Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > ECO-Fit Discussion
ECO-Fit Discussion Threads discussing the pursuit of ultimate economy, hypermiling techniques & maximizing your MPG
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-07-2008, 05:40 PM
JCLW will become famous soon enough
Measuring fuel by energy content instead of volume
I ran into a discussion of another board titled "How should the MPG of electric cars be measured?" which got me thinking, and led to the following reply. Not only would this way allow people to directly compare between vehicles with different power sources (ie: gasoline/diesel/electricity) but it would also show the differences between burning (for example) straight gasoline vs a gas/ethanol mix.
Quote:
Originally Posted by JCLW
In my opinion:
The fundamental problem is that traditionally we're measuring the wrong thing. We should be measuring Energy (kW), not Volume (litres or gallons).
It takes a certain amount of Energy to move my car 100km. When I go to fill it up, I'm buying energy. I don't really care how much space the energy takes (within reason of course).
Energy content of common liquid fuels:
Diesel: 41 MegaJoules/litre = 11.4 kiloWatthours/litre
Gasoline: 32 MJ/l = 8.9 kWh/l
E10: 28 MJ/l = 7.8 kWh/l
E85: 22 MJ/l = 6.1 KWh/l
E100: 20 MJ/l = 5.6 kWh/l
I drive a Honda Fit, which we'll say (for example) can run on gasoline or E10.
The fuel tank holds 40 litres, which is 356kWh of gasoline, or 312kWh of E10.
My lifetime fuel economy is roughly 7.3 litres/100km using gasoline, or 65.0kWh/100km.
So I can run 547km on a tank of gasoline, or 480km on a tank of E10.
When I go to fill up, I see one station selling gasoline for $1.20/litre = $1.20/8.9kWh = $0.135/kWh
Across the street, I see another station selling E10 for $1.15/litre = $1.15/7.8kWh = $0.147/kWh
Obviously the gasoline is a better deal when you look at energy content/volume, even when $/volume is more expensive.
Now let's say electricity costs $0.120/kWh. With an 88% efficient charging system your cost to put electricity in the car is $0.136/kWh. In terms of price per energy, you may notice that this is almost exactly the same price as gasoline.
But the electric drive system is much more efficient then the internal combustion engine. Using rough figures from the Prius PHEV (Plug-in Hybrid Electric Vehicle) kits, let's say my Fit is offered with a PHEV system that runs 50km on a 5kWh battery pack. So on electric drive I would get 10kWh/100km.
This is 6.5 times more efficient then the internal combustion engine.
So how do I think the marketing should work?
Gasoline Fit should read:
Energy efficiency (1.5l spark ignition engine): 65.0kWh/100km
Energy capacity / range (gasoline): 356kWh / 547km
Energy capacity / range (E10): 312kWh / 480km
Energy capacity / range (E85): 244kWh / 375km *(This line only if the engine could run on E85)*
Diesel Fit should read (if one existed):
Energy efficiency (1.2l compression ignition engine): 62.0kWh/100km
Energy capacity / range (diesel): 456kWh / 735km
Hybrid Fit should read:
Energy efficiency (electric motor): 10.0kWh/100km
Energy capacity / range (electricity): 5kWh / 50km
Electric Fit should read:
Energy capacity / range (electricity): 16kWh / 160km *(I'm assuming an electric only car would have a bigger battery pack)*
Also, I believe gas stations should have to list guaranteed energy content for fuel, and sell it by $/kWh.
So you'd see signs such as:
Diesel (41MJ/l) = $0.119/kWh
Regular 85 (32MJ/l) = $0.139/kWh
Supreme 89 (32MJ/l) = $0.147/kWh
E10 (28MJ/l) = $0.143/kWh
E85 (22MJ/l) = $0.145/kWh
This would be a big change for a lot of people, but it is the only way I can see to accurately compare different kinds of cars. It also stops gas stations from selling blended fuel for the same price as gasoline (and then people wonder why their fuel economy drops).
And you could still do it in terms of MJ/gallon & kWh/mile or mile/kWh or whatever.
The original thread was brought about by this article: http://money.cnn.com/2008/09/15/auto...ings/index.htm
What do you guys think?
Sponsored Links
  #2 (permalink)
Old 10-08-2008, 11:19 PM
pcs0snq's Avatar
pcs0snq has a spectacular aura aboutpcs0snq has a spectacular aura about
Quote:
I have looked at this for plug in's.
IMHO it's best to keep it in MPG when talking cars. It's the true std for now
Find out the kw-hrs/mile is and the cost per kw-hr.
Once you have cost per mile, convert that to MPG based on the going cost of gas.
I did this for the GM Volt and it's around 220mpg with ele at $.15/kw-hr and gas at $3.5/gal
__________________
Paul
2008 VBP Fit Sport Man 5 spd trans
208US Gal saved in the last 20,000miles
  #3 (permalink)
Old 10-08-2008, 11:23 PM
kylerwho's Avatar
spoon fed
kylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to live
Send a message via Yahoo to kylerwho
i understand what is being said but your average person will not understand how to figure out how efficient their car is as an energy converter. mpg is just simpler.
__________________
high roller #7
Quote:
Originally Posted by dewthedew View Post
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
  #4 (permalink)
Old 11-08-2008, 02:34 AM
zukered's Avatar
zukered has a spectacular aura aboutzukered has a spectacular aura about
That's pretty interesting. I've read that this line of thought is precisely why most metric countries measure fuel efficiency in L/100 km, and not km/L. I myself don't like using it; it's awkward to say, and you want to have *lower* numbers, which goes against most performance instincts where higher/bigger is better.
__________________
Reply
Tags
capacity, combustion, content, convert, diesel, economy, energy, engine, fit, fuel, gas, honda, internal, kwh, kwh100km, metric, prius
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Complete OBD II Codes List sLiVeRwOrM Fit DIY: Repair & Maintenance 13 02-14-2009 06:22 PM
P&G does not save fuel pcs0snq ECO-Fit Discussion 134 07-24-2008 12:33 AM
Filling up the Fit To the top or not?? Rdean58 ECO-Fit Discussion 17 07-26-2007 03:47 AM
How hard to replace pipe connecting to fuel filter Ed Other Car Related Discussions 3 09-15-2005 11:30 AM
Civic Hybrid -- gas/electric usage Jeff Other Car Related Discussions 28 09-03-2005 02:30 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
