View Full Version : Fit DIY: Repair & Maintenance
Pages : 1 [2]
  1. Driver Window Fix
  2. Searched can't find oil drain plug torque specs
  3. Changing Brake Fluid
  4. Clunk from back seat area.
  5. Pulling Door Panels - What's Involved?
  6. First oil change & oil analysis
  7. Map Lights
  8. vibration questions
  9. Zeta parts problem? Anyone else?
  10. 08 Fit Tire Pressure Monitor Disable
  11. Rubber undercoating wheel wells-MUST!
  12. Rear bumper and rear side skirting replacement
  13. locking gas cap?
  14. Fit threw a CEL, need info on DTC code U0155
  15. Need help ASAP with a fuse
  16. Steering wheel removal???
  17. manual tranny filler bolt location?
  18. steering wheel help and my story to it.
  19. Where do you guys order maintenance parts?
  20. Goo-Gone??????
  21. Does anyone change the ATF yet?
  22. Disabling seat belt chime
  23. AC Controls, anyone replaced them?
  24. better performance
  25. metric nuts on Fit what pitch?
  26. 08 fit auto door lock
  27. Change dust/pollen filter (cabin air)
  28. Foglights on and off question
  29. Odd Sound
  30. tire plug question
  31. DIY C-Pillar Bar
  32. Big Tranny Problem
  33. Where to jack?
  34. removing rear seats
  35. Winterizing the Fit
  36. Rubbing/Squeaking Noise
  37. Mini Review of Pela 6000 Oil Extractor
  38. Different radius tires front than rear
  39. I need help to buil a K20 engine
  40. Tanabe Front Tower bar instal?
  41. How hard is it to replace the front spoiler?
  42. Maintenance Minder Oil life question
  43. DIY windshield star crack repair?
  44. tein basic damper kit- front fender rubbing. help?
  45. programing remote
  46. Cost of new bumper, fender
  47. 07-08 Fit Service Manual from Helm
  48. need ECU wirin diagram
  49. OEM Part
  50. ABS Indicator Help!
  51. DIY CEL/MIL code check
  52. water drip
  53. DIY ATF Change
  54. Engine bouncing off 4K RPM ?
  55. Tenabe GF210 Spring Install Questions
  56. MT oil change
  57. Almost every little part of the FIT is listed
  58. DIY - Mugen Short Shift Install
  59. Repairing Interior Painted Surface :(
  60. MT oil change-over to RED LINE oil
  61. Uh Oh! Cold Air Intake + Deep Water. So how bad is it when...
  62. For you longtime Honda guys, EGR problems?
  63. Can someone write up a DIY for Drum Brake change?
  64. My wife's BOM Fit is...dead!
  65. question on coolant..
  66. VBP Fog light paint black?
  67. *HELP* snap off steering wheel
  68. headlights off with ignition?
  69. Fujita Air Filter Question
  70. Paint?
  71. Another Crazy Idea (Fan Oil Cooler)
  72. ATF Fluid Change
  73. keyless entry / indicators
  74. DIY engine tune after spark plug replacement
  75. DIY fuel filter
  76. replacing rad fan
  77. Oil Consumption>?
  78. Deka Battery Vs Odyssey Battery
  79. Battery Information
  80. Airbag light
  81. DIY Transmission Fluid Change
  82. Radiator flush?
  83. ATF drain plug
  84. lug nut torque
  85. How to mitigate ill effects of short trips?
  86. Fitting in springs...
  87. ODBII code reader compliant???
  88. AC water recycle (Crazy Idea)
  89. Clutch question (can i tighten it up)
  90. Clunk Noise When Changing to Reverse?
  91. Help - Check Engine Light
  92. HELP with taillight..=(
  93. Front license plate bracket?
  94. Redline MTL?
  95. Making Scoop without damaging/Hole the Bonnet
  96. Anyone paint their calipers??
  97. Dealer overfilled oil
  98. need help
  99. Hard to get maintenance parameters
  100. autodimming mirror
  101. Grounding wire kit -- help install!
  102. Help with Self-Locking Nuts Connecting B Pipe---Cat
  103. Help with Front Strut Bar
  104. tail light? do you have to remove the bumper?
  105. DIY OEM Fog Light install on Base Fit
  106. Front bumper removal?
  107. Where to buy NGK Plugs
  108. How do you remove Dealer sticker?
  109. Foglight removal HELP ASAP!!!
  110. door panel removal
  111. removing wing mirror?!
  112. jdm style tailamp question????
  113. How to remove driver seat?
  114. 2 new goodies...do you want How-To's?
  115. fog lights on with parking lights??
  116. Rear View Mirror Loose?
  117. Anything to protect rear bumper?
  118. Service , Tire rotations?
  119. Mirror scratched on Parking Lot pillar
  120. Check fuel cap and disconnecting battery
  121. Rotten-egg smell
  122. Keyless parklight connection
  123. Take out the door panels
  124. seat track extenders
  125. Maintenance Minder or traditional oil changes?
  126. engine oil additives
  127. Question about blown AC outlet fuse...
  128. fujita ca intake help...
  129. Windows Fogging and Frosting Up
  130. DIY Taillight install
  131. technical service bulletins
  132. Occasional smell of ammonia?
  133. Has anyone removed front passenger seat?
  134. anyone install...
  135. Mp3
  136. DIY repair/strengthening stock motor mounts
  137. help rough idle
  138. Washer Nozzle Alignment
  139. PIAA silicone wiper refills
  140. JDM Jazz owners...brake pad help...
  141. Broken parking brake handle
  142. Iridiums
  143. Manual paddle shift squirreliness
  144. Help with shift boot.
  145. Just replaced my windshield
  146. J's Racing Rear Strut Bar installation
  147. Heater control stickers cracking
  148. fog lights stopped working
  149. 12/17/06 FitCCA Holiday Give-Away Winners...
  150. Replace the front bumper
  151. 12/17 - FitCCA Holiday Membership Give-Away
  152. honda exhaust pipe finisher
  153. Oil Leak!
  154. DIY T1R Carbon Intake
  155. Gauge Self-Diagnostic
  156. A/T Trans. Fluid B&M Supercooler and Temp Guage
  157. LampGard headlight & fog light protection
  158. Is it Real Site HONDA FIT ACCESSORIES IS SO CHEAP IS IT TRUSTABLE
  159. Maintenance minder sequence...
  160. RDX Key fob
  161. Windshield cracked!!
  162. Re-Keying Gas Cap Cylinder
  163. DIY - Springs instalation
  164. EPS with wristband...
  165. Driving in winter - I don't want sport mode to shift down to 1st.
  166. Missing a part from the factory?
  167. Auto Transmission shifts to low gear when it should remain in 2nd gear
  168. Q: Radiator fan and temperature
  169. Hatch rattling..
  170. Rattles- I'm winning!!! + DIY FIX
  171. DIY Oil Change 56k beware
  172. Key Gas Lock
  173. DynoScan Palm by Auterra.
  174. polen filtre
  175. seat back for tall body?
  176. It's HERE!!/Engine break-in???
  177. Official Fit "lightweight" thread
  178. I'm T1R SUPER Fan!!!
  179. Vibrations and Rattles...
  180. DIY Door Ding Removal?
  181. REQUEST - DIY Spring Installation
  182. Electrical manual available
  183. center console rattle
  184. AJR JDM Foot Light Installed
  185. Car covers?
  186. Stock air box mods
  187. Stock Alarm ?
  188. Dust and pollen filter?
  189. How to remove the front lip
  190. That plastic sheet under my front end...
  191. must have shorted something or blown a fuse, but can't find the problem... help?!
  192. Idle Speed Spec
  193. spark plugs
  194. Dash trims removal
  195. Honda TSBs
  196. In car single bike rack
  197. Fit Filters?
  198. Block heater
  199. gah, side view mirror wont go back on!!
  200. Custom rear deck
  201. Passenger visor mirror
  202. Fatty Fit
  203. Getting ready for cold weather.
  204. modified JDM roof center storage console
  205. colder a/c from hose insulation???
  206. Need to fix a hole in the bumper!
  207. Synthetic oil / first oil change
  208. USDM Lower radiator protection
  209. DIY: Another Painted Intake Manifold Cover
  210. Windshieldwiper noise
  211. Help, need wiring diagram for sport factory Alarm.
  212. How do I remove the gas cap tether?
  213. Rear Seat Belt Falling Out Fix
  214. Tools
  215. Honda brand brake fluid
  216. Rotors Rusting?!?
  217. rubber insert on the shocks?
  218. To be or not to be..missing?
  219. Rubber insert not inserted
  220. Help with the Battery Wires!
  221. JDM LED Taillight
  222. Tire Rotation ???
  223. Rear emblem loose
  224. how to take the battery out
  225. Disconnecting battery...
  226. ECM/PCM Idle Learn Procedure
  227. WANTED A DIY for aftermarket springs
  228. Charcoal canister??
  229. Gas Tank Fits more than 10.8 or 41 L's
  230. What size is are the rotors?
  231. help with OEM rear spoiler install:
  232. 12V power all the time?
  233. Oil smell at Idle
  234. Ticking noise when changing speeds
  235. FIT Repair Manuel
  236. HID Installation
  237. My 12volt accessory outlet doesn't work.
  238. fan switch location
  239. If I only had a backer
  240. Filter question
  241. Banged up my alloy rim....
  242. DC2 ITR and DC5 S 5 lugs for the FIT?? discuss
  243. Oil Filter
  244. Mobil 1 Extended Performance Filters
  245. Another filter study
  246. Different oil filter study
  247. Need guide on Honda Emblem switch
  248. JDM wiper blade
  249. For those of you who like to use Honda Oil Filter, read on.
  250. I tried Mobil One 5w-30, and....
  251. question about Defi-Link BF water temp. gauge
  252. Retro-Fit Progress
  253. Locking gas cap installation instruction
  254. Does DIY Mods void warranty on NA Fit?
  255. HELP air bag light
  256. Spark Plug Spacing?
  257. Who has changed their oil?? How many miles did you have?
  258. resetting ecu??
  259. Octane 87 89 91 93 95 ???????
  260. Knocking sound from the engine
  261. Fit's comfort
  262. Front License Plate Attachment
  263. anyone installed Mugen Visor
  264. Stant 180F thermostat
  265. DIY Keyless Entry?
  266. Need help replacing a tiny broken part...
  267. Valve Clearence And Timbelt Breakage
  268. First Oil Change
  269. Painted Intake Manifold Cover
  270. Help! I'm frying with the A/C on, in Vegas.
  271. exhaust finisher on Sport?
  272. $20 DIY Performance chip for Fit?
  273. Stock Air Filter
  274. L15A - A/C Compressor Drive Belt Part Number
  275. Request - DIY for JDM Side Markers
  276. Cruise Control for base model
  277. Install the Fujita M/T CAI in a A/T (not recommended)
  278. To Help You People Out On Oil and Filters
  279. A/C DEFROST Mode questions,answers, solutions
  280. Windshield Whining-Noise Problem Solved!
  281. DIY - Door Sill install
  282. DIY - Door Sill install
  283. Valve Cover Thingy removal...
  284. Where should I jack my Fit from?
  285. Honda Fit 2007 Service Manual
  286. Request: DIY Spring Installation Guide
  287. I found 2007 Honda Fit Owner Manual to Download
  288. undercoating?
  289. Nipples
  290. A/C pump question.
  291. Online Honda Fit parts listing!!!
  292. Wheels and Tires, again
  293. engine replaced need help!
  294. Gas pedal adjustment
  295. Honda repair manual for Pilot?
  296. Oil Filter
  297. Horn Replacement
  298. Fumoto valve available for Fit?
  299. Downloadable Fit/Jazz service manual
  300. Jack points for the Fit?
  301. Intermittent wipers ...
  302. Help Me Need To Change Stock Speedometer!
  303. First Up .. Brake
  304. Tailgate rubber seal
  305. High revs (1.5 to 2K) on start up
  306. Timing Chain on N.A. Fit?
  307. Clutch Height Adjustment????
  308. I'm going to tune up my 1.3 CVT Jazz - Help :)
  309. Hey any of you Jazz / fit owners...
  310. Fuel Filter
  311. Door power lock diagram?
  312. Fuse Question?
  313. Magic seat stucked at flat position
  314. Where to get the service manual?
  315. Fit 2002 climate control - no auto AC?
  316. Fuel Filter
  317. CVT vibration - help?
  318. OIL, filter, maintance minder questions
  319. sticky gearbox
