L15A Aftermarket High Profile Camshafts
Old 10-19-2012, 05:26 PM
jdmkira's Avatar
I've done a little searching on the forums and google but I couldn't find anyone who makes higher profile camshafts for the Fit. The only post I read regarding to this was about a Bisimoto Rep saying that they were planning on making specified camshafts for the fit, but that was in 2010 and I've checked their site with no luck.
I tried sending him an e-mail but his box is full, so I'm wondering if anyone knows where I can get a higher profile camshaft for my 07 Fit. Not looking for anything too big, maybe a stage 1. I want to try and keep it as close to OEM as possible with a little more power.
Old 12-06-2012, 05:47 AM
ZaxMan's Avatar
VAC company in Pennsilvania makes a Cat Cam for 07 and 08 . Street cam to be used with stock settings and Sport Cam that requires a tune . They told me they making these for GE8's soon . About 600 bucks for cam
Old 12-06-2012, 11:32 AM
TPColgett's Avatar
Any one have a direct contact with a Cat Cam supplier?
Old 12-06-2012, 12:19 PM
Wafulz's Avatar
so thats how tyler Feels Ehh DAM UUUU <3 sup bro debateing over SF or SD for new years lol how the weather out there fogy lol
Old 12-06-2012, 01:00 PM
TPColgett's Avatar
Took 5 min, looks like at least in the USA that these guys are the only listed importer for Cat Cams:
http://store.vacmotorsports.com/abou...ons-p1980.aspx
Old 12-07-2012, 08:08 AM
gynosis's Avatar
JUN make cams for the L15A as well
Old 12-07-2012, 11:42 AM
TPColgett's Avatar
Any chance you can point me to a link? Do they distribute to the US?
Old 12-07-2012, 01:43 PM
TPColgett's Avatar
Hmm, after reading this thread https://www.fitfreak.net/forums/2nd-...bang-buck.html
and then reading JUN's actual site
JUN AUTO - JUN HIGH LIFT CAMSHAFTS and Kit - HONDA L15A/LEA
They appear to offer a cam for both the GD and the GE, BUT it's only a re grind... Which DSM breaks down about half way down the page on the first link why I would avoid this...
the GD cam from Jun is a 252/252 and is a regrind (OEM is 235/251).
In comparison CAT has a BIG list of cams and they are either "chilled cast iron" or "steel billet."
(CAT lists these as "ok" with OEM internals the first two are listed as "sport" and the third is a "turbo")
263/259
290/272
290/259
(all of these are listed as Rally & Cross or Rally & Race and "require" springs and retainers)
292/288
296/288
309/292
Here is a the link to Cat Cams in English, but it ONLY appears to work in an Internet Explorer browser CATCAMS racing parts [camshafts-valve springs-retainers-connecting rods]
WHEN I get to this part of my build.... I am planning to go with a Cat Cam...
Old 12-07-2012, 02:42 PM
FitStir's Avatar
maybe this?
Not sure if it's a swap possibility, but the 2013 JDM CR-Z engine supposedly got an upgraded high rpm cam... if the LEA is similar enough to the L15A, that might be a good option.
from this thread --> http://www.crzforum.com/forum/honda-...da-site-5.html
Originally Posted by human668
The spec page on Honda web site is not valid. There are some spec don't match with press info, redline rpm is one of those. Beside that, if you look at the speedometer photo, it's clearly shown the redline remains at 6300rpm, not 7000rpm. Unlike JDM ZF2 which has a high rpm cam (6800 redline) , USDM ZF2 is still using 12V/16V iVTEC.
6800rpm
- USDM ZF2 redline: 6300rpm HP: 130@6000rpm
- JDM (perhaps EDM too) ZF2 redline: 6800rpm HP: ~135.1@6600rpm (137PS)
- American Honda once again messed up with their web site. Please refer to the press page.
- I don't know how to make it more clear. I'm stupid.
The main difference is on the engine. JDM and EDM's engine (alone) makes the same power as the L15 from Fit. All time 16V high rpm iVTEC.
Honda CR-Z Hybrid | Book Test Drive | Specification, Finance & Information
"The 1.5-litre petrol engine sees an increase in power to 121 PS, while the electric motor now features a Lithium Ion battery for a 20 PS (15 kW) increase giving you a total output of 137 PS with emissions as low as 116g/km. When the battery is more than 50% charged, the new Plus Sport (S+) boost system can deliver increased acceleration for up to ten seconds."
Old 12-07-2012, 02:47 PM
TPColgett's Avatar
That MIGHT work in a GE...
But at this point, I have my FlashPro and a redline @7200 on the GD. I'm still working on other "bolt on" I/H/E options and finalized tuning to show to people before I start my big project. "Big project" most likely wont have anything to show till 2014 though. I have to keep my car in spec for my current SCCA class, however due to low participation, I will probably have to jump classes in 2014 if I intend to compete at nationals.
Old 08-01-2013, 04:08 AM
fit_racer's Avatar
I have grind my own hi-profile cam back in 07 when I raced my fit. Doesn't work too well. I am not sure too high profile of didn't degree the cam right. I bend couple valves.
Old 08-02-2013, 02:12 AM
loudbang's Avatar
Bending valves comes from over revving or not enough clearance between the valves and piston top with higher lift.
Old 01-04-2014, 10:25 AM
devmail's Avatar
I'm interested in eventually trying one of the first 2 sport cat cams usable with OEM internals, but does anyone know if there is an adjustable cam gear available?
Old 01-04-2014, 02:30 PM
TPColgett's Avatar
So far there is no commercially available adjustable camgear.
I know DSM was talking with a few places, but I never saw the results...
Also, it would be awful hard to adjust that sucker... being chain driven I don't think you can exactly cut a timing cover like they do on other Honda's, you'd just create a massive oil leak. Every time tobadjust you would have to take off the upper intake manifold and the valve cover.
Still, if you could have one made, degree the cam in right and tune it with FlashPro you would have a sweet ride for sure
Old 01-04-2014, 02:59 PM
13fit's Avatar
go get a reground cam. some companies who do minor profiles to work with stock ecu will cut into the base of the cam, and you just do a valve adjustment to get the clearance back in spec. usually this is for less then 5% lift increase.
I have had great success with both crower and delta regrinds. in those times I had them made, they did what is called spatter welding. They actually spattered melted metal over the cam lobe, then ground it back smooth. Usually they had to spatter weld several times on the same lobe, as they only would gain maybe a paper's thickness. Its a delicate process. But spatter welding ensures good contact and very thorough welding of the surface to make it just as strong as the factory cam surface
Old 01-06-2014, 09:52 PM
263/259
290/272
290/259
292/288
296/288
309/292
Searching the forums for "cams" and look who and what I find. LOL
You and I might be on a similar quest with our Fit's.
Good info from all.
Old 02-13-2014, 11:36 AM
devmail's Avatar
Any updates on these cams, has anyone tried them yet?
Koup
05-27-2018 01:03 AM
sbualuba
19
09-02-2016 10:43 PM
cnordt24
14
09-22-2014 07:10 PM
clanbuster
10-21-2009 01:01 PM
Cat
02-08-2009 08:09 AM
Quick Reply: L15A Aftermarket High Profile Camshafts
