View Full Version : Fit Engine Modifications, Motor Swaps, ECU Tuning
Pages : 1 [2] 3
  1. Best Bang for your Buck intake < $200 USD
  2. AEM Dry Flow Filter?
  3. ECU upgrade?
  4. Maybe a repost? New password intake
  5. OBX lsd, any idea?
  6. WHY it is not a good idea to modifiy the frame
  7. carb legal intake
  8. listen to this fit growl! where can i get an itb setup for the fit?
  9. cant find TPS signal wire
  10. Lightweight Pully Questions. Mythelogy or others.
  11. Need Help Guys
  12. Just ordered this for my Fit!
  13. Apex'i AFC Neo
  14. Cai Vs. Sri
  15. port and polish
  16. Green Filter?
  17. Replaced shifter bushings
  18. Fuel Pump psi
  19. Methanol injection discussion
  20. cf tailgate question
  21. HPS Cold Air Intake
  22. ARC Super induction box intake
  23. K&N Typhoon
  24. Scam products
  25. Fit's Red H-Emblem
  26. 4WD Fit
  27. Stop the presses, New Chambered intake for the fit!
  28. Hids / Light swap
  29. Spoon Drop-in Air Filter
  30. K swap Vs. Stock FI
  31. Electric Fit
  32. planning to uy & Install B&M #70255 SuperCooler
  33. Any intakes for Automatics?
  34. i got bored
  35. $9 Performance Chip
  36. help with Voltage Stabilizer !!
  37. K24 4WD Fit
  38. New Last Station Intake scoop?
  39. Custom Installed ProSport Guages
  40. can any one help me?? URGENT!!!
  41. Air Intakes and prices which one should i get
  42. Burning oil when downshifting (new car) ??
  43. Spoon Vs. Stock Filter
  44. Possible B series
  45. World recored 1/4 ET/trap and dyno numbers?
  46. Dry Charger to prevent hydrolocking
  47. JDM Headlights
  48. CO2 Spray?
  49. T1R Carbon Intake
  50. Fujita SRI on my FIT
  51. WR SW intake
  52. Comptech for FIT ( under development)
  53. Install Sheets for fender braces? not aj
  54. nothing here
  55. Pivot Raizin Spark Type S
  56. Intake: AEM vs. top fuel vs. k&n vs. etc...
  57. stupid ? auto to manual
  58. stupid ? auto to manual
  59. Most HP on an L15???
  60. Honda Factory Performance Muffler
  61. Need Help! HKS FCON-IS tune!
  62. L15 specs
  63. where to buy jdm L15a vtec ?
  64. Question about ECU Stock with APEXI Neo
  65. Ignition mods
  66. Drycharger or SOCK for intake?
  67. Weapon-R Secret Weapon Intake is it good?
  68. Just wondering.......
  69. 2008 FIT performance part from Mugen
  70. K & N filter
  71. Does Anybody know of a reputable performance clutch for the Fit?
  72. Fidanza Aluminun Flywheel
  73. thoughts on this swap?
  74. Most HP all motor?
  75. oil on cai filter?
  76. Hands down best intake
  77. Weapon R intake : PROS & CONS
  78. 07 with 09 power?
  79. short shifter help
  80. Underhood Temperature?
  81. A thought on intake
  82. Fuel injectors
  83. Tanabe Medailion touring vs. concept G
  84. 08 Fit Intake
  85. spoon exhaust system
  86. Swaping L15 in L13
  87. Need advise on lighthened pulley effects
  88. Which cold air intake brand??
  89. Removal of Driver Side Fog Light For CAI?
  90. exhaust....
  91. AFC wiring diagram
  92. ??? Mugen drop-in filter question???
  93. throttle body swap
  94. Piggy back ecu or apexi A/F computers?
  95. Bolt on parts and hp gains
  96. k24a swap possible in fit?
  97. Fastest Fit/Jazz on forum
  98. JDM Steering wheel
  99. Password:JDM Honda Fit PowerChamber
  100. Ah!!! Pjdm Ftl!
  101. Stock Box or Not
  102. Correcting lean A/F ratio caused by Intakes
  103. Clutch and flywheel
  104. What Swaps Fit da Fit?
  105. Unorthodox Racing pulley sets IN STOCK!!
  106. honda part stamp
  107. Mugen Fit supercharger
  108. Noisy enginer....help anyone
  109. Port n polish
  110. Wondering...
  111. More Power... without voiding the warranty!
  112. r18a in the fit?
  113. Bigger Throttle Body
  114. part numbers for Fit and Jazz emblems?
  115. Increase Low End Performance
  116. I need help
  117. Type-R Oil Cap
  118. H-Fit Supra Sucka Intake
  119. Dash mounted gauges INSTALLED! Writeup anyone?
  120. J's Racing Replacement engine mounts coming!
  121. H-Fit SS Intake installed pics
  122. HKS Japan Bolt-On Turbo
  123. k-series wiring harness conversion
  124. Which company is better at producing race vehicles
  125. Drop in Air Filters
  126. k20 swaping it in
  127. safety issues regarding running an open downpipe
  128. will I need an aftermarket clutch?
  129. K20 swap Exhaust?
  130. anyone using Secret Weapon Intake from weapon R
  131. German ShortShift for the Fit
  132. Bypass Valve
  133. Spoon Thermostat & Thermoswitch - USDM Fit?
  134. jdm yellow fog lights
  135. Modding=check Engine Light?
  136. throttle position sensor
  137. Anyone knows any update regarding to aftermarket clutch?
  138. Direct Swap
  139. oversized pistons
  140. **Skunk2 New Product-Short Shifter**
  141. whp of J's racing Fit, Spoon Fit and AJR Fit?
  142. What do you guys think about Top Fuel intakes?
  143. Fujita SRI owners step in...
  144. Injen Cold Air Intake
  145. stock internals
  146. Question about intake
  147. Emanage Ultimate for our Fit
  148. difference between high and low compression rate
  149. Help wit NOS
  150. H-Fit Supa Sucka Intake Now Available!
  151. Pulse Plugs...2 good 2 B true?
  152. Fujita SRI and Idle relearn
  153. Spoon Sport vs J's racing
  154. stock fuel pump
  155. Best Part Combo for High RPM Gains????
  156. Any L-Series DOHC heads?
  157. Quiet Aftermarket Intake?
  158. I hate Drive By Wire.. any idea to improve DBW?
  159. Honda fit with turbo...Lost the Waranty?
  160. Hard Engine Mounts and Daily Driving
  161. Intake testing. Anyone interested?
  162. Cold Air Intake for 5AT
  163. "If It Doesn't Fit, You Must Acquit!" Johnny Cochrane
  164. buying an Intake????
  165. cai for autos
  166. Slow Car dyno day! 3 runs w/ the fit
  167. Think the L15 can be made fast?
  168. L15 JDM into UK GD1 Jazz....
  169. Finally HKS introduce Twin Power for Honda and it is for FIT!
  170. massiv usa
  171. ITB's
  172. Oil Temo high even after the cooler !!!
  173. Fujita intake
  174. B&m A/t
  175. Flywheel?
  176. k24 swap?
  177. K24 deal...opinions
  178. Dynojet Power Commander
  179. Spoon drop in air fillter of T1R carbon air intake
  180. Thoughts on Fuel Decomposing using Magnets?
  181. Oops. TB Porting. Please Read
  182. Hondata S100 EMS for Fit
  183. Fan always blowing
  184. Port n Polish
  185. Drop in Filters? Which is best?
  186. Cam
  187. General Voltage Stabilizer Puzzle Thread
  188. Simota Short Ram Intake
  189. Short ram intake or cold air intake?
  190. VS3 Voltage Stabilizer
  191. Help on Part #s for GD4(4WD) East?
  192. La-gd4??
  193. Fujita/injen
  194. Mods to improve lowend
  195. pleasee help with air/fuel meter
  196. Under Drive/Crank Pulley wanted
  197. Why no AEM V2 for FIT???
  198. K20 Fit How To Discussion
  199. aem cold air intake install info
  200. Intake for I-DSI
  201. Where is the USDM ECU located?
  202. spoon fitting?
  203. Short Arm Intake VS. Long Arm
  204. pics of short rams...
  205. How much longer on the clutch?
  206. My Fit is leaning out alot up top
  207. stock air box mod!!!
  208. What does disabling the governor do to your car?
  209. Just finished Injen CAI install!!!!
  210. E-ram superchargers, do they work?
  211. my new colair intake...
  212. Random Hissing noise in engine bay?
  213. Problem with Injen CAI Install
  214. Installing PROTOTYPE engine mounts from Innovative
  215. aspec cai
  216. cold air intake... is it worth it ?
  217. Nitrous Kit for Fit?
  218. M-Works intake & headers
  219. is it possible to do an engine swap 1.8 vtec
  220. High performance ignition systems?
  221. When to Clean Intake Filter
  222. New intake making me run rich?
  223. K&N stock replacement filter experiences?
  224. i feel so stupid for asking this ...
  225. What do you guys think of Bolt on Turbo Kit By HKS?
  226. Nano Charger - Air Charger
  227. Blitz fit? buy now!?!
  228. zero1000 induction...
  229. hood and hatch weight vs carbon fiber
  230. What do you recommends me for cooler transmission?
  231. L15A Dyno Tuned with Unichip
  232. Tanabe Front UnderBrace for Honda Fit
  233. Measurements PLEASE!!!!!!!
  234. Wtb A Injen Cai Or A T1r Carbon Intake ..
  235. Fitless :(
  236. If you had a $1000 Budget??????
  237. Nitrous in 1.3 Jazz (L13)
  238. ECU reflash? ECU Swap?
  239. Intake: Aem or Fujita
  240. still confused???
  241. Real Performance Parts
  242. TOP Fuel Headwork NA Stage Discussion
  243. Need help with Nitrous??
  244. Is there a baffled oil pan for the L15?
  245. Intake Manifold clean up
  246. Jazz GD1 @ 180km/h possible??
  247. Aluminium flywheel + oversized clutch kit
  248. Vtec controller question...
  249. Relocate Battery for Better Breathing?
  250. Greddy catch can installed.
  251. anyone how to install Apexi SAFC NEO
  252. engine mounts from innovative
  253. I want this intake
  254. New Intake for the fit!
  255. FOR YOU AUTO TRAGIC guys!!! theres a CAI now
  256. Intakes for Autos? Where Are You?
  257. K20 with air conditioning/automatic
  258. Honda Jazz 1.4 iDSI '05 Graphite IT
  259. how much boost for Fit sport AT???
  260. Thermal Shield Intake Gasket
  261. Hks Intake!!
  262. What is the best INTAKE?
  263. T1r Carbon Intake
  264. Forged pistons for Honda Fit
  265. Fujita Short Ram Air Intake System?or T1R B-Max Carbon Intake ??
  266. what intake is this?
  267. Aspec Intake Exhaust
  268. Warranty
  269. J`S Racing Fit Type GT
  270. Super Street cover:
  271. apexi power intake
  272. ToP FueL power chamber intake!
  273. L15 head/cam work?
  274. spoon or js racing
  275. fit/jazz 1.5 vtec engine swap
  276. anyone know How To Bypassing Malfunction Indicator Light?
  277. Auto Salon Ign.com HKS Turbo Kit
  278. Dyno Numbers, Dyno Numbers, Dyno Numbers
  279. Rev Ignite, more ignition!!!
  280. Opinions needed on a/t strength
  281. WARNING! Do Not Buy K & N Typhoon SRI
  282. 805FitSport redone nitrous set-up... pics inside (IAT sensor relocated!)
  283. which Performance spark plugs?
  284. Engine Weights
  285. spoon filter power numbers???
  286. HKS Racing Suction Kit
  287. Fujita Short Ram Intakes (Pics)
  288. New performance mod on ebay
  289. K&N Typhoon SRI
  290. Fujita Short Ram Intake Impressions
  291. spoon throttle body
  292. AJR intake on DSI ?
  293. Aftermarket injector
  294. Fujita SRI Pics please
  295. Quaife ATB LSD available for Fit?
  296. DIY Cold air?
  297. revist Fit on nitrous... video with sound
  298. This just in from H.Fit
  299. anyone tried this?????
  300. Fit engine size compared to others...
  301. AT Transmission Cooler
  302. Spoon Thermostat
  303. tomei pulley
  304. Unit converter
  305. New J's Racing chamber intake
  306. Blackstorm Racing Module
  307. Redline Performance Module on e-bay...
  308. Blitz Lm Filter
  309. Oil Catch Can?
  310. US air intakes (short/long)
  311. Hondata
  312. o2 sensor
  313. Anyone with the helms manual for the USDM Fit?
  314. NOS on AT
  315. Spoon N1
  316. GTSpec strut bar and trunk cage
  317. Jazz with LPG fuel.
  318. Turbo for 1.3DSI Jazz?
  319. Fidanza Aluminum Flywheel
  320. T1R Intake
  321. TB Coolant bypass
  322. MAP sensor
  323. Second attempt T1R Crank pulley + Exhaust !
  324. B16/17/18 swaps?
  325. Pics of Spoon backpipe
  326. 'Mythelogy' lightened crank pulley
  327. Mugen filter
  328. Performance gain without losing gas mileage?
  329. K20 in a FIT??
  330. ADM Electric Air Charger
  331. Need Fit for Mount prototyping
  332. Cold air intake for an 07 Auto Fit?
  333. Fit SI...I'm probably just losing my mind.
  334. What would you like for your Fit?
  335. Massiv
  336. Has anyone installed an LSD yet?
  337. Arc intake
  338. do magnetic drain plugs really work???
  339. koni for us fit?
  340. muffler n00b
  341. 1.5L Twin cam ( DOHC)
  342. Does anyone know how I can give 4 degree advance please;
  343. L13 and L15 Cylinder Head
  344. 143 hp at 8000 rpm
  345. Air Charger
  346. AT- Fujita or Weapon R?
  347. Just put on intake, now CEL, help
  348. Short Ram Intakes available?
  349. DIY: Installing an Injen CAI
  350. Fit on nitrous!
  351. Spoon ENGINE MOUNT TORQUE CANCEL DAMPER
  352. Front bumper removal instructions?
  353. Torque Dampaner! Need R&d
  354. Is there a demand for this part?
  355. Air Intake
  356. Spring Battle!: Spoon vs. T1R
  357. New here and looking to mof my Fit - Help
  358. 5zigen bad mother* wing
  359. AJR Wagonism
  360. Cold Air-vs-Short Ram Intake
  361. Injen, CAI
  362. Proven performance mods...
  363. connector question
  364. AT Transmission cooler for the Fit
  365. I went on a mission...
  366. Air Filter for Fit.. which one? help me
  367. Alex Motorsports
  368. AEM CAI Knocking Sound
  369. Engine Damper Modification
  370. Anyone have a JDM accessory brochure?
  371. Switching an AT to MT
  372. Fit to all wheel or rear wheel drive?!
  373. JDM/K20 swap - project car
  374. Is it too early to add mods?
  375. New ebay short ram coming soon!
  376. Mugen Supercharger...
  377. Comptech makes me happy
  378. TEIN for JAZZ
  379. Check this out!
  380. Hasport K20/K24 Mounts
  381. Attn Fujita Cai Owners
  382. Last Station PowerBox
  383. apexi and hks intake kit
  384. Fit performance mods???
  385. parts that could be improved
  386. replacement panel filters
  387. Apexi SAFC 2 for the jazz
  388. Anyone know where the Fit's "Moby Dick" is?
  389. new source for FiT JDM parts!
  390. Top Fuel Power Chamber Type 2
  391. T1R Carbon Intake (Dynoed)
  392. Just Got My Fujita Cai
  393. Gruppe M intake for the FIT any infos??
  394. Does the F5 fujita short ram fit the 5spd???
  395. Engine Torque Damper
  396. T1R Earthing systems
  397. Cusco LSD for Fit
  398. Buddy Club racing spec condenser
  399. Bigger throttle body
  400. AEM Intake
  401. Force Flow 4.0
  402. E68 Twin Power Intake System
  403. drop in or intake?
  404. warranty
  405. how to get a better 0-60 timing
  406. Dealer Response to Intake Question
  407. Engine bay heat insulator DIY - Help me find.. :(
  408. Fujita Short Ram Intake
  409. AEM intake available?
  410. GTSpec NEW Parts! Crankshaft Pulley and STB
  411. AT gearbox maybe problem
  412. Looking for K20A Swap Candidate!
  413. Spoon Air Filter.
  414. New to forum and to tuning...Need suggestions
  415. 1st Summit pulley installed USA?
  416. What can use from a gen 2 Integra?
  417. G-tech dyno, stock sport AT in S mode.
  418. JDM Fit product Catalog
  419. HKS Super Hybrid Drop In
  420. Obd2b?
  421. Anyone install a summit pulley on USDM fit?
  422. Does anyone have a Spoon air filter installed?
  423. KingMotorSports.com update
  424. mugen drop in mini-review
  425. Honda Fit Performance Chip
  426. Yet another Ebay find....
  427. Honda FIT Tow Hook
  428. Today's Ebay Find!!
  429. Fit CAI and Ram Air Kit - CHECK THIS OUT!
  430. Yellow Fit in Cali RUNNING FINALLY!
  431. What is TRUE (Don't delete this ADMIN!!)
  432. USA hp increase
  433. Mujen website - trying to decifer japanese
  434. awd or rwd fit?
  435. Ingalls ETD a mod I want for our cars
  436. Remote starter for MT?
  437. Find This on eBay
  438. 06 Civic Si shift boot?
  439. Converting a 5 speed manual to a 6 speed
  440. Fit K20A- Type R Proof!
  441. Anyone INstall Fujita on an A/T!!
  442. So what are your options?!
  443. hi guys need some help to mod my jazz?
  444. AEM CAI installed *pics*
  445. How much power can our CVT take?
  446. Custom AEM & me Intake!
  447. Vtec controller?
  448. What are all the options?
  449. AEM intake on sale, already???
  450. Any East Coast tuner companies need a Fit to work on?
  451. Mid/top end fix
  452. Flywheel spec.
  453. Tell JRZ (JRZ Suspension Engineering) your dreams :)
  454. CARB Legal Cold Air Intake?
  455. Any "GOOD" tuning shops in the New York area?
  456. Injen
  457. Tell Jackson Racing your dreams
  458. jazz spoiler??
  459. Best MPG ratings post!!
  460. New Fujita CAI released!
  461. Clutch Travel!!!
  462. vtec engage
  463. K20a Fit
  464. Cone Filter installed!
  465. $8+ shipping = 20 extra hp
  466. AEM intake
  467. Nitrous Oxide Kit on Fit
  468. Service Manual is available
  469. Projector headlight
  470. Highest Engine Rev on GD-3 Matic (Jazz/Fit VTEC 1,5L)
  471. PCM Programmers?
  472. Latest Engine Modification
  473. Fit for AutoX
  474. Engine Swap
  475. Unichip Piggyback & The Result On Jazz Gd-3
  476. Unichip Piggyback & The Result On Jazz Gd-3
  477. Strength of Transmission
  478. DIY VTEC indicator for Jazz/Fit
  479. Spoon and AJ Racing HP/TQ numbers?
  480. info abt the CVT transmission please
  481. Ported & Polish Head
  482. engine swap legality
  483. Comptech & J's Racing Intake
  484. any info on Spoon parts u can give?
  485. Jazz Air Filter Recommendation !
  486. B series engine swap??
  487. Questions on 1.5L engine!!
  488. May I ask how to change the 1.3L engine into k20a one?
  489. are there any great guys changing...
  490. What this thing is?
  491. Alot of DIY's for the fit,
  492. New Throttle Body
  493. short shifters question and answers
  494. How do you replace the stock horn?
  495. Fit motor codes?
  496. N/A Power
  497. K - Series in the FIT
  498. Windscreen wiper
  499. Reference Bible for Springs/Rims & Tires??
  500. ECU question
