ECO-Fit DiscussionThreads discussing the pursuit of ultimate economy, hypermiling techniques & maximizing your MPG
Welcome to Fit Freak!
Welcome to Fit Freak,
I have heard the gas tank noise also no biggie there. I also think the FIT feels weird when I hit the breaks sometimes. I figured it was just me coming from a race setup DC 5 with custom breaks.
I figured the breaking issue was 1 new pads and 2 drum rear rear breaks. I have not had drum breaks for about 5 years. So I don't know but I do understand what you say the car feels a bit scary when I have to moderately hit the breaks. It is probably me just getting use to the car since I only have had it for 3 weeks tomorrow
yeah, I agree w/ rekcah, it could also be you getting used to the brakes on the car + new pads. I've had mine now for just going on a year next week, so to me a lot of that faded into the past and the car is like a pair of comfortable shoes -- it just feels right and familiar at this point now. More than likely you and it will settle into yourselves over time and things will start to smooth out and feel more natural and predictable.
__________________
'07 Vivid Blue Pearl Sport w/stuff attached in useful places
race setup dc5 custom breaks?? wow... rsx owners that cant even tell the difference between breaks and brakes. shocking....
I had this same gurgling after putting on a T1R intake. When you install that aftermarket intake, you disconnect a hose going to the throttle body, allowing air to get into the system. I imagine most if not all the aftermarket intakes include this step, so if you recently installed an intake that is where the gurgling is coming from. It persisted occasionally for several days and when I rechecked the coolant level it was low so I topped it off. It has not happened since. I hope this helps some of you.
I had the same problem after i installed my Fujita CAI.
I can't remember who, but someone in the forum suggested to open the radiator cap and turn the car on. Turn on your A/C and let the radiator fan go on and off a couple of times. Leave the cap off for about 3-5 minutes. This will bleed the air out of your system. You may see the air leave the radiator top as small bubbles or just see the radiator fluid level rise and fall near the neck of the radiator top.
After I did this, the sound went away for the most part. I used to hear it driving < 30mph, but now I don't hear it anymore.
With a good Maynard Ferguson CD going, you'll never hear the gas sloshing! Charlie Parker also works real well too. But I'd definitely avoid Kenny G! Rather hear the slosh than Mr. Gorelick!
Really, the slosh sound is barely noticable in a quiet garage with the audio turned off.
Reason: Typo
Hi,
A while back I read in this forum that some Fit owners claimed they could hear and/or feel the gas sloshing around in the tank under the driver's seat. Is that correct?
Allen
Hi Allen:
I can hear (slightly) and feel (barely) the gas in the tank only when I pull into the garage verrrrry sloooowly. It would have to be totally silent in the car, no radio or chattering kiddos. I have never heard it/felt it any other time.
No worries~
__________________
Heather
2007 BOM Sport AT
~Dream Come True~ I am loving this car....
Ok - this is something I just found out about a few days ago. I never knew that the gas tank was under the drivers seat. This thought bothers me and now that I am reading you can feel and hear the gas sloshing - it really bothers me. With the tank being so near to the engine what type of steps did Honda take to insure that the tank is safer in that location. I am seriously rethinking my purchase of the Fit because of this. I use to drive an exploding Ford Pinto back in the days and don't want to go back to that nightmare! Any idea of what safety factors Honda took to make this work?
Cat
If your gas tank explodes, you have bigger problems to worry about than whether it is directly under you or 4 feet behind you.
I never noticed it until my friend said something. Normally I have the radio up loud enough but when I backed into the garage she's like, "what was that?" I didn't have the radio on and noticed it. I don't think I ever heard it before.
Cat
GAs only ignites with oxygen. I don't think a gas tank explodes from within. If you ever get into a terrible wreckage, where the tank punctures (and fire is present) is where the flames will shoot out.
Note that on "regular" cars, the gas tank is under the back seats. My guess (don't cite me) is the gas tank is stronger than most. I also am guessing it's smaller than average capacity (10-11 gallons) has to do with safety.
But one thing I am sure of is they did address this problem a long time ago when talking about this car. I remember being concerned, and reading about what Honda says about it.
Cat
I really don't think you've got much to worry about. There are literally hundreds of thousands of Fit's on the road for near 7 years now w/o one single issue to ever come up from the tank position. Honda basically has it in a reinforced "cage" in the frame that pretty much has it completely surrounded. It also has a shield over it on the undercarriageto protect it from road debris, etc. The sound of the gas moving is really overblown -- it's not like it's constant, only under certain times like if the tank was just filled and even then it's not often or pronounced. If you been hit hard enough to puncture the tank, you're already probably dead or near to it just from the impact alone, so it's really a moot point in that sense.
__________________
I know Fit has fuel tank under the driver/passenger seats..
i was driving home yester day and hearing fuel moving sound underneath, i began to think "Isn't gonna be more dangerous in accident since fuel tank is closer to driver/passenger"?
basically i am sitting on fuel tank... lol
i am sure Honda tested the safety for Fit's design.. well.. i had to share this thought...
__________________
MR Honda Fit Sport Automatic
2007 FIT Sport "The Honda that ZIGS"
***SOLD for $14K after 22K miles**** *NOT FAST BUT FUN TO DRIVE*
It is not more dangerous. If you really think about where are the most common places you would get hit? front/rear. Having the gastank in the rear is more likely to have it hit during a collision making it more likely to rupture.
