- Where to get yellow foglight bulbs & backup bulbs?
- Front Stabilizer bar bushings
- My lights are going out! o.O
- Timing Chain question...
- How to install LED running lights on GE8. Wiring Guru's please HELP!
- help, day lights and back lights dont turn on when turned on by the switch
- Looking At A B1 Maintenance Interval
- anyone know where I can buy the upgrade accord horn using paypal ?
- Help! How to remove front sport lip.
- Help, Gate hit my fit.
- Front lower strut bar... Help please
- Wiiper blade assembly problem
- Fuse short #8 Back Up
- Noise ?
- Need help 2007 Fit CEL!!!
- Noise coming from rear brake drum (right side)
- Help~ A/C and fan only work when set to 4!
- PCV hose noise
- DIY: Paint Your H...the right way
- Painted Fog Housing...
- Honda Fit SRS light 8-1 8-5 after accident and SRS unit reset
- Where to buy replacement tailgate struts for GD3
- T1R Radiator Hose...
- DIY: Hydraulic Lifts for Hoods GD/GE
- Need Service Manual
- Seatbelt beep malfunction
- Vinyl tinting the stock tail lights
- A/C Button doesn't engage
- Help...SRS light on and dealer said..
- Remote key fob for BASE fit?
- Aux port not working; not wired in head unit
- Black wheel scuff repair?
- 30k mile maintenance ?'s
- Quick question about Front Brake/Rotor Replacement
- How to install ARMREST onto Base FIT
- 1 Year, 17,400 Mile Oil Change Lab Results
- Has anyone done a DIY on a MTF change?
- How to remove o2 sensor?
- Anybody installed/replaced a front fender before?
- Electrical bits needed
- Installing rear view mirror back on...
- Need some input on this pls....
- PRM Intake Cleaning?
- benen tow hooks
- DIY: How to Lower Your A/C Temperature
- B12 Service Minder and Alignment
- How to fix stripped screwhole for cargo cover button?
- Official DIY: Changing Spark Plugs (L15A VTEC)
- Access to back of Fuse Box
- Recaro SRD seats + Bride RO-type seat rails: DIY seat removal and install
- request: DIY front seat removal
- Filthy Fit Filter
- Studdering in 1st gear.
- Removing Backseat
- 12V Socket in cargo area
- oil catch can
- ground wire kit???
- PCV valve question
- rewiring fog/driving lights
- Spark Plugs
- ATX filter!
- gerabox oil
- DIY Camera Mount
- Foglight problem! need help plzZ!
- Rear passenger window motor very noisy after rain
- Anyone tried to add battery water?
- 51R battery installed
- How does one "repair" Carbon Fiber?
- WTF? a/c not blowing hard on recycle
- Constant 12V source near headlights
- Modified Mishimoto CF Intake
- Removing tint
- Water In back footwell of Fit (Jazz)
- p1157 Engine code .. HELP PLEASE!!!1
- airfilters
- Help find fuel pump power line
- RPM @ idle? or neutral....
- check engine light on help please
- "CHECK GAS CAP"... what?
- Has anyone replaced a side mirror?
- ????? Skunk2 universal coilovers ?????
- Replacing Mirror/Removing Door Panel?
- Xenon HID
- DIY: How to Stiffen a GD3 Drive-by-Wire Gas Pedal
- Does anyone know how to remove hondata or ecu in 07 fit?
- Skunk2 Honda Fit head porting DIY
- Tune up
- Electronics problem
- Why you should check your air filter before it's due
- DIY: Header removal / installation help + tips
- Hood rusting from rock chip...
- i want a new battery...but...
- modified stock intakes
- 2 Oil Analysis Results - Factory Break in Oil and Synthetic
- Did you know . . .
- DIY Brake Fluid Flush
- Oil Leak
- anybody help please?
- 1999 Accord Shuts Off While Driving
- clicking sound at 1000 RPM
- 2008 Honda Fit front right turn signal light replacement
- oil filter, honda vs fram extended vs purone?
- Rear anti sway bar
- Poll Take 2: oil change interval @ 15%
- Removing glove compartment
- Need Ideas for in-car Bike Racks / 2008 Sport
- Finally Fixed Dash Vibrations
- Huge dent and scratch on fender.
- !!HELP!! please....
- Where to Buy Side Mirror Mount Thingamabob?
- Poll: oil change interval @ 15%
- Headlight assembly
- My honda Fit's high fuel consumption
- Where to get Filters?
- What ramps work with Sport?
- Cruise Control Won't Engage
- check out Walmart for oil
- Code appears after 10K miles..
- Third oil change, switching to ENEOS in my GD
- drain bolt removal direction
- Filter cut open (with Filter Mag)
- fumoto: opening the valve
- Q Horsepower full synthetic oil
- Automatic wing mirror turn in
- Inner window sill protection
- Need help!!!diy~fog light
- 0W 30 Mobil 1 Oil
- Oops...Help Please?
- DIY - Install a Gentex GENK41A Auto-Dimming Mirror with Homelink
- Ultimate Electronics DIY (56k users BEWARE)
- Help with lights, please!!
- CEL p0405- fix?
- Painting Carbon Fiber
- I need a garage lift ....which one???
- Magnetic oil drains
- key dismantle anyone know?
- AC & rear defogger button broken
- D.I.Y^o^ Vertically @ rear wiper for GD ( Fit & Jazz )
- D.I.Y^o^ Vertically @ rear wiper for GE ( Fit & Jazz )
- Coolant change
- Password JDM DIY
- Skunk 2 Springs DIY gone wrong
- Oil Filter Thread
- Installing JDM Center Console on GD3
- in cabin air filter
- recommend a torque wrench for tire rotations
- Valve Clearence
- Maintenance letters = what mileage?
- Removing 05 Fit stereo unit?
- Interior Light Problem!!
- power surge/short? 08 sport
- Oil Change????
- reset oil life monitor
- My airbag light is on??
- USB adapter
- Replacement Wiper Blades for Fit Sport
- How do you black out your headlights
- no tailights now!!
- Fit Sport Auxiliary Socket
- Oil Filter Removal
- oil life is on -numbers LOL!!
- How to Change Automatic Transmission Fluid?
- Need help removing windsheild wiper plastic.
- Washer fluid problem
- Someone with a Helm manual please!
- How to bleed the brakes on an 08 Fit
- rear strut bar diy?
- oil life --> how does it measure ??
- Brakes noisy after downhill braking, help?
- DIY: Honda Accessories Installations
- DIY: Bolt on Projector Lens
- Disconnecting alarm horn.
- My new switchblade key fob
- Aussie Fit DIY, have a look through..tons of DIY for us
- Marks on wheels from snow chains!!
- XM Radio install......need info
- cheapest air filter?
- 08 Fit Dome/Interior Lights Help!
- DIY: Changing Headlight Bulbs
- DIY Brake pads?
- Turbo timer install questions
- HELP with fan, a/c, heater console
- Help for skunk2 shortshifter
- removing/white front reflectors
- ANyone DIY on the fuel filter?
- Lost Rays Engineering wheel lock key... Help.
- BRAKE & ABS light on after tire cable install!!
- Tire Rotation and Wheel Bearing Noise
- I Fail...
- Short sifter install help!!!!!!
- It broke!!
- MTF magnet?
- After 100,000 miles...
- Tire Pressure
- DIY Seafoam
- What running 104 octane race gas on a daily drive will do to your spark plugs
- Best way to smoke taillights???
- What is the cold cranking amps for 07 stock battery?
- Hydrolock? any info guys?
- Air tools for working on suspension parts
- Engine Coolent level?
- May I have your advice please?
- Anyone wired Aftermarket CC with OEM controls?
- Automatic Door lock/light turn off
- Turn-Signal switch... wearing out?
- Water leak into the boot
- Dash Rattle... Easy fix
- Changing Wheels with Power tools
- exhaust manifold for L15a2 ?
- Weird Rub/Grind Sound
- Buzz Bomb
- need help with foglight?
- Emissions light on
- slotted? drilled? oem? Rotors.
- DIY: Oil Change on 2007 Fit
- 2007 Fit Transmission Selector Light
- Running water sound when stopping/moving
- intake filter
- switchblade key - cheap alternative
- Strange OBDII Code - Definition?
- Ran out of gas and now the fit wont start HELP!
- mother-[bleep] paint -.- help me?
- Broke my HVAC
- Steering wheel and defroster
- I need a new front lower arm!!!
- High Pitch whine emanating from dash at high speed.
- Wiring Diagram "want to add some mods"
- Broken Mirror
- has anyone tried the rear brake conversion
- DIY: Installation of hard mount shifter bushings in an 07-08 GD3
- DIY: Installation of lowering springs on 07-08 GD3
- Maintenance Minder B1
- The "I should have done it myself" Thread
- No Highbeams!
- ETCS Learn Procedure
- FYI -need oil for squeaks or lube
- rattle about the vents
- New fit owner
- Please help. About Fit's battery.
- Keeping engine bay clean??
- how to fix drv side door lock
- question about Amsoil
- Two Ways To Prevent A/C Damage from Rocks DIY/Photos
- How long did your clutch last?
- Mugen Short Shifter vs. T1R Quick Shift vs. Stock
- changing the head light bulb!!
- wiring help for sidemarkers
- electrical manual, looking for 1-3 pg scan
- S2000 fit?
- Tools of the Trade!
- T1R tow hook
- Weapon R Engine Torque Damper
- Need a front & rear lip DIY. Please Help!
- CVT getting sluggish....should i change oil ?
- Another what is it? question
- what is this?
- Recommended DIY alarms
- Pump Motor Water Windscreen Washer Problem
- oil change
- Brake Pad Change
- poor gas millage :(
- Gutted cat now have indicater light :(
- Stereo Install
- How do I add accessory wiring
- How do you remove front lip?
- How do i take off the rear viper
- Programming OEM Fit Sport Key?
- Can you make windshield wipers faster??
- Slow power windows
- UR Alternator pulley replacement
- Steering wheel not straight?
- Prestone Flush kit Where is the heater inlet hose on the Fit
- Engine accessibility on the '08 vs.'09
- Online Factory Parts stores that don't kill you on shipping charges
- Constant speed "stutter"
- Looking to replace stock spark plugs with aftermarket plugs...
- New oil change analysis
- Dome Light Access
- Removing Fit Sport rear hood spoiler?
- Fuel Gauge reading FULL!!
- n00b mistake...need help
- K&N Drop-in Air Filter
- DIY - 06+ Civic Si/Type R Shift boot into Fit
- 07 Honda Fit Sport spoiler
- DIY paint manifold cover
- Quick Wiring Question
- Service Manual
- Floor Illumination Lights
- Door sill lights!!
- DIY: T1R Sway-Bar
- **** ME SIDEWAYS....4 day old fit.****ed side mirror.PICS and please help =-(
- :( parking spot tore off my front end...
- Help with Engine Sputtering..
- Fixed Noise From Sway Bar
- Jack stands and jacking spots
- where is the horn located 2007 honda fit
- DIY water/oil temp guage install?
- clean throttle & intake
- Few engine mod questions. One is really dumb.
- DIY Side view mirror?
- help: AT tranny fluid
- malfunction indicator(mil)...thinkin the maf
- fogglights
- Fit to be tied! Rattle by right back window. Grrrr.
- DIY Password JDM CF Intake Manifold Cover
- Honda Access JDM Slim Visors
- oil level indicator check
- DIY: JDM Honda Access Slim Visors Install
- Faulty A/C
- Scratched/Gashed Dashboard Plastic: Repair Ideas?
- help!!!! check engine light is ON after...
- mt fluids
- paintinf foglight housing???
- T1R rear disc conversion package!
- power steering noise
- debadge
- OEM replacement parts online
- Who makes suspension bushings?
- Installing Fogs on a Base model
- Do i have a dead battery?
- WTF CEL! no recent mods either. any ideas?
- foglight question...
- DIY Switchblade FOB with Trunk Delete, Completed with Pics!
- Q:Clunk sound Jazz CVT
- Is there an inexpensive why to repair wheels
- estimated time for clutch install
- I LOVE the fit, but I HATE it right now...
- bad clutch...safe for 4 hour drive?
- Q: Brake system
- Honda Jazz Tail Lights
- skunk2 short shifter?
- how to adjust headlight aim...
- Jack stands or ramp for oil change?
- independent fog light question?
- 07 stereo help!
- Axels are taking a S**T
- DIY: Independent Fog w/ Original Switch.
- English Instructions
- Inside Paneling of the Hatch
- DIY: T1R Crankshaft Pulley
- Touch Up Paint, You know you need it...
- Installing Rear Spoiler
- How to: Remove vinyl or sticker pinstripes.
- Seems only option is to force flush Transmission
- Oil Change/Filter Change Question
- Has anyone installed a window module with a aftermarket alarm/starter?
- Replaced A/C Condensor
- DIY: Independent Fogs
- Another quick question about pnp Hid
- Part # of the oil drain plug gasket?
- Anybody done a tyre rotation?
- air ratchet question?
- Water sloshing around somewhere
- Removing Fit Center AC Vents
- 1st oil change lab test
- car repairman mechanic
- 2008 OBD interface for MacBook
- Anyone with an 08 Helms manual?
- Missing post -- oil test comparison
- best price on Honda Oil Filters
- Honda dealer oil
- set tool for clutch?
- Help! Check engine light
- DIY - 2 Point Grounding Kit
- TSB for wiper chatter
- Remove the instrument cluster
- Question for a honda tech
- Motor Oil. Everything you wanted to know and more.
- Extended Oil Drain Analysis: Lab Comparison
- My tpms woes
- DIY: Dust/Pollen Filter Replacement
- Sport front spoiler removal
- Synthetic 5w20 question.. specifically formulated?
- 1st oil change can't find it
- Rear Bumper Needed 2007 Silver Storm Sport
- I blew out a tire!
- DIY Aspec Header
- Yes, another hid mishap
- Anyone added cruise control to a base MT ?
- My clutch needs help! Please advise.
- Oil Capacity
- Changing wiper blades
- Help! Weird Noise !!!
- how much does scheduled maint. cost you?
- AT transmisison change interval, parts?
- How do I make inner fender flush again?
- Depo tail lights grrrrrr - wiring help please
- Car Boging HELP!
- Brake bleed sequence
- how to remove mugen rear driver side visor
- Is there a Heated Mirror mod available for our Fit?
- is my clutch going bad?
- DIY: Acura TL Switchblade Key Fob
- DIY CAI using dryer hose
- Where to buy the 15400-PLM-A01 oil filter?
- Honda Jazz Haynes UK Manual
- spring install - bolt torque specs
- Fix my suspension
- Help Loweing Car!!
- Mugen visor adhesive not sticking anymore
- crankshaft pulley tool
- Removing glass from sideview mirror
- water fan switch
- Power steering gone
- #8 Fuse
- Finally painted rear badge succesfully
- i need a DIY for skunk2 catback exhaust
- Rear Night Running Lights broken...
- Has anyone replaced their oem battery yet?
- Remove windshield wipers
- Trust E-manage Ultimate
- Ideal Tire Pressure on Stock Sport Fit?
- how do you
- diy servicing
- My factory installed front bumper lip - ripped of!
- Fuel Filter
- honda motor oil
- Jacking....?
- Water leaking between inner door panel and the door lining
- Hey DIYers, show us your box!!
- Rear Mat (for us who leave the seats folded)
- How can i fix this?
- mtf viscosity?
- Radiator fan starts kicking in whenever stopped
- haas anyone made a vteC light
- spoon knob problem
- DIY: A-Spec Cold Air Intake
- jdm center console on ebay
- Where is the OBD port?
- tps sensor help
- Complete OBD II Codes List
- Engine Vibration with Anti-sway Bar??
- comp. & cond. fan kick on in heating mode? (a/c switch off)
- DIY: LED Door Sill Lights
- Auto Dimming mirror
- anyone notice gas sloshing back and forth in car!!
- 6000 Mile valve lifter tick normal?
- Fog Lights
- Seatbelt Light and Beep
- Please explain VTEC
- So yea, My 1 month old Fit has a damaged Front Bumper
- anyone with a wiring diagram? a question
- brake light not working
- dome light wont fade out
- Bumper hook pic request
- M1-104 or M1-110: Which M1 oil filter is better?
- Is 5W-20 spec'd globally or is it North America only?
- My Solution To Cargo Cover & Bike Rack
- wheel alignment help
- Source for body panel clips?
- DIY Short Shift 4 free!
- Anyone in the CT area want to help me out with springs?
- First problem, starter gone. DO NOT DIY
- engine light flashing D
- Oil Change Question
- Noise under Fit...HELP
- Jazz Window Winder Removal
- Aftermarket steering wheel install
- Rust and other issues
- alternative to Honda oil filters
- Rust & Paint
- replacing front lip spoiler
- 2008 Headliner Removal
- coilovers??
- Where to get a K&N drop in filter??
- Help with Angel Eye Kit install
- Help on Tailgate Spoiler Template
- XM Radio install?!?!?!
- 2008 Lug Nut Torque Specs
- Winter Chains / Other Traction Aids
- Quarter panel damage
- Help to make 12V Accessory outlet always hot
- heater blower motor
- Help!
- Which brake pads are better
- Lowering / Drop
- How easy is it to replace the clutch ?
- Snapping Fender
- Front Seat Removal
- Unique oil change question/concern...
- redlining too fast...
- Maintenance Minder sequence so far
- Oil life indicator: Interesting bit from Car Talk
- cold weather start + burnt electrical smell
- fuel filter
- underinflated tires
- 2003 Jazz - Rebuilt
- will this knob fit?
- DIY on Installing Xenith Xenons HID Kits
- Honda Electronic Parts Catalogue
- Question: CVT user engine brake
- advice for diy spoon n1...
- hallowing out catalytic convertor
- Many parts to be replaced! I have questions, be kind and please offer advice!
- Driver Window Fix
- Searched can't find oil drain plug torque specs
- Changing Brake Fluid
- Clunk from back seat area.
- Pulling Door Panels - What's Involved?
