Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Eco FIT
Eco FIT Fit for Fuel! Got the low mileage blues? Care to share a 40+mpg tale? Automatic vs. Manual? Come here to discuss topics on fuel efficiency and other Green Topics
Reply
  #1 (permalink)
Old 06-22-2007, 09:51 PM
charliehart1 is an unknown quantity at this point
what is the best way to drive to get the most mpg?
i drive a 5speed honda fit sport
i am fairly new to stick i had one back in the day but i never paid attention to mpg and now i am wondering what is the best way to drive
what rpm to shift at ect ect
Sponsored Links
  #2 (permalink)
Old 06-23-2007, 12:48 AM
dank24's Avatar
dank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the rough
I shift at 2k, and use the cruise control as often as possible. I am avg 35-39 mpg
  #3 (permalink)
Old 06-23-2007, 12:45 PM
2 k really wow ... the only thing that sucks is that is a boring ass way to drive
  #4 (permalink)
Old 06-23-2007, 06:45 PM
Misha is on a distinguished road
Torque line is flat from 2500 - 3500 rpm , that would be optimal rpm range for normal / sensible driving.
  #5 (permalink)
Old 06-25-2007, 01:36 PM
kps kps is offline
Honda Fit Forums Moderator
kps will become famous soon enough
Cruise in the highest possible gear; shift early (2.5K or less if conditions allow). Accelerating hard to get into high gear sooner is fine. Where traffic permits, accelerating quickly and then coasting in neutral (or declutched) is particularly efficient. Likewise roll downhill to pick up speed for the next uphill. The car uses no fuel while engine braking; use it to coast toward a stop or if you'd roll too fast downhill. Using the brakes is throwing energy away; do it as little as possible.
  #6 (permalink)
Old 06-25-2007, 01:57 PM
I Am Ray.'s Avatar
The One With HoBo Stab Insurance.
I Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to live
All of those above would be true if you drive like that for a month; the ECU will then learn thats how you drive.
My ECU knows that I drive with a slight heavy foot. If I drive like they explained above I cant break 100miles before 3/4 tank. If I shift at 3000-4200rpms with slight/sorta heavy foot then I get 33mpg city WITH a/c on.
If I drive like a beeeech, I get 29mpg. No more. Its happening right now. I didnt even break 200miles at half tank. Ughh!
__________________
- KillerFit #2 -
- The Originator -
  #7 (permalink)
Old 06-25-2007, 10:25 PM
dank24's Avatar
I reach 230-240miles at half tank driving the way i do
  #8 (permalink)
Old 06-25-2007, 10:51 PM
I Am Ray.'s Avatar
I normally hit half with 210-220. Im modded, shift at 4500rpms (sometimes go to redline a few gears)
Im proud of my MPG. I would like to break the 35mpg mark.
__________________
- KillerFit #2 -
- The Originator -
  #9 (permalink)
Old 06-27-2007, 02:41 AM
dank24's Avatar
that is good for taking the revs up
  #10 (permalink)
Old 06-27-2007, 12:13 PM
FITrunner's Avatar
FITrunner is a jewel in the roughFITrunner is a jewel in the roughFITrunner is a jewel in the rough
Downhill, with the wind, and in neutral.
  #11 (permalink)
Old 06-27-2007, 01:37 PM
Gil554's Avatar
Gil554 is on a distinguished road
Depends where you drive as well. My wife is unable to drive less than 10 mph over the speed limit on the freeway. It kills the overall tank.
General stuff has been touched on. Here is my rundown:
1. Cruising in and shifting the lowest gear reasonable
2. Keeping speed (this can be fun too!)
3. Time lights to avoid overt braking
3. Neutral where possible and legal
4. Don't surge (unless its stop and go...you don't need your brakes on the freeway other than emergency situations. If you are using your brakes assess your following distance. Unless of course your in LA then proceed to tap your brakes every few seconds).
5. Don't speed (we drive a toaster...not an autobahn cruiser, high speeds are not good on the ole' mpg o'meter).
6. Don't autox/race (OK yes do it on a closed course...it's worth it!)
This is not comprehensive, and it repeats others as well. I use the above comments on myself on a daily basis to try and slow down, be safe, and save money. I drive like a little old man around town and autox on the weekends (helps get those redline urges out). Avg 37mpg combined city/hwy/autox
Gil
  #12 (permalink)
Old 07-04-2007, 03:28 PM
MINI-Fit's Avatar
Frequent FitFreak Poster
MINI-Fit will become famous soon enough
Keep your air filter clean
Keep your tire pressure up at the right level
Use a manual transmission for best results but if you have the automatic, let it shift automatically- don't assume you can control the gears for high mpg better.
Don't carry lots of heavy things in your car all the time- travel light
Don't let others drive the car if they don't observe the rules above.
Don't put on a roof rack and pile up stuff to increase wind drag.
Don't order extra wide and large aftermarket wheels and tires.
  #13 (permalink)
Old 07-12-2007, 12:07 PM
cool_one556 is on a distinguished road
I have never gotten anything more than 160 miles or so at the half tank mark, on average I'm at about 130 half way.
Reply
« 40+ Mpg | Hydrogen »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drive by wire?? aveosam General Fit Talk 14 12-15-2006 12:10 AM
Manual test drive review mustangguy72 General Fit Talk 10 05-09-2006 12:47 PM
Fit Ride & Drive Report pahondadealer General Fit Talk 11 04-15-2006 05:08 PM
NY Go Kart Racing - This Saturday - Arrive & Drive!! OVRPNY Other Car Related Discussions 0 05-28-2005 05:41 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
