- 2017 Fit LX Carplay/Android Auto upgrade
- 2018 EX Head unit swap
- Need 2015 and 2018 Fit radio harness connectors A, B and C pinouts
- Audio upgrade version 3
- 2018+ Harness
- GK5 Bass restoration
- Amplifier mounting location?
- 2009 sport subwoofer discussion.
- DIY sub enclosure
- issues with the radio
- Added a Class D amp to my 2016 FIT
- Steering Wheel Controls and Lanewatch Adapters '16 GK5
- New Android Phone Bizarre Behavior
- GPS Tracker?
- YAC Car Phone Holder + wireless charging?
- Stereo and fob issues
- Replace stock head unit with OEM upgrade
- Android Auto Night/Dark Mode?
- 2016 Fit EX speaker upgrade
- Sony Android Auto: Retain Right Camera?
- Change clock with aftermarket head unit?
- LaneWatch on a Aftermarket Stereo
- Infotainment pinout
- GK: USB Flash Drive File/Folder Limitations using Auxiliary Port
- Adding a power outlet to trunk.
- Carplay Needs Monthly Reset
- Alternator ECU Bypass Charging System / Battery Sensor
- 2017 LX Audio shuts off
- LX Radio Swap to Sport Radio?
- Wiring your backup / rear view / reverse camera to a switch
- Radio Replaced
- 2015 Fit - Entertainment unit software upgrade?
- Yes, The Radio Is Bad
- 2018+ Display Audio Steering Wheel controls -- get to mpg screen
- Steering Wheel Controls/Adapters '16 GK5
- Adding "Walk Away Mode" to 2016 EX
- After market stereo for 2017 Fit
- Wi-fi Connetion to 2018
- Wireless CarPlay - Factory Head Unit
- Aftermarket stereo / Sirius antenna adapter
- Has anyone figure it out to add a cd player to Honda Fit 2018
- Keep Steering wheel controls, and Lane Watch, Backup Camera on aftermarket HU.
- Sirius XM Radio Won't Refresh
- 2016 to 2019 Audio/Nav unit swap?
- 2015 Fit EX - iPhone and Song/Artist Display
- USB Music
- USB Port Troubles
- Car can't find my iPhone over bluetooth
- Always on (constant) fuse?
- No audio from Google Map while Android is connected to Bluetooth
- The Factory Headunit Audio Upgrade
- Audio system and new iPhone
- ew low/mid system build advice/C & C -- 2018 Sport
- Pinout for 2017 US LX B connector
- Aftermarket for 2017 AU model
- Sony XM-S400D Power
- USB and Popping Sound
- Turn lane camera on 2018 Fit Sport
- Fuse position 41 or 42 powered?
- Head unit Wiring Diagram
- 8mm bolt in bottom of head unit?
- 2019 Fit Sport. Speakers Upgrade
- Sony head unit installed on 2018 Honda Jazz
- '17 EX-L Navi USB Issue...
- Amp mounting location
- Aftermarket Head Unit: Fisheye Backup Camera
- Problem with stock head unit 2015 EX
- 2018 Fit EX-L diagnostic mode?
- Radio on, Volume up, No speaker sound
- Length of HDMI cable?
- Adding SiriusXM: GSR-HD01 Install
- 18/19 Fit aftermarket stereo (double din)?
- 2018 OEM Headunit Wiring diagram
- Wiring Amp and Subwoofer Questions
- XM Radio Keypad ??
- USB Adapter Cable For . . . ?
- Crackling/Distortion at Volume above 28 w/ new subwoofer
- USB Stick and Tunes
- Remote Start install-
- table of all honda HUs?
- iroot on Display Audio, installing other apps
- Lighting Under Dash and Near Cupholders
- 2018 specific GK attempt in adding amp.. DENIED!
- Remote Turn On
- Stock Tweeters / Upgraded Door Speakers
- Swapping stock tweeters on 2015 Fit
- Blutooth: No "Playlists" showing on car's screen
- Sound Processor for Stock Radio
- Orronoco Audio DIY - 2015 Honda Jazz
- Replace Head Unit-What's Being Lost?
- Speaker Upgrade to Improve Sound?
- Wireless Android Auto --Kenwood Excelon DMX905s
- Axxess ASWC-01
- Easy Subwoofer Addition To Stock Audio System
- Upgrade factory speakers with factory HU, more bass in mind
- Gk fit stock dash tweeter rattling sound
- 2018 Add an Amp wiring harness
- 2015 Fit EX, possible EX-navi swap ?
- Sirius Xm radio
- Gen 3 Horn Upgrade.
- 2018 Fit. Discreet place in back to cut in a line out converter?
- Alpine w505e
- Retro fitting 2018 CarPlay Stereo in 2017 Model
- Apple CarPlay Experience - 2018 Owners
- Similar LED headlamps, LEDs imitate halogen filaments
- USB phone connector ... in console compartment?
- Will a 2018 head unit work in a 2015 model?
- Bluetooth Transmitter Add on
- Sub enclosures
- Handbrake signal OFF DIY !!!!
- Vendor Says It Doesn't Fit! I say... "I think it can!"
- Upgraded '16 LX head unit to Sony aftermarket
- Immobilizer bypass for remote start option?
- Backup camera adapter: BeatSonic BC29 - any idea if this works?
- Defrosting Small Windows in Front
- Instrument Cluster Color
- HDMI Input
- Sony XAV-AX100 Android Auto
- Install 2 way coaxial in front door - what about crossover?
- Hondalink Navigation NA File request
- Subwoofer install - Anyone have under the seat dimensions?
- Possible to replace factory tweeters with aftermarket?
- ideas for upgrading speakers
- 2016 Fit LX (Canada) with touchscreen: Rearview camera connection
- 2015 EX Stock Radio/CD Issue.
- Come on, Honda - if Kia can retro-update to CarPlay, why can't you?
- New Radio for My Honda Fit 2015
- Bypass steereng control
- NVX / JBL audio system install
- Photos of under hood breaker mounting
- Weird Issue With Display Screen
- Fit Jazz 2016 RADIO FROM EX IN LX
- Photodon Protection film for head unit
- 2015 Fit vs 2015 Civic Stereo wiring
- Backup camera as rear view
- Honda fit vs Civic.. Infotainment? And stuff [2016]
- Red light blinking from gauge cluster when doors locked
- So Cal place or person for audio work
- audio constantly defaulting to source screen
- Podcasts not recognized
- 2016 LX radio wallpaper
- '16 LX iPod issue
- A possible way to get around OEM radio limitations?
- Blue tooth not working
- USB Flash Drive - MP3 viewing order problem?
- Radio wiring problem
- Question on speaker install, front doors - use old ones as mounting brackets?
- 2016 EX touchscreen radio is sloooowwww
- EX Tweeter high pass filter location?
- 2016 Fit EX - Upgrade Speakers and Add Sub
- Mirrorlink device
- Anyone installed aftermarket navi dvd player for 2015 Honda fit?
- 2016 - poor AM radio
- Harman JBL Legend CP100 Head Unit - Another CarPlay & AA Option
- Portable XM receiver hooked up in Fit EX
- How does Sirius radio sound through the LX aux port?
- Android Auto, MirrorLink and Apple Carplay support
- Mirrorlink and google maps
- New Owner! Love it, but confused: Apple CarPlay
- Bay area free custom 10in subwoofer box
- 2016 Fit's Radio
- Ready to test/starter "beeps"
- Grounding at Center Console
- Infotainment rebooting
- Which Positive Battery Contact Can I Use
- No Aux... So what bluetooth transmitter are you using?
- Idea for Google Maps on stock HU
- is there a direct connect yet for an added xm radio?
- Replacement internal speakers for EX
- OEM HU/Kenwood KSC-SW11 Sub installation
- Messaging and iPhone
- Replacement Dash Tweeters
- Anyone Using the Nav App?
- Polk db 651 Speakers
- iOS Cable Cost/Usefulness?
- Putting 1200 rms system in fit. Will it be ok?
- Upgrade of speaker system with OEM HU
- Subwoofer system.
- Prototype HDMI Enable Hardware Works!
- Complete high end system install
- Radio froze - 2015 EX
- Stock Battery enough for an Upgraded car audio
- OEM cameras with new HU?
- Tips for Working on the Interior
- Custom playlists on USB stick?
- Installing Polk DB651 Speakers
- Mounting depth/height for woofers
- So it looks like the new 2016 model does not have Android Auto or Carplay
- HondaLink for Dummies
- Audio upgrades for fit?
- Pioneer Avic 8100nex install
- Intel Compute Stick in HDMI
- It runs Doom!
- Bluetooth Audio issue and workaround
- Best Approach to no-amp Audio Upgrade
- Adding Phone Feature to Fit-LX?
- amp and sub for EX question
- Android Auto - Tweet
- Music, USB Drives, and exFAT
- cheap floor lights
- Upgraded the front speakers
- Bluetooth Audio Group feature
- Hands free doesn't recognize stored phone #s bluetooth
- Any Galaxy S5 Owners?
- Dashboard Camera Recommendations?
- 2015 Fit EX-L. Any way to install Navigation yourself and save money?
- clock resetting issue
- Lusting after Pioneer 8100NEX Headunit, ???s
- Anyone making a radio cover?
- Adding tweeters to LX
- ApplePlay?
- remote control of fit
- Making LX into a 6-speaker car?
- USB issues with iPhone
- Voice recognition no longer works with iOS 8.3
- Will MP3 in CD Format Play in the Fit?
- Windows Phone on the 2015 FIT?
- Removing the stereo and video screen from the 2015 FIT
- Android Auto Doesn't Work
- Change iPod display options?
- 2015 Fit EX with an HTC One M8
- Andriod phone WORKS with in car system
- Android Auto and MirrorLink
- Firmware Update?
- Voice Recognition System Volume
- 2015 Fit/Full screen Wallpaper
- Anyone see this head unit?
- Onyx Plus Pics
- Infotainment Software / CarPlay
- USB folder/file size limits on 2015 fits
- Is a Second Amp Fuse at at the Amp Okay?
- No splicing factory wires installation of amplifier and speakers
- How annoying is the lack of volume and tuning knobs on the 2015 Fit?
- Speaker and AMP install help
- Where to buy? Nav Headunit
- XM Radio poor sound quaility?
- Where to put a GPS?
- LX Rear Speakers Poor Volume/No Bass Caused by??
- Some Hope For Android Users
- 2015 honda fit ex l oem navigation into a ex
- 3.5 Audio Aux convertor for Fit EX
- Radio Harness Pin Layout
- Satellite radio
- EX/Navi Stereo - issue with "view track text" common?
- Hondalink and Iphone Dont Connect
- amp under passenger front seat
- Is HondaLink spyware?
- Warning Statement on LCD Screen
- Replacing factory speakers & add amp
- Instrument Panel Clock with Aftermarket Unit
- Third party installers in the SF bay area.
- Door panel/speakers
- Phone not compatible, maybe
- After Market Head unit ???
- Improving Stock Audio Fullness
- Non-Invasive/Destructive Amp Power Run?
- Signal Processor Reviews
- Radio Unit SD Card
- iPod Classic - turn repeat or shuffle off
- Sirius XM Fit EX NAvi Owners help Wanted!
- aftermarket heated seats or seat covers
- Good sub for the 2015 EXL
- A great article on Infotainment (Carply/Android Auto)
- XM Options
- HDMI while driving?!
- Navigation Traffic Issues
- Stereo Quit Working!!!
- Ios 8
- LX radio display issue (5" inch)
- iPhone mount
- LX - fast-forward/rewind music track?
- HandsFreeLink Text messages show number instead of name, Working as intended?
- How to stop iPod/iPhone autoplay of music
- Backup cameras depth Perception seems way off?!
- Honda Debut's Android Connect Head unit
- Adjusting Volume While on Handsfree Call
- Ideal Android Car Mount area?
- EX-L Head unit froze with Iphone 6
- Navi Audio
- Apple Carplay now available on 5 Pioneer Units, who wants to be the GK guinea pig?
- A little tip for LX - iPhone users
- Nav input locked out while driving?
- My Fit doesn't like Siri
- USB music limitations?
- iPhone 6/iOS 8 Caller ID + Display Audio Weirdness
- Playing Music from a Flash Drive
- Recommended USB flash drive?
- Android Auto
- Deleting Speed Dial Entries in the EX
- Radio removal on a 2015 fit
- Radio not showing Station Name or other information
- Android Google Maps - Low volume?
- Smartphone integration
- Missing Aux Input Jack
- HDMI port - how are you using it?
- iPhone podcasts play 1.5x on Bluetooth
- LX with a memory stick
- Adding Homelink??
- Amp placement
- Help with stock radio removal
- Honda addresses Honda Link issues with iOS8
- Apple heads
- iPhone text and email
- HD Radio - anyway to enable it in an EX?
- Ipad
- Routing a wire next to the radio
- Using Bluetooth directions in radio through Google Maps
- Head Unit Replacement?
- Apple CarPlay
- How is the sound system?
- Portable USB HDD to playback music?
- Cord Kit for iPhone
- Spotify + HondaLink
- Lane Watch Camera Bug and Replacing the Head Unit
- 2015 Honda Fit EX radio
- Text and message notification
- Delete Radio preset stations
- "Secret" GPS on non navi EX models
- Missing Aux Input Jack in EX
- Sirius/XM for 2015
- Jailbreak Honda Link, Possible?
- For those who plan to use a USB Flash Drive
- Stereo keeps resetting
- replacing my stock radio
