P2R B-Spec Honda Fit
So we decided to get a head start on setting up a car for the new B-Spec race class. We picked up a 2010 HondaFit 5 speed Base Model. Here are two pictures of the car.
Here is the baseline dyno of the car. Since there are no rulebooks out for the car. We are going to leave the engine completely stock until we find out some more information. We did 3 pulls, but all of them came up with the exact same HP & TQ numbers. These pulls were done in 3rd gear.
Roll Cage is in. HEre are 2 pictures of how the cage came out
We are trying to get the car ready to race in the FARA @ Homestead Miami Speedway on June 4, 2011. In case any of you are interested in coming out and seeing us race the car. Here is a flyer that if you print out, admission is only $10.
B-Spec is conceived to be a low budget racing class. (If there ever was such a thing.) In view of that concept, there has been some serious discussion about mandating bolt-in roll cages. There has also been serious discussion about limiting tire size to 185/50-15s. Between the bolt-in cage and the skinny tires, there would be no advantage to someone using extravagant (relevant) suspension upgrades. Thus, keeping the costs down and rewarding driving skill. Isn't that the way it should be?
B Spec itself is not a race series, its actually a race class that will be incorporated into different race series. So safety equipment is actually based on which series you are trying to race the car in. About the suspension, If you plan to race and receive the Honda contingency pay outs, you will need to run the Honda Racing Suspension which will shortly be released. They are actually going to offer a complete race package. I will post up some more details on our car later today.
nice car! got a few questions
1. where the rear cage legs meet, why did you guys choose on top of the spring perch? I know that is where all the work is done but i would like to hear your reasoning. J's racing also did this.
2. Are you competing B spec in that event you posted? If so, isnt the cage sitting to low? I read somewhere that it has to extend all the way to the roof lining. Im sure you did it for less top heavy weight but I thought this was against scca or nasa regs.
3. Why did you guys not go behind the dash with the A pillar legs?
Not starting a fight, just wondering for personal interest. Thanks!
The cage goes all the way up to the roof lining. You can hardly fit a credit card between the roll cage and the roof. Maybe its the picture that makes it seem lower than that.
We connect to the spring perch because its normally ideal to connect the cage to the suspension points. Plus the flooring is pretty solid there , so the roll cage point is pretty strong right there.
The event we are racing is just for testing purposes, its not B spec. We actually will be racing in a class called MP4B, which is for cars up to 1.6 liters.
Last but not least, we didn't go any further back into the dash board because of the way the floor is shaped. The flooring on the Fit is really unusual. I guess for one since the gas tank is below the front seats, the floor ramps up right there, and then with the dash board, the floor ramps up very early as well, so if you try to go any further back with the roll cage, you will be on a weird angle.
Honda Racing Fit roll cage is pretty similar to this as well. Here are 2 pictures of there cage.
I was just wondering. I managed to have my front A pillar legs go behind the dash and welded to the front fender well. the front legs are also welded completely to the A pillar.
hard to see here cause the pic was not for the cage but you can see a little
Maybe the 2nd gen fit is a little different <_>
Its cause it wouldn't be fair and the GD3 would be like CHEAT CODES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!! lol
"dang man! I didn't know your GD3 came with a game genie."
Ya, that makes sense. Guess I will have to stick to my small time events. Regardless, looking forward to seeing a great build and products from you guys!
