Honda Fit 2002 Rear Panel
Hi,
My missus car Honda Fit 2002 (GD1) just got some small crack at rear panel, where it covers the plate light and with honda emblem.
Any idea if you can supply this panel?
photo of said panel below. not actual car but same color.
That is refereed to as the Tailgate Garnish. You should be able to get one from your dealer, prepainted in the correct OEM color from the factory. I'd post up the part number but I can't find one for the GD chassis just yet.
What is the name of your GD1's color? I can't give you an exact part number since it starts off as 74890-SAA-013Z then the final character would be another letter which corresponds to a specific vehicle color.
If you do not know the name of the color go to an OEM Honda parts site of your country, type in either your VIN (Vehicle Identification Number) or your year, make, model info. After that look in the ELECTRICAL section and it should be in a category along the lines of "Tailight - License Light". It should be listed as illustration 19 with something like "GARNISH ASSY., RR. LICENSE" as its description.
Again, the part number should start off "74890-SAA-013Z" with an additional letter that varies depending on the garnish's color.
Edit: Just noticed that you mentioned that Fit/Jazz was the same color as your's. If I recall correctly that would be "Storm Silver Metallic" which paint code number is NH642M (you'll find the paint code in your driver's door jam) and the parts number for the garnish in that color would be 74890-SAA-013ZN. Please double check the color name/code to ensure that is correct for your Fit/Jazz before you order.
Nigh-T Pedri
02-18-2009 12:04 AM
saltydad58
09-04-2005 09:30 AM
