Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > North America FIT Forums & Clubs > America West > California - Bay Area Community
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 06-26-2009, 08:22 PM
Lancebeat1 is an unknown quantity at this point
Wiring Powered Sub to Battery - HELP!!!
Hey gang -
I have a 2009 Fit Sport in which I'm installing a small powered sub (Boss 600) and I need to know the best/easiest way to route the hot lead through the firewall to the battery. I'm handy, but would rather not make any new holes in the firewall and wondering if I can pass a 8 gauge wire through an existing grommet somewhere.
Any ideas!!!
Sponsored Links
  #2 (permalink)
Old 06-26-2009, 08:34 PM
gimme's Avatar
gimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to live
Send a message via AIM to gimme
you will most likely need to punch a hole through a rubber grommet at the firewall. that's what i did, among many others here
__________________
I offer various installs on our car and have done most that can be done. PM for pricing and appts. Not only am I a fan of the Fit, I actually own one
http://www.fitfreak.net/forums/gener...tml#post697447
  #3 (permalink)
Old 06-26-2009, 10:33 PM
Subwoofer wiring
Wow - thanks for the quick reply! When you say "punch a hole in the grommet", does that mean there's an existing passage that I might feed that wire through. And if so, how did you do that? Idon't have a ton of tools, but I'm stubborn as hell and will keep trying until I get it done. Just looking for direction from an experienced person such as you.
I'm planning on tapping into the head unit using a Scoshe line converter so I can use the low level inputs on the sub. Thinking that I should splice into the front speaker wires since I have replaced all my stock speakers with Polk db651s' and the fronts seem louder and fuller than the rear.
OK, I've rambled enough, but I'm pretty psyched about getting this stock unit to sound way better than factory.
Thanks for your input so far!!
  #4 (permalink)
Old 07-03-2009, 09:51 PM
Thanks much for the info. I punched through a large grommet on the driver's side and after 1 1/2 hours and plenty of sweat and swearing my ass off, I got it!!! I was able to tap the head unit and route all the wires to under the LT backseat without breaking any trim tabs or breaking anything.
This web-site help me get all the info to tackle this project myself. I don't want to say how many hours it took, but I've learned a whole lot!!
Reply
Tags
07, 09, 2009, batteries, battery, california, company, firewall, fit, honda, membershotmailcom, powered, subs, subwoofer, wire, wiring
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2007 Honda Fit: Original battery dead at two years Sibyl 1st Generation (GD 01-08) 74 11-17-2009 05:33 PM
What is the cold cranking amps for 07 stock battery? jchcmax Fit DIY: Repair & Maintenance 5 12-18-2008 09:14 PM
Need more POWER gthumb23 Fit I.C.E. 30 05-30-2008 10:53 PM
question regarding battery behavior d_cymbal@hotmail.com Other Car Related Discussions 4 08-28-2005 12:31 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
