. *Personal* Eibach Review!
  449. another great chassis brace find!!!
  450. How to pop the front axle in...?
  451. 20,000 miles + springs?
  452. miracle x bars by next
  453. allover suspension
  454. Warranty issues......
  455. Koni Yellow Ground control and Springs
  456. Koni Yellow Ground control and Springs
  457. coilovers: Need help, pictures added
  458. ultra racing chassis bracing
  459. Eibach Pro kit and more to come
  460. Should I Lower My Fit w. Pics//
  461. Cusco Rear STB Installed w. Pics...
  462. Tanabe Gf210 Vs Skunk 2 Springs
  463. TEIN Super Compact / Basic Compact
  464. lowering my dd
  465. Painting The Drums/Rotors and some other 'stuff'
  466. Help! Uneven spring compression. Tire scrape
  467. putting front sway and rear sway?
  468. swift spring of tanabe gf210?
  469. so i've gone too low....
  470. rotors / pads
  471. T1R 2.0 Lowering Springs Vs. Eibach Progressive Springs
  472. skunk 2 springs
  473. bumping/thunk sound in rear
  474. Pop noise in suspension
  475. Tanabe + Panducky = FTW
  476. mechanic's gloves... kinda off topic.
  477. Tein High Tech Springs???
  478. best coilovers for the money
  479. Cusco 26-way adjustable coilover
  480. Adjustable Dampers
  481. Mugen suspension
  482. Nex SS Coilovers
  483. lowered and rubbing...what to do
  484. looking at skunks
  485. Megan Street Series Coilover Damper Kit
  486. stupid question: Coil over vs just Spring
  487. will it fit?
  488. Eibach Sportlines
  489. skunk spring installed
  490. quick question
  491. just lowered...wierd noise now
  492. Are Tein Basic Dampers good for Street/Daily Driving?
  493. New Progress Auto Rear Anti-Sway Bar
  494. Skunk2 Pro C vs. Pro S Tech Video
  495. Pics of rear underside?
  496. Spring choice for Northeast
  497. cusco type2 front under car brace
  498. Stance coilovers
  499. Maximum Compression of Stock Suspension
  500. yay! got my progress rsb in the mail
