- DRL 95 Honda Accord EX
- OEM speakers for my 1998 Honda Civic DX HB: question for remplacement
- Tires on a 2003 Accord
- After market Stereo for 2001 Odyssey - recos?
- 95 Accord cooling fan fuse blows
- Need Body Part Name for '97 Civic
- 2003 civic ex
- Windshield rock damage
- Brake question for TeGGeR
- Brake Question for TeGGeR
- Sirius SIR-PNR1 and Honda Civic 2001 installation
- How do you replace headlight bulb in Honda US Wagon
- Odyssey 2000-2001 questions
- Transmission Gone Bad --Sell or Fix
- Reflex wipers on an 05 Accord?
- wont run uphill
- '88 Accord spark plug gap
- 2000 I-4 Accord: Jerky shift
- 1990 Accord LX, manual transmission
- free adult website xxx passwords !!
- Cup holder--$75????
- Looking at buying a 94 Prelude. looking for any info????
- 93 prelude main relay problem
- Onboard diagnosis interface - reading ECU data?
- Vibrating Honda
- A Blog About Making Money With Your Hobby
- Loose caliper on Integra?
- 1993 Honda prelude vtec
- 95 Accord AC problems - NEED ADVICE!
- Replacement Battery '92 Accord Question
- Do It Yourself Distributor Change
- Question on "Maint Reqd" light
- Honda Civic EX vs Mazda3 S
- A new milestone!
- TIP: Ignition switch replacement (smoking)
- 93 Accord - AT tight when in PARK
- honda passport AT fluid
- HRV Wing Mirror
- '02 Civic with cracked manifold
- diagnosis/cost: 98 accord lx hesitates @ startup
- injector on/off ratio display
- Vancouver Area - Acura Club ideas
- repair shop recommendations near Palm Beach Gardens, FL
- rear weel area griding noise when turning
- Muffler pipe ? ('97 Honda Civic DX)
- A/C 94 Civic
- 99 Civic LX won't start (sometimes)
- 2005 Accord EX - nose mask
- Insurance problem with Japan Prelude SI VTEC 1992
- 1994 Accord A/C pretty useless
- Unofficial FAQ: Brake Master Cylinder update
- Civic Check Engine Light - Code P1336
- shift stick drivers
- 94 Accord AT going bad?
- Filetoad.com Latest Software Virus and spyware
- Hood supposed to be insulated?
- 2000 Honda Civic EX-G (Canadian Model) Exhaust issues **Need Help**
- FS 1990 Honda CRX HF (DFW)
- converting refrigerant, 1990 Honda Accord
- Re: Big Bertha Thing blogs
- Re: bicycle rack for Insight? anyone?
- Anybody had the Civic ('97) bumper off?
- Looking for advice about service for Accord
- 94 Integra burst A/C suction hose question
- Tegger: Did you do your clutch yet?
- 91 Civic corrosion of rotor button
- What are the best model years to purchase used Honda Accords?
- Integra-95 Demister
- Engine light keeps comming on
- 2000 Odyssey trailer hitch bolt size?
- BUY AND SELL YOUR HONDAS! www.why2buy.com.. just check it out
- Honda Elite-problems
- Civic AC weak?
- Noise-suppressing carpets for Honda Element?
- buy and sell your autos by posting free! www.why2buy.com
- Honda Accord Bumpers
- Honda CR-V 2003: can the 12 volt outlet be 'always on'?
- Civic GX
- 98 civic check engine light
- 1991 Civic Stalls
- 2004 CR-V "first oil change" technical bulletin?
- 1998 Honda Accord Coupe
- 97 accord srs light on
- Unofficial FAQ: Ignition corrections
- 1990 Accord Distributor
- Oil in spark plugs
- Los Angeles Mechanic
- 2005 Honda Accord Coupe EX V6 Demo Price?
- dedTUNIA: Gegen kreisrunden Haarausfall - Against circular loss of hair - Contre Alopécie Areata
- www.fantasyshop.com.au
- 93 Honda Accord Ex , 2 door
- 2005 Accord 12 Volt Accessory Socket
- Buy and sell honda parts, free exposure for your honda item www.why2buy.com
- Dealer recommended me to change brake pads, charging $220, what to do?
- where to get 04 honda pilot aftermarket side bars and front bars
- NY Go Kart Endurance Racing - Arrive & Drive - 6/17/05
- CRV radio audio input
- 93 Honda Civic Engine Longevity
- Can anyone comment on 2005 Accord EX V6 Navigation system?
- Adjusting headlight aim on 94-97 accord
- Alignment Problem 95 Integra
- Soft brake persists after Brake Fluid Flush.
- Toyota to raise prices out of consideration for U.S. car makers
- Test Message
- 5w50 synthetic instead of 5w20
- '93 Honda Accord with some problems
- 95 Civic - Clutch?
- 2005 Civic Hybrid -- A/C problem?
- AT has better MPG than MT?
- 05 odyssey navigation doesn't load
- Bad vibration at idle when AC compressor kicks in
- 94 Civic spark plugs: type and socket size
- handaaccessories.com
- Gear shift lock out
- ok, what's with this?
- Full size SUV?
- Honda Jazz UK CVT holding on hills
- Rain leak, CR-V, 2001
- honda accord LX 2005 MP3 Player
- DIY Hatch Glass
- Ignition Timing Question
- 96 Civic DX, steering becomes too soft
- 94-97 Accord - How long do front springs usually last?
- Re: How long do aftermarket struts tend to last (Sensatrac)? (harsh ride on 97 Accord)
- Anyone install Goodyear Assurance Comfortred tires?
- Replacing Master-Cylinder twice
- 1990 Accord
- Re: Any recommendation for aftermarket headlamp bulbs for 94-97 Accord
- civic timing belt adj bolt?
- 96 Civic passenger side water leakage, A/C
- DIGITAL CLOCK HONDA ACCORD LX EX DX SE 94 95 96 97
- Leak Near Rear Window - 2003 Accord
- FS: Tokico front struts for '88 Accord
- Sound dampening can cause rust?
- * * * Please Read And/Or Print This! * * * Press [Ctrl][P] Keys On Your Keyboard To Print >> June 1, 2004 9:31:37 pm >> http://115639.aceboard.net/forum2.php?rub=158&cat=61&login=115639&page=0#id96 << * * * * * * * * *
- 96 Civic No Start
- Can't get the %$#@! license plate off
- Shock absorber bushing
- Belt-like squeak when clutch is out
- HELP- Changing Headlight
- fuel pump noise 1994 Integra
- '05 Civic EX: Looking for no drill Type I receiver hitch
- Honda Odyssey DVD Player
- Fuel Filter location of Civic 89
- 2000 Accord Brakes - Ceramic Pads?
- New! The Unofficial FAQ is now searchable!
- ABS Warning light
- 90 Civic main relay replacement, how to release connector ?
- Problem Entering & Exiting 2005 Accord EX
- Key Remote programming
- Ladder rack?
- best stuff for removing stains in auto carpeting? (ink, taco sauce etc.)
- Immobilizer Theft-Deterrent in Honda Civic Ex 2000
- Re: 200 My 1 Accord EX leather seat problem
- 05-Accord - Questions
- '05 Civic EX: Transmission slips from 3rd to 4th sometimes
- Does anyone have wiring diagram for Civic 93 EG si model ?
- replacement tape deck for 88 honda civic
- Honda Accord depr & trade ?
- Civic Type R fuel economy?
- Power Window Switch
- 2001 civic autotransmission - hesitation
- 91 Accord Fuel Filter question
- Color Opinions
- 2005 TL vs 2005 Accord
- (Recommendations) Ones I found useful: Consumer Rights Trouble, 2005 car reviews & Car Safety Seats Guide. [w12332]
- 2003 Honda accord Head unit display
- Examples of Gender Bias in Car Sales
- Accord vs. Camry ?
- 94 Civic: exhaust system replacement
- CR-V SatNav DVD backup
- replacing single rear brake caliper?
- 2003 Accord Radio Display Problem
- Best game ever
- '93 Accord transmission problem.
- 1991 Accord Balance Shafts Belt Tensioner
- Honda Element Full Back Cargo Mat with a logo!
- FS: 2004 Honda Civic EX 5 spd with side airbags in Virginia
- NY Go Kart Racing - This Saturday - Arrive & Drive!!
- '91 Accord won't start when wet
- You want can be found! Perhaps
- 2000 Civic w/Leaky Moonroof
- looking for a car?
- 95 civic suspension upgrade
- Re: Re: 1989 Sterling 827SL Ignition output problem one spark on
- I need help: 1998 Honda Civic 4 door LX
- 2003 Accord EX-V6 stereo backlight is out
- how much labour to change distributor - 93 accord
- Honda Element right door lock: unsafe?
- Header Ciivic 1.5L ?
- Strange noise behind my 1997 Acura CL 2.2
- 99 Honda Odyssey Radio - Anti Theft
- Honda Civic 01 Alternator change at 58K
- 1992 Honda Civic VSS(?) problem
- 87 Accord alternator part 2
- 1990 Honda Civic Wagon
- Need Help for a 93 Accord 10th Anniv. Edition
- 97 Prelude Value?
- 2000 Accord EX-V6 Wipers
- 1999 Odyssey water under carpet...
- HELP! 99 Honda Accord dashboard backlight is out!
- Rear light stuck on 92 Accord
- Ignition updates to the Unofficial FAQ
- 1987 CRX questions
- How Dare Could America Industrial Property Office Be In Conspiracy With Jungang International Patent Office To Make An Extravagant International Crime ?
- '90 Civic Driveability Issue
- Honda vs Toyota ??
- e.g.r. valve maintenance
- Re: In Van. BC where to buy door window?
- check engine light 1990 honda civic wagon 2wd
- 93 civic cx transmission
- 93 Honda Civic Needs Repairs 234,000 miles
- 94 Civic 1.5L 5 speed LX head gasket 170k miles?
- 95 Civic 1.5L how to do head gasket?
- Brake Specs: 99 Civic LX
- Civic 2002 LX (Canadian Model)
- What year did the Civic have fuel injection?
- Pics of my Civic - corrected
- Pics of my Civic
- bleeding order for 2000 Accord
- Civic - Honda service or mechanic?
- How to Clean Heater Core? - 93 Civic
- How to take ball joint out of Knuckle
- Odyssey Sunroof - how to adjust/lube/service?
- Some good sites for Civic owners?
- change in car acceleration Honda Accord
- 87 Accord oil burning when cold.
- Question re: Platium Spark Plugs
- Ran car with no steering fluids now leaks. `89 lxi Accord Honda
- Converting Rear Drums to Discs on an EG Honda Civic
- NGK spark plug update
- 91 Civic: Seat belt alarm
- 95 civic master cylinder replacement
- 13" vs 14" wheels on 94 Civic - best MPG?
- What is wrong with Civic 2001 front suspension?
- Testing alternator.
- Honda CR-V brake failure
- 2001 Accord LX-V6 - rough idle
- 2003 Accord Radio dead
- Spark Plug Hex Nut Disintegrated
- auto tranny 93 civic cx
- 1993 Accord Wagon - brake job mess
- 2000 Civic P0135 heated HO2S
- Tachometer doesn´t work on Civic 2000
- Radiator drain cock - how tight
- Honda Element improper oil change?
- fyi- cool deal
- Re: 88-91 honda civic 2dr- are driver side door windows identical for these years? I need to replace my '88. thanks, eom.
- 98 Civic Windshield Difference?
- Setting the clock in a 2004 Civic stock radio
- 92 Honda Civic No Crank
- Brake fluid leak from Brake line
- 94 civic transmision failure
- 2000 Honda Accord EGR valve
- New Timing Belt at 360K Miles?
- Honda/Accura model similarities
- Radiator Cap
- 1992 Honda Accord EX 2.2 L pinging Does this car have knock sensor
- Leak in Master Cylinder
- Honda Pilot ok in sand?
- suggestions to buy accord
- Duct Cleaning
- Homelink
- 94 Civic vibrates at low RPM
- Brand New Ball Joints
- WTB: carb for Prelude
- Re: Integra 91 A/C
- Jesus said, "I am the way, the truth and the life: no one can come to the Father(God)(in Heaven), but by me." (John 14:6) This means that if you die without trusting in Jesus Christ as your Lord and Saviour you will die in your sins and be
- NY Go Kart Endurance Racing - www.OVRP.com
- Crankshaft pulley turns but not cam
- Click sound from wheels, Integra
- Wiring pinout for ELD,
- Re: 92 Civic radiator fan doesn't work
- 92 Civic radiator fan doesn't work
- 91 Civic Problems
- Weak radio solution
- Civic release date
- Installation of struts/shocks
- computer codes
- 91 Accord - "Change oil" indicator is on but....
- Re: computer codes
- 05 Accord Pictures
- Stolen side view mirror on Honda Civic '97
- Timing belt inspection, 90 Acura Integra
- changing a tail light (Prelude '01)
- static electricity shock when exiting car (97 Accord) - anti-static straps?
- How to check whether timing belt slipped on 88 Accord
- 98 Accord LX hesitates after starting
- Are new Hondas maintenance free?
- Civic Website
- 1987 Civic with d13_a2 1.3L
- Thoughts on Cooper Tires Please
- When to top off oil
- 99 Accord ignition recall disaster
- slight vibrations from everywhere in 05 accord
- Seized Bolts to Anticipate?
- 1994 Honda Civic- Ignition lock
- Life saving driving tips
- CRV driveshaft replacement
- Set of Neuspeed Racing Springs for 96-00 Civic
- Modine radiator for 91 civic std hatchback -- CANT FIND ANYWHERE
- 05 Accord - Tires?
- Req: Link for brake service routine 2001 Civic
- '90 Civic Rear Suspension Clunk
- battery corrosion on 95 Civic
- Alldata 2004, [4 DVDs], [53 CDs], Mitchell CDs, year 2005 - 2003 , 53 CDs, total 107 CDs
- 05 Accord 4 cyl Engine Break-in?
- Transmission
- Question for electronics experts...
- Honda Civic - D16A2 Engine
- Door lock making noise
- Is the D4 light on a 1998 Honda Civic supposed to be illuminated while driving?
- Newbie here...Honda civic 1998..help needed
- New to Hondas, got a few questions
- 05 Accord Hybrid engine light blinks, no code
- 95 Civic overheats when not moving
- 1990 Acura Legend Jack Points
- intermittent start
- 92 accord - front drivers side rattle and shake
- Water pump selant required beside rubber gasket?
- 86 Legend workshop manual 4 sale
- Re: 89 Hond Prelude Service Manuals on CD
- Honda Legend Workshop manual 4 sale
- 2 Honda Civics FS in North Central Iowa
- Subject: Looking for more information.
- '99 Accord Blinking Oil Light -- sanity check
- Noisy Sunroof
- Carfax $1.50
- Stick shift stiff
- Re: unburned fuel odour
- unburned fuel odor
- Tire bubble question
- creaking suspension
- Deciphering the igniter...
- 01 prelude
- My beloved Civic is no more
- Re: Honda Odyessy or Nissan Quest?
- Break pad recommendation -2001 Prelude SE
- Dealer over-torked lug nuts - warped rotors now! Advice please...
- 2006 Civic Si...
- 97 Accord brake job makes scraping noise
- Honda Civic timing belt
- '95 Accord: Keyless Entry Install
- Accord 91 undrivable in the rain
- 87 prelude power steering
- Need updates for 94 del Sol S
- ±z¬O§_¦b´M§ä¤@*Ó¤wÃÒ¹ê¥i¦æªº¼W¥[¦¬¤J¨Ó·½¤è¦¡¡H
- To stripe or not to stripe
- Door seal/gaps
- Honda Prelude ABS Lamp
- Need website re: Engine Pictures
- Alarm horn sound obscenely loud (2005 CR-V)
- Gear oil vs. motor oil viscosities
- Coils vs. Coilovers
- Civic Seatbelt Question
- Maintenance budget
- '92 Accord TCU
- ACCORD '93 EX STANDARD 200 K
- 1999 Model UK Accord - display lights
- 1996 Accord ABS Questions
- 92 Prelude Electric Problem.... Plz Help.
- stupid rear brake drum
- 92 Integra Idler problem
- Why Not Try This....Have you wasted $5.00 before?
- Horns: How loud?
- Suggestion needed - Engine stalling occasionally.
- Unofficial FAQ: Many small updates
- mpg Honda Element
- Honda 97 civic timing belt replacement dilemma
- stock civic 96 hx clock n radio
- Accord noise when braking low speed
- 92 Accord has no power on acceleration / slow acceleration
- '05 Accords & 225/55-16: Anyone tried?
- 1998 Accord Transmission Problem
- Break Check Light on cold mornings: '00 Accord
- CRV on board computer connection location?
- Installing Alpine CDM-s620 and civic 99 radio/headunit in 90 civic wagon
- More updates to the Unofficial FAQ
- 87 accord dies at lights
- 1985 civic upgrades
- online / mail order parts
- Selling My '87 CRX HF :(
- Special Oils
- Power Outlet Switching
- Stereo upgrade - WWYD
- Can you repair/patch a high performance tire?
- 2005 Civic Steering weirdness
- Which wire is the positive headlight (at fusebox ) for 95 civic ?
- Q. Acura vs. Toyota - Parts & Reliabity?
- Friends CRV
- 97' civic rpm issue
- faq or pics?
- 95' Civic Coupe LCD Panel Install
- 2004 CR-V replacement tires
- Brake lights, door lights and trunk light come on
- 1990 Civic hestiation/stumbling
- Do the rear speakers in a 1999 CRV do anything?
- 1999 CRV Driver's Seat Rocks
- Honda Civic 270,000 Miles!
- 2005 Accord LX, fluttering sound while idle (and various other problems)
- Re: Do You Want To Know For Sure That You Are Going To Heaven? The reason some people don't know for sure if they are going to Heaven when they die is because they just don't know. The good news is that you can know for sure that you are going to Hea
- Re: Shock/strut life for a 96 Civic Coupe
- 05-Accord?
- Civic engine wash
- Insurance: Mods & Underwriters ever "mix"?
- DC Outlet Battery Booster
- Accord Ex LCD
- "Chippers" still working on '05 VTEC ECM?
- Wider tires on back of 2001 Prelude? (215s) Bad???
- 99 civic maintenance
- EPA mpg testing
- Anyone w/access to 2005 Service Manual?
- type of gasoline for civic 05
- Paging Randolph: VSS info.
- Cigarette lighter glow ring
- 91" Honda Civic HELP replacing stereo
- follow up to radio removal
- Do You Want To Know For Sure That You Are Going To Heaven? The reason some people don't know for sure if they are going to Heaven when they die is because they just don't know. The good news is that you can know for sure that you are going to Heaven
- Re: Radio Code??
- removing radio
- 89 accord, starting problems
- stereo upgrades
- Yet another supension question!
- HELP!! Engine stalls when clutch depressed
- Civic 1,6 Vti 93'
- RPM Meter moving Up/Down during downshift in Accord 98
- Need a jack for 2000 Cr-v
- 91 accord just wont start
- Suspension creek/ balljoint check
- HELP! Rattling dashboard in Accord
- 2005 accord ex-l rear speakers
- 1990 Civic Power Loss and Shudders
- Cooling System Maintenance Questions
- Handling/Ride: +Rubber/-Unsprung weight?
- where to get good deals on honda hood deflectors
- Trailing Arm Bushings-Where to get them?
- Pilot Replacement Tires?
- 92 Civic VX VTEC-E
- Where to find PB Blaster in Canada?
- Look what I got today!
- UK Hondas
- Remote Starter / Alarm for Accord 97 instructions
- Any towing experts?
- Re: THE GREATEST NEWS EVER! °º·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º ·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º·. _._.·º°`°º·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º·._. _.·º°`°º·._._.·º°`°º·._._.·º°`°º·._._.·º°`°º·._._. · (newsgroup-post 130)
- OE Steelies Weigh? The answer is ...
- 1994 Civic Vibrates when stopped
- Greasing ball-joints
- Rear trailing arm - parking brake cable question
- Transmission removal and engine mount questions...
- god is dead, religion has been banned, bush was impeached, THE GREATEST NEWS EVER
- 88-91 civic distributor update
- 98 civic parts
- Honda S2000
- Re: what brand of oil is good for a honda pilot.
- what brand of engine oil is good for honda pilots?
- oxygen sensor warranty
- 2000 Civic spark plug
- accord transmission
- Hondas speedometers. Use DRAC modules or what?
- Honda Civic VTI steering wheel
- Female manual-Prelude driver needed
- Should I fix my Lude?
- OE Tires: Load index and safety?
- PCV valve location for D16y7
- how to check the water pump
- Calipers
- sorry, but i gotta spam y'all
- Re: Smell gas--'05 Civic
- Accord Hybrid Air Conditioning Question
- 19997 Accord EX timing belt woes
- ticking from AC fan in Civic
- Anyone here do their own 15K & 30K scheduled maintenance?
- 93 Honda Civic
- Set the clock?
- Max velocity for 2001 Accord EX coupe
- OE steel wheel weight for Accords?
- "Real time" fuel consumption measurement
- Where to get electrical power on Civic Hybrid?
- Finding TDC on 94 accord
- 94 accord High idle when driving, low idle when stopped.
- Re: 88 PGMFI accessing PCV tube at crankcase?
- How to replace wiper squeegees?
- PCV Valve
- CV Boot
- 93 Honda Civic
- Honda EX --- mp3?
- 2000 HONDA CIVIC QUESTION
- anyone know where to get cheap factory honda pilot foglights in toronto
- 92 civic 1.5 dist. seal
- Vibration at Idle
- '94 Civic EX MSD Install question...
- 2002 CRV and MAINT REQUIRED LIGHT
- 91 Civic muffler
