Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > ECO-Fit Discussion
ECO-Fit Discussion Threads discussing the pursuit of ultimate economy, hypermiling techniques & maximizing your MPG
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1161 (permalink)
Old 07-20-2009, 12:28 PM
elohel is an unknown quantity at this point
^ Now that is impressive
  #1162 (permalink)
Old 07-20-2009, 12:45 PM
RichXKU's Avatar
RichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to liveRichXKU relies on Rep Points to live
Send a message via AIM to RichXKU
41-42 is right on the money of where a normally driven Fit should be, probably even better since the 09+ are geared shorter. Keep up the good work
I just filled up: 45.1 MPG.
That's 534.2 miles/tank for those keeping score at home...
I think the Mishimoto CF shorty intake has helped due to higher intake temps.
  #1163 (permalink)
Old 07-20-2009, 11:05 PM
SCBarren's Avatar
SCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to liveSCBarren relies on Rep Points to live
Send a message via AIM to SCBarren
Hmm, I should look into the intake possibilities. I'd love to achieve even 500 miles on my tank. Is that after running it past empty? Or was this at the point of the gas light turning on? That would blow mah mind! But I'm still damned happy with even 40+ xD.
__________________
"And you run, and you run to catch up with the sun, but it's sinking. Racing around to come up behind you again."
  #1164 (permalink)
Old 07-20-2009, 11:49 PM
RichXKU's Avatar
That was about 10 or 15 miles after the gas light came on. But that also included filling almost to near the top. You can "fit" about 2 gallons more after the pump clicks off, it just takes a bit of time, because you have to wait for the foam to go down.
I can usually drive about 150-160 miles from "pegged" to the "F" slash.
Anyway, keep up the good work man!
  #1165 (permalink)
Old 07-21-2009, 12:20 AM
SCBarren's Avatar
Will keep this in mind for future road trip events
__________________
  #1166 (permalink)
Old 07-21-2009, 12:49 AM
Contrabida Face's Avatar
Frequent FitFreak Poster
Contrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to live
i don't know how you guys do it. i average around 32-36mpg with mixed city/highway. the highest i've done was ~40-42mpg on my road trip from vallejo, ca to biloxi, ms. i don't drive like a jerk, i drive pretty conservative mostly. where is the best shift point? i usually shift at around 2600-3000. is that too high? i don't want to shift too fast to a higher gear to over load the engine. i wish we had a 6th gear for the freeways.
__________________
-Paul
Quote:
Originally Posted by eldaino View Post
contra's wheels set the standard for twb cars.
  #1167 (permalink)
Old 07-21-2009, 11:40 AM
SCBarren's Avatar
Quote:
Depending on the gear or how fast I'm going I tend to shift a bit lower. Generally around 2000-2200 RPM's, which can be too low at times, so I don't always. But, if I'm doing flat driving I get better MPG's (city speeds) in higher gears.
__________________
  #1168 (permalink)
Old 07-22-2009, 10:13 PM
rickbhill is an unknown quantity at this point
I have filled up 4 times with my new Honda Fit Sport. Every time the electronic average MPG indicator shows my average MPGs to be 2-5MPG more than my odometer/fuel pumped calculations. Is everybody else experiencing the same difference?
Either the electronic indicator is wrong or the gas stations are under pumping gas.
  #1169 (permalink)
Old 07-24-2009, 01:05 PM
SammiJo's Avatar
SammiJo is an unknown quantity at this point
Send a message via AIM to SammiJo
+1.
Getting ready for an 800 mile road trip next week. Will report back with MPG.
My average around town is 36 MPG. And I'm not a conservative driver.
  #1170 (permalink)
Old 07-24-2009, 01:22 PM
anniemcu is an unknown quantity at this point
...i wish we had a 6th gear for the freeways.
Quote:
Originally Posted by SammiJo View Post
+1.
+(another)1
  #1171 (permalink)
Old 07-24-2009, 01:53 PM
RichXKU's Avatar
6th sounds great but what we really need is just a longer 5th. All they would do with a 6 speed is copy and paste the ratio for 5th to 6th, then make 2-5 shorter.
Honda is prioritizing peppy over MPG in the Fit, the 09s have an even shorter highway gearing than the 07-08.
--Begin real math--
07-08:
5th: 0.757
Final: 4.294
3.25 engine revs per axle rotation in 07-08
09:
5th: 0.727
Final: 4.62
3.36 engine revs per axle rotation in 09.
So the 09s are revving 3.3% higher than the 07-08, and get only 93.5% of the combined fuel economy of the 07-08
--End real math--
If I extrapolate, then the 2039 fit will probably get around 9 MPG and be at 7613 RPM on the highway.
  #1172 (permalink)
Old 07-24-2009, 02:16 PM
SammiJo's Avatar
2345
  #1173 (permalink)
Old 07-24-2009, 02:17 PM
honda2112's Avatar
honda2112 is on a distinguished road
Beginning of the month trip to NYC from South Hadley, MA: moved a friend from Queens to Brooklyn, drove around both cities with stop and go around rush hour then back=43mpg. Week after to the beach in New Hampshire to Newbury Port then back home= 42 mpg. Work week, 15% highway= 39.7mpg. Not too shabby!
  #1174 (permalink)
Old 07-24-2009, 02:42 PM
Texas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to live
I believe I read that the U.S. market Fits have been geared lower because of the added weight to meet safety requirements, lower octane fuel and fat people not to mention the obsession with 0 to 60 times..... British motorcycles were geared lower for the U.S. and Harley-Davidson put an international belt pulley and shorter drive belt on the big twins sold overseas.
  #1175 (permalink)
Old 07-25-2009, 07:29 PM
Black01's Avatar
Black01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to live
I just filled up. I know this is not impressive but 339.9 and refilled 8.158 = 41.66mpg. This is driving the car hard, hitting VTEC and sometime going 5k-6k rpms. This is excellent mpg for a Fit driven hard.
__________________
MR Fit
K&N Drop in Air Filter
Windows tinted
OEM All season floor mats
Cargo Tray
2008 Honda Fit Full Specifications
  #1176 (permalink)
Old 07-25-2009, 07:46 PM
wdb's Avatar
wdb wdb is offline
wdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to live
It's the electronics. Gas station pumps are tested by duh gummint every so often, and it really doesn't pay them to cheat.
  #1177 (permalink)
Old 07-30-2009, 07:09 PM
kirsch92 is an unknown quantity at this point
Happy after First Tank
09 Taffeta White Sport 5MT 1st Tank
Mileage indicator read 45.9 mpg
Actual mileage was 40.26 mpg
Mostly highway driving, but a lot of up and down hills.
Light foot on the go pedal with tach 2k-3K seems to work best.
A/C really works that tiny motor too.
A light car and short gearing really hurts it on the downhills.
I think neutral coasting would really boost the mileage on the downhills.
I have a 2 mile downhill where the Fit slows down on a 5th gear coast.
My 04 Odyssey is accelerating on its own and would be happy to be doing 75 without some braking to keep it in check.
  #1178 (permalink)
Old 07-30-2009, 07:15 PM
Unbelieveable! And that is completely stock? I just tested my 5th tank: 26.3MPG (all city driving). Still the best I've reached was 33.5MPG (Mostly highway with A/C use). I switched from neutral coasting to coasting in gear when possible because I've been told the computer shuts off fuel injection at those points.
I don't even look at the electronic mileage indicator anymore because it is always 3-5MPG higher than when calculated at the pump. Definitely an unsatisfying add-on by Honda. I would have rather they left it out and saved me the money.
  #1179 (permalink)
Old 07-30-2009, 10:47 PM
Completely stock. I drive to and from work at odd hours, with only a few lights on the drive.
I know a lot of people don't like the real-time mileage bar, but it seems to remind me to keep a light foot on the gas.
I mostly coasted in gear, but I found I was losing a lot of speed doing so, so I experimented with neutral coasting. I was having to accelerate too much at the end of the downhill. I've been minimizing the A/C usage.
My 2nd tank isn't looking as good though. I went into Seattle for a Mariners game. Between the heat and the traffic, I think I am going to lose a few MPG. Plus I have a twisty back road I just HAD to try out on the way to work.
My real time bar spent a lot more time near the 20 MPG mark on that trip
  #1180 (permalink)
Old 08-02-2009, 01:07 AM
nerual13's Avatar
nerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to livenerual13 relies on Rep Points to live
First fill tonight, actual was 31.8, though the gauge read 36.9, so not sure what that is about. But, not bad compared to the 14 or 15 on my old Jeep. Stock, brand new Sport M/T that I've been taking out joyriding to break her in
__________________
2009 Fit Sport M/T Blackberry Pearl
born July 27, 2009
I work for a small fruit company 
Reply
Tags
18901, actual, fit, fitfreak, gas, honda, indicator, manual, milage, mileage, report, road, standard, transmission, trip
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mileage reports: Automatic transmission (5AT) shipwrek ECO-Fit Discussion 1389 Yesterday 02:20 PM
Is Honda manufacturing manual transmission Fits? Tom Cliff Tell Honda 36 08-25-2009 11:12 PM
Long (!) review of automatic vs. manual Fit Sport (US) Wessy General Fit Talk 235 03-13-2009 01:23 AM
USA Fit Specs. Honda press release claymore Front Page News 3 04-28-2006 10:59 AM
Auto vs manual mileage debate Gordio General Fit Talk 36 04-19-2006 04:50 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
