- I recommend avoiding the AEM CAI
- Calling all K20 Fit owners!!!......HELP!!!!
- Petition to hondata to release a reflash for gd3 fit
- blitz throttle controller help
- Piggyback help!!!!!!
- GD pistons in GE engine?
- Jazz CVT to Fit Auto, Possible?
- Fuel pump / fuel regulator
- A/T Transmission rough
- Helppp!!!
- Honda car parts
- Fuel Pressure - for turbo
- TPS sensor voltage??????!!!!!!!!!!!!!
- WR intake manifold FINALLY cracked !!
- My Jazz Dyno'ed
- Crank Pulley: Stock dampened?
- KraftWerks engine oil cooler system in development!
- question about nitrous timing
- What Performance Chips are available in UK (GD1)?
- T1R intake issue !
- aux in for UEGO on my boomslang?
- greddy e-manage VS aem fic
- How big is too big?
- What you think about this custom HKS intake?
- Weapon-r neo!!!!!! Look
- Changing cams!!!
- If swapping in a non honda engine, what happens with gauges..
- Advice on mods for UK Jazz?
- Question regarding T1R intake install
- Whats soooo wrong with modding a FIT?
- Brazil ECU, injector Swap for E85 usage?
- My New Clutch Masters Clutch Review!!
- Where to get K20/24 swaps?
- What would it cost to install?
- NEW turbo manifold for Fit!
- What to get next??
- Fit reflash, re-tune?
- anyone running Hiprospeed SRI?
- Transmission options
- Gude Bullfrog Head package
- Skunk2 limited edition oil cap and stuff
- K20 - rsx typs S ecu ?
- Oil Temp Sensor Location
- Cat cams
- H-fit SS intake
- transmission swap
- Anybody have a Dyno of a DC Sports Header?
- quick spark plug questions
- Weapon-r manifold = |
- HKS intake pic request
- Just Installed Fujita SRI
- GD exhaust fit GE
- need help :/
- spoon low temp fan switch..
- ***The Official SSR Intake Owners Thread (Sid Short Ram Intake)***
- does adding an intake really give you more mpg?
- question
- H22 in a fit
- Will T3/t4 turbo with 440 injectors work on my 07 Fit?
- Swap: L13A to L15A - possible?
- Fit 1\4 mile times...
- braille battery question
- adding style to PWJDM manifold cover
- Taking oil pan off
- Low Temp ECT Fan switch?
- Which Torque Damper are the best?
- Colored PCV Tubing?
- re: Apexi AFC-neo
- Burning smell on track: Coming from transmission/engine?
- honda fit 2007 i vite in ted vite
- Battery relocate for NSX airbox
- Possible N/a and Turbo reflash
- How To Port Your Cylinder Heads
- ?uestion about CEL's
- PRM Intake Pic Pleeeassee
- anyone using this???
- Valve cover torque specs?
- Toda racing engine
- Fujita Short Ram Intake and now smoke smell?!?
- Cleaning PRM intake filter
- Engine Build Thread
- running lean
- Thinner M/T oil?
- Pivot 3M
- Short Ram Intake Question
- carburator for honda fit
- AEM methanol injection kit?
- Cylinder order?
- is it possible to put a turbo in the 2007 fit?
- I and H needed out of the (I/H/E)
- weapon-r race header wrapped?
- whats a good short air intake or ram to get for 2007 fit
- need mod advice
- Quick SRI Questions...TIA
- AEM F/IC installed!!!!!!!!!!
- Blitz Throttle Controller INSTALLED + DIY
- Clutch Delay Valve
- Oil Catch ?uestion
- quick question about engine mods!
- Higher compression N/A?
- apexi neo or aem f/ic?
- Would a 1.8li ivtec fit in a Fit GE?
- Racing: Fit vs audi s3
- GE8 TB and Intake on a GD3
- injen sp1511????
- installed WR oil catch can
- The Official Normally-Aspirated Thread....(techniques/parts/troubleshooting etc.)
- Scoop Intake Build
- Sugarphreak 2.0 - Kickoff
- ECU pinout for L15A GD Fit
- Apexi intake?
- OBX LSD......dont even think about it
- MT swap
- Stack Intake for L13 CVT
- Springs Retainers Need Help
- valve clearance
- Anybody know where this is located on the engine
- ECU controller for L15A
- Plugs????
- Anybody has the Exedy stage 1 clutch?
- OBD2 Port, where is it?
- Springs Retainers
- The things that over revving may do to your engine (possible minor NA build??)
- Messing with timing
- Throttle Body Bypass?
- Kustomz Unlimited Intake Manifold
- Backfiring Prevention, possible?
- SRI's are loud, but how loud?
- Exhaust Manifold L15A VTEC
- Wiseco Forged Piston Find...
- K20z3 into '09 Fit
- Stock injector size
- EGR valve
- Spark plugs!!
- Honda Access Cybermall
- Clutch for GE8?
- E85?
- ge8 cam gear
- Greddy ultimate piggyback.
- throttle controller, torque damper and pulley anyone running all 3?
- Swapping my L13 for a L15
- A new clutch option! Bully Clutch!
- mods that need to be made for ge8
- K20 or K24
- GE8 mods
- My plan
- Afr?
- RHD conversion?
- Does the L15A comes in A/T (IE. not CVT)
- ARC intake
- Mfactory Racing Flywheel
- perfict
- AEM wideband bung location?
- header gasket
- Any cams yet?
- To the guys running lean! (simple trix inside with results!)
- question?
- crank pulley removal?
- i-DSI Throttle Body
- Wr manifold testers..
- crower cams
- AT to MT?
- Finialized Fit Sheet Metal Manifold..
- My Spoon Rad Cap :(
- HPS CAI A/T conversion
- L15 11.4.1 compression N/A
- Check this IM out
- noblesse, where to buy?
- EGT and Fuel Pressure Gauge Installation Q
- Best Guess at HP Numbers
- Help!!!!!!! Crank pulley bolt
- Spoon Engine Torqe Damper installation review.
- Jet Performance ECU chip??
- Scanguage code P2227 ... ??
- Weapon R intake manifold install question.
- B18C1 in a fit!!
- Valve Cover!!!
- ITB's
- overheating when driving hard and on idle
- Oil Catch can mounting locations
- J's racing or Spoon Throttle Body
- Info on Buddy Club e-throttle booster vs. Blitz throttle controller
- Throttle body spacer?
- Re-installing stock airbox
- scan guage error code help !!
- GD3 M/T rear engine mount replacement
- NST pulley...
- Weird CEL and Rev limiter change
- Hood damper/prop
- DIY guide for Blitz throttle control is needed !
- Intake Help
- does any one have or heard of buddyclubs new throttle controller?
- A/C belt delete
- mFactory 4.7FD/Quaife ATB LSD/T1R clutch installed!
- Aem cai
- Motor mounts for L15A to eliminate wheel hop?
- NST pulley on ebay
- Piggyback units and L15 Tuning
- Can someone point me in the right direction
- What XGauge will measure any difference in performance with a controvesial mod?
- Ingalls Stiffy vs Spoon engine torque damper
- Ingalls "STIFFY" engine torque damper
- Modding an automatic?
- BTC Mounting?
- just starting
- intake filter shield
- PRM's 09 kit soon comith
- Zex Nitrous System
- h-fit supa sucka or T1R carbon fiber intake?
- Next Level Performance...Tri-Phase Module
- Blitz throttle control OR Pivot 3-drive throttle control?
- idle rpm
- PRM's intake dyno figures
- looking for...
- Stock Air Box mods?
- So I dyno'd my Fit
- Intake Manifold/Throttle body?
- question about i/h/e on AT
- AFE Stg2 Intake...Warning Dont Buy
- Weapon R Secert Weapon Intake setup
- Fujita Short ram... Where to buy?
- removing stock intake box bracket
- Mfactory LSD Installed
- Pros and Cons of K20 swap
- Need advice for building motor...
- Max Bore Throttle Body
- Vafc in a GD3
- Intake manifold differences....
- What happens to engine without TB?
- Ebay Intake
- Exedy Stage 1 and 2 Clutch Kits Available Now!!!
- problem/questions Fujita CAI
- Injen Cold Air to Short Ram question
- anyone have this intake?
- Supa-Sucka Installation
- Supa-Sucka Power Gains?
- What happens to the old L15 motors?
- IAT question
- k&n drop in filter vs. mugen drop in filter
- Porting head
- Ingalls torque damper
- Weapon R IM
- PRM Racing Intake - Review+Pics+Video
- Bypassing Coolant Passages to T-B!!
- intake heatsoaking???
- T1R carbon fiber intake or CAI?
- Best place to purchase Engine Mounts??!
- 1.1 VS 1.3 on Radiator Cap
- Possible to put F20C engine (S2K) inside Honda Fit
- Sceptre intake... yeah, home made
- K&N vs Intake
- 1.8L swap
- What size are the Air Intakes for the fit?
- help with intake....
- who makes this manifold ?
- noob intake questions
- Fit Silver Door Sill
- Intake which is best...
- Cruise control not working....after ground wire kit install...???
- NST pulleys
- So I bought a K&N intake....
- Does it really matter?
- If I....
- Intake Question
- who makes oil cooler for GD3 ?
- looking for good,cheap,ez to install intake.
- DC5 helical LSD a direct swap for GD3 manual?
- A couple of noob questions
- Chambered Intakes???
- Removing ABS?
- Short Shifter
- Which Intake?
- Best Cold Air Kit
- zex nos kit for honda fit
- The fit can ported and it does help
- Grounding Kit by Teck Kits
- Dyno results!!
- JDM All Wheel Transplant to USDM Fit?
- ...how to reinstall stock intake?
- World's first HD plastic reinforcement bar
- Hamp Oil 5gal Drum
- Royal Purple in the fit motor!
- my intake (in the works...)
- Exedy Clutch Info
- Sugarphreak Dyno - Shocking Results!
- Best shop for k20fit
- My question thread....
- buy dc header?
- Breather hose?
- WR Rev2 Manifold
- okada plasma direct
- every detail about teh l series
- Innovative Mounts Released!
- What OBD is the Fit?
- looking for braided stainless clutch line
- Reliability testing my parts...sort of
- just a quick question. extened lugs fit normal studs?
- 64mm Throttle Body
- where to buy t1r ss?
- NEW!!! PRM intake prototype
- Modified OEM Airbox
- Buddy Club Race Header
- Shifter plastic ball cup cap thingie - where can I get a replacement?
- For those wanting to go over 200hp.
- simota
- T1R Vs. Password: JDM
- Pistons and turbo kit
- For Those Wanting the Mishimoto Carbon Intake
- blitz throttle control working with greddy e manage?
- questions regarding clutch installation...
- ATS Carbon Clutch
- HPS SRI OR Fujita SRI
- T1R Clutch=Big Time FAIL
- Fit2008 - GE6 ECU pin out
- k24?
- jdm usdm intake manifold difference
- SHG Intake
- Battle of intake systems
- Installed CAI, now overheating need help ASAP
- how to AT tranny cooler ?
- T1R B-Max Carbon Intake Questions
- Performance Chips
- NST lightweight crank pulley
- Intake air temp difference
- Question For All The Tuners
- vtec solenoid cleaning... do we need to do it?
- any cams avabile yet??
- Engine mount replacement: Warranty?
- T1R Crankshaft Pulley
- Where to get the cheapest Mishimoto Carbon Fiber intake?
- Powder Coating valve cover? heat resistant?
- Fuel pressure regulator
- WR Intake Manifold EGR problems Solved.
- I want more low-end power/torque--What mod next?
- Afe Cai???
- R18 swap into Fit?
- Just installed SRI: A few questions
- How do you know "break in"
- at what point?
- home made chamber intake
- Performance chip, anyone?.........
- Replaced trans fluid and huge difference.
- Please help!!
- Lightweight Fit...
- b18c swap
- Upgraded Radiator?
- Project: asking for help
- one-off custom intake on ebay
- My SFF Build!
- Torque Damper YES or NO?
- hood prop?
- first mpg report with cai installed
- Easy way to fix a CAI to Run in rainy weather
- converting auto into manual
- shift kit for A/T?
- intake question!
- To suck or not to suck? That is the question.
- Potential Buyer - Questions About Modding.
- header back - no muffler - real loud
- New intake coming soon...
- Share pics of your CAI setup....
- Where do you buy engines?
- ECU pinouts
- New Fuel Mgmt Module - Need Input
- AFE intake pics
- Caution: Intake warning!
- electronic
- JDM to USDM Throttle Body Swap Question
- spoon shocks and spring
- Spoon B-pipe, axle back, and T1R cf sri
- Tunerzine Fit getting Zex Nitrous!
- Old and new L15 heads Compatible?
- What are some options in improving performance?
- Ignition Booster
- crankshaft bolt which way to loosen?
- flywheel
- boosting, which gauges to install?
- Intakes for the DS-I engine, hmm...
- New Fit need suggestions
- k20 310cc injectors
- Throttle body for fit
- T1R quicker shifter???
- eunos oil
- How come nobody sees J's Racing Fit?
- Auxilary Vent directly on the Intake Manifold?
- Do CAI or short ram intakes make a lot of noise?
- Tunerzine VIP Fit mishimoto intake install..
- T1R intake vs. AEM
- any stock *A/T* dyno plots?
- combining skunk2 short shifter with t1r ss
- synchros... wtf?
- light fly wheel
- Cheaper lsd than J's racing?
- O2 voltage range
- hks intake
- Universal Carbon Air Box
- t1r intake question please answer
- Honda Fit ECU?
- How to get more air circulation under the hood?
- How do the paddle shifters in the A/T Fit work?
- Anyone have a grounding kit or BC Race Spec Condenser
- whats everyone using these days for tuning?
- L15a Header flange from WeiRtech
- crower cam
- More pleasant motor swap than K20
- anyone change their plugs yet? brand?
- Engine Torque Dampers
- ***The Official SSR Intake DIY Thread (Sid Short Ram Intake)***
- New Filter = More HP?
- does it make that much difference????
- anybody seen this!!!!
- Review: Weapon R Intake Manifold
- the ULTIMATE honda motor swap!
- Summer is just around the corner.. what mods are you doing?
- Intake manifold swap
- K-series but its an auto
- Weight of L15
- The Official Intake Thread
- afe stageII intake for the fit
- Clutch option...
- Driving opinions with lighter crank pulley
- Hondata?
- Which oil type needed for fit w/ LSD installed
- jdm guage cluster on usdm with auto
- JDM L15 HERE I COME!!@!!@!!!! (im building this b*tch 4 boost)
- OMG Voided Warranty!
- greddy intelligent informeter
- Manual 3rd gear delay
- K20 but keep it automatic?
- newb has Q on sport auto trans.
- CAI carb question!!!
- CAI for auto tran FIT???
- Supa Sucka Intake vs T1R Carbon SRI
- S-afc???
- Cold Air Intake system?!?!
- Possible 8k RPM L15
- Oh SNAP! Engine Mount Help Needed ASAP!
- ok stupid ?
- jdm clutches??
- best intake for price with best look and performacne
- valve cover mod
- B-series LSD?
- Injen CAI touch fogs?
- T1R Short Shifter
- battery relocation?
- R18 swap? easy?
- Bulletproof Automotive
- ECU Reset
- Possible 4WD conversion?
- I need L15 Specs...Help!
- Hps Intake!
- Oil catch can
- Header for low rpm gain?
- Apex'i Power Intake?!
- quick question about a DIY intake
- Aftermarket Engine Mounts
- Fit 1.3A Performance??? Cone Air Intake + HKS XOS + Experience Honda Tunner
- L.s.d. Obx
- Individual Throttle Bodies
- AEM Fuel/Ignition Controller installed
- B Series into A Fit?!?!?!!?!?!?
- Spoon intake box
- Vehicle Stability Assist (VSA)
- ECU/ Dyno tune
- grounding kit points
- the way our ecu thinks...
- New Intake for FITS
- my 08 fit came with no vtec switch
- VTEC Switch Possible?
- Leaning out? How about fuel return line and fuel pressure regulator for Fit?
- cryo treated engine
- camshaft
- spoon parts catalog for GD3 (go away 56k)
- $40 Homemade Short Ram Intake
- drop-in or CAI?
- Gimme your dyno graphs!
- Help! New Tuner in need!
- Throttle controllers, yea!
- light-weight pulley alt/crank
- k&n filter & our sensors...
- auto to manual conversion
- SATISFACTION cai systems
- Your Intake, HP Gain & Pic.
- H-Fit Supa Sucka Intake
- Wr Intake Manifold For Gd.
- DIY: P2R Intake Manifold "performance" gasket
- megan axle back
- CARB legal intake?
- Fujita Short ram intake or Zero 1000 Power Chamber
- LSD maintenance schedule??
- Ingalls Torque Damper
- k23 in a Fit?
- T1R Carbon Intake - First Impressions
- Honda FIT CVT vs Acura RSX CVT which is better?
- H-FIT supa sucka intake
- K20 Help!
- jdmsupply.com
- Sound from Gear box
- PassworedJDM Carbon Fiber Power Chamber...
