View Full Version : 3rd Generation (2015+)
Pages :
1]
- Replace spark plugs AND coils at the same time?
- 2015 Rear Toe Alignment Shims
- Fron wheel stud replacement
- New (to me) 2015 Honda Fit EX
- Vibration noise near oil drain plug - some kind of bracket
- Engine Idle Rattle - Anyone Have This?
- If you ever forget to reconnect the GK Fit's MAF Sensor
- Looking for thule fit kit 1751 or alternatives
- Help with parts ID please? Evap canister tube to the great unknown
- Display screen going blank
- Help with front license plate attachment
- Tire recommendations for LX Fit? 186/60R15
- Help figuring out what's what, please?
- 19 FIT LX Radio / Headunit questions
- Android Auto, no longer working. 2018 sport
- Is this okay to drive
- Intermittent Dash Messages - Expensive Camera Replacement Needed?
- hatch leak fixed
- P0420 (and now) P219A in '16 Fit.
- Whopsie over curve, drove ine, now wont mov
- SOLVED: Water leak in trunk and drivers foot area
- 15810-5R0-003 Valve Assembly, Spool
- Chasing water leaks on a '17 Fit
- Rear wiper motor
- All service lights carbon buildup injector issue very frustrated help
- GP5 Honda Fit Aftermarket Headunit require canbus for steering wheel button control?
- 2015 LX MT: What to expect at 75k?
- 2015 Fit - Consistent groan from top of engine?
- LED Conversion
- Identify rat eaten hose
- 2015 Fit - Rough Idle + Engine Ticking + Scraping Noise
- Leak into drivers foot well from hood latch release cable
- Eibach Pro Kit availability?
- What Muffler Are You Running With.
- Turn Signal Light in Side Mirrors?
- New member.
- Desperately trying to get to the bottom of some drivability issues on a Fit I bought.
- Is this a good deal?
- Broken front panel close to the radiator
- Replacing Center Console Question
- Any variations of 2018-2020 models?
- Check Charge System Warning
- Looking for 2018+ Honda Fit Sport Parts
- 2015 CVT stuttering when accelerating from stop or slow speed
- Keyless start sustem problem - engine won’t turn off
- Who's Your Starter?
- Frost! 2020 Honda Fit LX
- 2016 CVT Car Will Not Move
- Eight Snow Tires
- Rusty Brake Drums
- DIY Windshield Washer Fluid
- 2020- what should I know?
- Air Bag Recall
- Weird Starter Relay Noise / No Start
- Do Japan made 2018-2020 Fits exist in the US?
- Cup Holder Solutions for 3rd Generation Honda Fit EX?
- 2018 sport -- 30,000 mile service
- Seat belt buckle receptacle fell apart
- My Honda Fit journey - Please give your comments
- Right turn camera always on
- 2017 Fit sync key
- Replacement Volume Knob for 2019 Sport
- Manual transmission upgrade
- Looking for the JDM clear headlight reflectors
- Soft or just worn engine mounts (manual car)
- 2015 Honda Fit Ex Just Purchased
- 2019 Steering Click/Clunk on the left.
- Noise just prior to start up.
- Michelin X-Ice
- Rear hatch going crazy
- Gas mileage suddenly went up?
- 2018-2019 Fuel Pump recall
- Car randomly loses acceleration
- Water in the spare tire wheel well, coming from underneath?
- Flashing transmission indicator after transmission swap
- Honda Fit 2015 trim
- Adding a temp gauge, (feasibility)
- Hey Tuners
- Chrome delete - but with colors: trashy or no?
- Honda Jazz rear emblem location
- 2019 Honda Fit Rust bubble
- 4 maintenance light on dash came on
- Class Action Lawsuit ??
- Is there a way to permanently change instrument cluster language from Japanese to Eng
- What is this plastic strip on the door sill of my JDM Fit?
- Redesigned Fit
- VTC, Timing Chain, Guides oh my!
- 2015 Fit System Inficators
- 2Bad starters-Both had bad ring gears on the 2015 Fit models.
- Water finding a way inside my Fit
- Yellow Xenon h4 question
- Honda Recall Over Fuel Pumps
- Is a 2.25" catback from Unequal Fabrication too big for a stock motor?
- Trying something new
- I miss my 2nd and 3rd Gen
- Purge solenoid question
- 2019 Fit Click
- Rear brakes
- Spaek plug replacment
- Getting ready to swap out headunit in my EX '20 -- Some questions
- 2017 Fit - 85k miles - lots of repairs needed, is something wrong here?
- 2018 Replacement side mirror glass?
- Aftermarket headlight bulb recommendations
- Trying to mod my 2017 EX into a (street legal)sleeper
- From 2015 to 2018 in a Bang!
- GK5 SPORT bumpers ?!?!
- Reputable dealers/mechanics to do maintenance in the Seattle, WA area?
- Changing Out OEM Foglights, 2018 GK5
- Broken wire near A/C pressure sensor
- Water found in spare wheel well area
- Weird 2016 honda fit starting problem
- Can I upgrade a 2018 EX head to a 2019 EX head unit?
- Seat Covers
- Battery won't charge, weird woodpecker noises coming from fuse box and power relay
- Wanting a Performance exhaust but not too loud
- Konig wheels offsets compared to stock offset w/ 205 50 16 tires??
- Rebuild/repair 2017 Fit alternator?
- Remove FogLight Cover Fit RS
- 2019 Oil Change Time Frame
- momentary rattle sound
- What hardware do I need for the inner fender assembly?
- Coolant question
- 2015 fuel injector failure
- 2016 FIT Rear Shocks Replaced/ Still Clanking
- NZ gk5 owners I got some parts I need to swap and sell so I can trade up
- Is this much motor movement an issue?
- Car won’t turn over after battery change
- Head Unit Full Pinout
- Alternator/ELD questions for 2015 Ex CVT Fit
- Opinions
- Honda fit running very poorly on acceleration
- Cruise control and throttle response
- Key Fob Issue
- 2015 limp mode - p0341 - runs perfect
- 2015 Honda Fit EX - 4 lights on dash - help!
- "Brake!
- 2016 w/CVT- where's my gas going?!
- How many emus can you get into a Honda Fit?
- What's underneath the plastic floor plan cladding?
- Push start 2015 clicks once no start
- Wheel Alignment?
- Can't Drive, it won't shift into Drive anymore
- Need help identifying return line of CVT cooler
- How do you know you need valve adjustment?
- Dead USB Ports
- Honda Fit 2020 - Footwell LEDs wired to dome light
- Aftermarket Fog light Turn signal front & back, help
- Sore Right Knee?
- Windshield Wipers - Different!
- Click, no crank, slow cranking....
- Replacement radio problems
- Weird noise turning engine ON & OFF
- Replacing the stock Aluminum Wheels on a 2015 GK
- 2019 Honda Fit - Factory Wipers?
- Honda Fit 2019 Replacement Battery
- Wallpaper image stopped displaying
- Reverse to Drive delay?
- 2015 Honda Fit 98k miles
- Please delete
- Door check straps
- Parking Break Cable?
- Is car considered level on 4 jack stands - Transmission fluid check
- Battery drain/dead after starter replacement?
- Ecu wiring diagram
- Door locks activating by themselves
- Need wire locations for wiring aftermarket remote starter on 3rd gen Fit
- 2015 Fit ex manual timing valves both neither?
- While CVT is out - should I do rear main seal?
- What was the 3rd gen refresh change?
- 2019 honda fit EX warning lights
- Honda fit 3rd Gen cluster meter pin layout.
- Starts then immediately dies
- 2018 EX water leak issue
- Tail light assembly (right side/passenger)
- Temperature Control Dial Jammed (HVAC Blend Flap)
- Replaced Driver's mirror, now no HVAC fan, AC or mirror adjustment...
- Rattler
- Rattler
- Key Fob, flashing lights, and unlocking
- How much data does a 2019 Fit LX collect?
- 2019 Honda Fit holes under drivers side floor mat
- rustydude
- Use OEM microphone on aftermarket radio
- Oil Filter
- 1.3L 2018 Honda Fit - Japanse to English language
- 16" Full Size Spare, Valve Side Up - A Workaround
- Starter issue
- Starting Problem
- Pneumatic Hood Supports
- 97 psi
- Ticking noise when in drive 2019 60k miles
- LCD, USB stopped working.
- Oxygen sensor brands
- 7 warning light issue and my resolution
- Honda Canada Warranty Extension
- Honda fit sport rust proofing damage
- P0172 code (too rich fuel), Youtube vid on 2018 Honda Fit
- Saying bye bye to my blue 2015 Ex CVT
- The Red Stripe
- Disable Anti-thief System
- High pressure fuel pump
- Modify underbody panel for easier Oil Change? Fumoto valve?
- What do I need to install a hitch for a very long move in a 2015 Fit (Manual)
- Rear Brake Replacement - Mileage
- Leaking!
- Help Identifying This License Plate/ Bracket Theft Prevention Combo?
- sport ecu plus pedal boss??
- Key Warning Light and Starter Button
- Expected life of the Fit?
- Zero to Hero, Auction Honda Fit
- A/C evaporator removal
- Radio Code 2020 3rd Gen Fit?
- Dealership recommending fuel injection cleaning/transmission fluid change
- Rear Windshield Defogger Not Disengaging
- Dealership Maintenance Recommendations Question?
- Selling my 2016 EX (NY area) and saying goodbye
- Creaking sound in rear of 2018 Fit Sport
- 2015 EX - battery issue? worse?
- 3rd Gen Evaporator Core Replacement
- EGR Tips
- Best tires for rain/snow/ice?
- Steering Wheel Lock
- Passenger mirror
- Best Phone Mount
- Best Sunshade 2019 Fit
- Clutch Pedal Theories?
- playing music with iphone attached to charge chord-no music sound
- Changing key fob battery renders fob totally inoperable
- E85 with stock tune/fuel system
- anyone have pics of your fit with non stock size tires
- 2023 Honda Fit
- Death Wobble!?!? Is My Rack Smoked? Videos Attached.
- Help needed !!!! No lights
- Largest roof box to reasonably use with the Fit?
- No Rust on 3rd gens?
- AC Compressor Clutch Relay Honda Fit 2017
- New here, got some fit issues.
- Warning lights on, cylinder 4 misfire code
- Interchangeable Parts
- Camera for reversing
- Wheel mod for suspension improvement
- XM vs Radio. Radio is Winning
- RS spoilers on aliexpress
- Fuses to tap for dash cam?
- Trunk Hatch Wont Open, No Click
- Optional Front Grill.
- Manual driving "manual" & tips (2019 sport)
- Driver side airbag curtain rattle over bumps
- how i cleaned my center console arm rest.
- Class Action Lawsuit for Honda Fit Battery issues
- Coolant Light
- GK5 tail lights
- 2020 Fit Sport weird squealing noise when in drive and AC compressor on
- deflation warning system
- Serious Manual Transmission Problem
- Manual Swap on GK5
- Whining manual transmission?
- After market rearview camera
- Replacing PCV valve tips?
- Performance mods?
- Dry Clutch for GP5
- 2020 Fit directly drop in swap problems
- Radio Screen and Backup Camera Resolution Crashed
- New Shoes on GK5, 2018 6M Sport
- Dead Battery
- GK5 tail light wiring question
- 2017 injectors need replacing
- PCV valve
- Transmission compatibility
- Radiator hose & cooling system bleeding
- clutch slave bleeding
- Looking to get a GK Fit soon. Any tips?
- Rattling sound from the resonator
- New here. Learned a bit cleaning intake valves and replacing fuel injectors
- Feeling: 2 months before saying good bye to my 2015 Ex
- P0420 and exhaust leak.. anyone have this happen?
- Ran 3000 kms with just over a litre short of oil
- AUX input jack from 2017 LX to a 2018-20 LX
- Engine noises, looking for help
- past 60,000 but no maintenance minder code
- Anyone know where I can find the Morimoto headlights for the 3rd Gen Fit?
- Tighten fuel cap.
- Looking for a spare keyless entry fob
- Mysterious Whining Noise When Backing Up
- WTB OEM EX or Sport wheels
- My first Fit and just learning how fun it is! Any tips?
- 2017 Fit A/C intermittent
- 2016 LX alternator won’t come off
- Occasionally takes a second key turn to start engine. Suggestions about cause?
- Relays clicking/Something on engine bay when key is off. Dash lights/interior lights
- What part # is this?
- Battery lifespan
- Remove "Chrom"-Rings on Foglight
- Safety Recall, Display Audio unit, low power
- Replacement Tire Recommendations Requested
- Lights galore
- Trading In Fit
- Anyone have experience replacing a cracked 2020 Fit EX Head Unit?
- Engine Air Filter and MPG Improvement
- GP 6 L15 engine type ID
- New Brake Pads
- GK Smart Entry System Indicator light
- Bought JDM late 2013 fit (3rd gen) Weird fisheye effect on reverse camera?
- Lifting
- GK 5 Rear wheel hub assembly bolts / brakes conversion questions
- Driver's door lock / Smart Entry problem
- 2020 Fit - Differences
- Wiper Washer Nozzle Replacement
- Cv shaft replacement
- 2020 Fit EX MPG
- Keyless entry system issue
- Those with higher mileage, how’s it going?
- Purchased a Used 2020 Sport trim (CVT trans) with 29k miles
- Just picked up this gently-used 2015 Fit EX as a base for a new racecar!
- Engine Replacement
- battery sleeve
- Very quiet whirring noise in neutral? Normal? Or Input shaft bearing?
- Hi, Oxygen Sensors
- Squeal/scrape/grinding
- Power without a tune
- Load Squeaking sound when Hill assist releases.
- Starting problems
- What is this in the picture?
- Part of electric dash goes blank
- Bad maf sensor at 115k
- 2106 started in zero degree F weather
- Stock stereo problems
- Head unit cables
- Electrical Problems
- Discovered passenger side rear door damage?
- 2015+ Front Plate
- Thoughts? <LED light upgrades>
- buzzing noise under dash with ACC on, keyless system
- ISO Non Lowered Stiffer Suspension Options
- 2015 push start won't start first attempt.
- CTV fluids and part number reference
- Oil leak
- Honda car parts stockist/dealer in Portland Oregon
- Air bag replacement
- Another Oil Change
- Spark Plugs - How often do you change them?
- hrv to gk cluster swap
- bilstein shocks and struts
- Does anyone else "skip-shift" their manual trans?
- GK Recall on BU Camera for Key Ignition VEhicles
- Battery upgrade fixes VTC start rattle?
- suspension issues maybe? Shocks? I'm no sure...
- Carpet removal for some rhino liner
- 14 Inch Wheels On GK5
- P219A for '18 with 55k miles
- Windshield Wipers Falling Off
- Plastic Piece Dangling from Undercarriage
- Help with p0420
- GK5 2015 2016 Honda Fit ECU Location
- 2017 Honda Fit underbody panels
- Valve Adjustment. Please Suggest.
- Multiple problem lights after being parked
- VSA light
- Maintenance Minder Code "3" for Transmission Fluid Two Times in a Row?
- CVT fluid change- some information
- 2015 Honda Fit VSA, TPMS, EPS Check Charge Lights
- Has anyone had CVT issues or breakdowns?
- CVT fluid change
- Timing Chain Replacement 15 ex-l
- Fuel Injector Warranty
- Fuelly - How To?
- Electrical problems on a 2016 fit?
- Do I stay or do I go... Timing chain/fuel injectors
- 2018 EX, plastic shield under engine fell off— should I replace it?
- Help finding '18-20 fit sport radio
- How to fill in spare tire space?
- Rear wiper - changing the resting position
- Hatch and rear passenger door locks unusual issue
- Help: 2015 Fit EX-L infotainment connectors?
- Tomioka Racing batteries
- How to install rear (back up) camea to 3rd gen Honda JAZZ/FIT (GK5) car
- Center Console Latch Spring Measurements
- Sunvisor Solution???
- Rear pillar led lights install + wiring
- 2019 no heat, but knob turns.
- 2015 bad 25 MPG Help!
- 2019 Fit Shift Boot Sagging, Retention Ring Missing
- Car not starting, electrical weirdness. (2015 LX)
- Honda Fit 2019 - help to identify this part.
- Honda Mk3 Keyless entry No lights, Will not start, Remote will not open doors
- 2018 only blows cold
- Oil Filter
- 2019 Fit Horn not working. Fuse okay. Relay location?
- GK HPD support?
- Undercarriage Shield Issue
- Manual trans drain plug
- Better cornering and handling mods?
- P0172 code after PCM replacement
- P0843 flashing D
- Help me explain how to get my 2016 started to a non-Honda person
- Replacing A-Pillar clips
- Air bag deactivate
- How many different styles of OEM GK5 taillights exist?
- GK5 Brake Light on hatch
- Honda GP6 Error P287C
- Dead battery then bad jump then no radio.
- Coolant Leak followed by Starter Problems
- Oil leaking from harmonic balancer side, can't find source
- Incompatible with android?
- questions about headlights
- Fit 2014 transmission fluid
- Buzz Sound
- is this excessive engine movement? the mounts look fine
- Wiring schematic
- Fuel mystery
- New stereo that works with right mirror cam (EX manual)
- Dash trim discoloration. Removal?
- Fixing the display menu
- Recommend A Place To Get The Instrument Cluster Repaired
- Anyone buy tires lately?
- 2016 CVT Valve Body Solenoid B...
- Will a 30" stove fit in a 2015 Fit?
- Accessing the top of the rear shocks?
- Driver/ Passenger Side Mirror Adjusting the Mirror Bracket Position Forward Daily?
- Hissing noise only when on the freeway
- KC screen on radio?!
- 2016 CVT fluid change...reset the Maintenance Reminder?
- How to install new speakers?
- No start. Key stuck. No display on tranny gear (cvt)
- Honda fit gp5 2018 foglight fitting
- Air Conditioner cables stuck
- Seeking an unusual measurement!
- AC Compressor Clutch Not Engaging
- 2015 EX Moonroof issue
- B-Pillar Vinyl Kit
- Opinion on valve adjustment
- Push button issues with 2015 Honda Fit
- Intake Valve Cleaning - Forget the Walnut Blast
- Amazing Coincidence
- 2016 CVT with PO741 code
- Ex break in from emergency key hole
- 4 Liters of Coolant not enough on my fit?
- Fuel Injector Recall.
- CVT Help desperately needed
- Black Sport Wheels On My EX.
- Hatchback won't open on 2015 honda fit
- PIAA Xtreme White Light Bulbs.
- How to disassemble front headrest
- Rear shocks - 2015 MY vs 2017+ MYs
- Issue with Defogging System
- Getting rid of dead skin on door panel
- 51 Battery Install
- Has anyone ever taken their Honda Fit 2015 ex on a road trip?
- 2015 Honda Jazz 1.2
- Replace rear hatch handle
- Radio control on steering wheel rubbing off....
- Manual Transmission hard to shift sometimes
- Blind spot accessory mirrors and placement, sideview
- Leaking air at highway speeds only
- Morimoto 4banger LED fog lights
- Clicking noise when Idling
- 2019 EX with P0303 code and now dead battery
- Replacing Timing chain, VTC act., etc.
- Platinum White vs Orchid white
- 250amp alternator upgrade, 2019 honda fit ex, advice please
- coil-overs vs Spoon progressive springs for Gk5 Lx
- Has anyone ever tackled replacing a 2015!AC compressor assembly ?
- Sudden iPhone Music Plays on 2018 EX-L
- Car audio electronic updrade
- 195/60r15 on a stock 175/65r15?
- 23mpg. Is it normal?
- Wheel Question from a novice
- Mirroring Android Phone with Infocenter
- ABS code U0401-68
- Wheel and Tire Size for Stock Height GK5?
- any info on these codes...
- Fuse Pulling 2017 Fit flat towing
- 2015 light issues
- Lost my key
- My Honda Fit is Haunted! Help!!!
- Fuel Injector issues - 2018 Fit EX @ 17,000miles
- Immobilizer kill switch?
- New Rims & Tires
- why won't my 2017 start when I push the "ignition" button
- I Solved My XM Radio Addiction Dilema.
- Mattress for refresh mode?
- 2016 Fit with black radio screen
- Do winter/snow tires makes sense of Fits?
- fuel pump recall
- 2016 LX Grinding Noise on Start?
- Is Your Fit Turning Into A Money Pit?
- feathering on rear tires
- Charging system message is coming after replacing battery
- At my wit's end with starting issue. 2015 LX MT
- How can I disable all doors unlocking when opening the driver's door from the inside?
- VSA Module Replacement
- 2019 honda fit dash lights
- Impact sensor 2019 honda fit
- Aftermarket radio installation,… But what about.
