Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #41 (permalink)
Old 04-20-2008, 05:36 AM
QuickGD3's Avatar
QuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to liveQuickGD3 relies on Rep Points to live
Send a message via AIM to QuickGD3
I got one of these intakes and im getting 35mpg with the intake. i was getting 31-33mpg with the stock intake.
  #42 (permalink)
Old 04-22-2008, 11:24 AM
jsensk has a spectacular aura aboutjsensk has a spectacular aura about
Quote:
Originally Posted by LastDance View Post
How do we maintain this filter?
E-mail A&J Racing to inquire about filters/maintenance/replacement.
__________________
Trying to do it right.
KRAFTWERKS Kit Owner #10
  #43 (permalink)
Old 06-25-2008, 12:11 PM
jdmfit88's Avatar
jdmfit88 will become famous soon enough
Send a message via AIM to jdmfit88
hey man great DIY. did it in like a 45min........ thanks
__________________
Mugen(Visors, Door Sills, Oil Cap-Red, Radiator Cap, 2 Reserve Tank Cover, license plate Frame, Rear Wing Spoiler) CF Manifold Cover, Benen Rear Tow Hook, ASPEC Axle-Back Exhaust, 20% Tints, LED TailLight Red/Smoked, All Red Hazard Switch, PassSide Visor w/ Mirror, Type R Key Cover, C-Pillar Strut Bar, T1R B-Max CF Intake, Type R Emblem Rear, Takata shoulder pads, Progress Springs & Tokico HP Blue Shocks, Weapon R Engine Damper
  #44 (permalink)
Old 07-03-2008, 10:37 PM
junior40er's Avatar
junior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to livejunior40er relies on Rep Points to live
super easy. I got thisintake and LOVE it. Worth the money.
  #45 (permalink)
Old 07-09-2008, 09:43 AM
rl_nemo is an unknown quantity at this point
Please help
Hi All,
First I want to say this was a great DIY. I'm new at modding and this worked out well for me.
I've got a couple of concerns. First, I didn't take the plastic off the battery but was still able to get the intake in. Yes it's tight, but it did fit. One of the reasons why I didn't take the plastic off the battery (yes, please laugh) was that I wasn't necessarily sure how to disconnect the battery. So if anyone can explain that I'd love to hear it.
Secondly, the thing sits really close to the coolant hose. I even bent the bracket as I could, but I still think it sits way to close.
Finally, I know there's a tight fit in the engine bay, but right now, I feel like I actually lost power/torque/throttle response with this thing. I even performed the idle learn procedure this morning as specified in the fit service manual -- still I feel the same. Anybody have any thoughts as to why this might be? It feels like I've got extra load on the engine, as if the A/C were on. I also get hesitation on the throttle, like the ECU is thinking about things.
If anyone could help me with this I would really appreciate it.
Thanks!
  #46 (permalink)
Old 07-09-2008, 09:51 AM
Fit of RAGE's Avatar
Honda Fit Forums Moderator
Fit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to live
Quote:
Originally Posted by rl_nemo View Post
Hi All,
Thanks!
1) There's a 10mm bolt holding the "+" and "-" terminal on. Just loosen it off.
2) Which coolant hose is it close to? If it's still close to the one where you bent the bracket, you may have to bend the bracket so that it's in a different angle.
3) Make sure that all the sensors are plugged in. Take the car to 4000RPM in 2nd gear, hold it, then hammer it. Tell me if it's still "gutless" or not.
  #47 (permalink)
Old 07-09-2008, 10:22 AM
Ok, I'll do that after work tonight. And yes, it is still close to the one where I bent the bracket. Apparently I didn't bend it enough. I'll have to do that along with taking off the battery plastic, etc. Hopefully that should do it. Is it possible that despite higher RPM gains, we lose a little something in the lower ranges?
  #48 (permalink)
Old 07-09-2008, 03:30 PM
kodo's Avatar
kodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to live
any trick to removing the bolt that is by the radiator cap?
having hard time removing it.
__________________
  #49 (permalink)
Old 07-10-2008, 10:35 AM
As far as the bolt by the radiator cap -- I just used an extension and a deep socket, no problems.
So last night I re-installed everything -- after having removed the plastic around the battery and readjusting the coolant hose bracket, everything is much cleaner now.
So, things do seem a bit better with it. However, I noticed in the service manual that after the ECM gets reset ('cause of the battery) there are a number of procedures that should be done, two of which are the Idle Learn Procedure (ILP) and the Crank Learn Procedure (CLP). These are a part of a number of "readiness codes" that are set in the ECM for emissions. The manual explains that if you turn the ignition to ON -- the MIL (check engine indicator) light should come on for fifteen seconds and then disappear, if it blinks five times before disappearing it means that one or more of the emissions "readiness" codes are not "complete." My MIL light blinks 5 times before going out -- anybody else's?
Fact is, these learn procedures are a PIA and I got to think that after a normal amount of driving these procedures would no longer be necessary. I mean, disconnecting your battery shouldn't require 2 hours of learn procedure work -- just doesn't make sense.
Any thoughts?
  #50 (permalink)
Old 07-13-2008, 12:53 AM
silverbulletfit's Avatar
silverbulletfit is a jewel in the roughsilverbulletfit is a jewel in the roughsilverbulletfit is a jewel in the rough
what if it rains? do you need a bypass valve for this intake? im going to order this soon and it rains a lot in new england haha
  #51 (permalink)
Old 07-13-2008, 04:17 AM
Fa1's Avatar
Fa1 Fa1 is offline
Fa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to liveFa1 relies on Rep Points to live
Quote:
You can't hydrolock unless part of your filter is actually submerged, so you should be good unless your expecting 1-2 feet tall water.
  #52 (permalink)
Old 09-29-2008, 06:51 AM
kingsize's Avatar
kingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to livekingsize relies on Rep Points to live
Thanks!
yeah it seems like it doesnt do much but when you open it up above approx 4000 rpms, you can start hearing/feeling the intake kicking in.
__________________
  #53 (permalink)
Old 05-09-2009, 06:23 PM
Contrabida Face's Avatar
Frequent FitFreak Poster
Contrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to liveContrabida Face relies on Rep Points to live
ok, i did the install this morning. i had to unhook my battery and now i have to do the radio code thing. i don't know what that is. can anyone help me?
__________________
-Paul
Quote:
Originally Posted by eldaino View Post
contra's wheels set the standard for twb cars.
  #54 (permalink)
Old 05-10-2009, 10:39 AM
Quote:
The radio code is supposed to be on the driver side wall of the glove box. SOME Fit's have it here, some dont. If not, it shoudl be in your pouch where your manual is. All you have to do is turn the radio on so that it says "CODE" then punch in the code.
  #55 (permalink)
Old 05-10-2009, 03:06 PM
thanks man. you saved me from boredom.
__________________
-Paul
  #56 (permalink)
Old 05-10-2009, 09:34 PM
how do i extend my IAT? it's kinda short on my fit?
__________________
-Paul
  #57 (permalink)
Old 05-11-2009, 02:53 AM
It shouldn't be. I"ve never come across that. THe only things you can really do are:
1) unwrap it from the OEM harness?
2) Cut and extend the wires
  #58 (permalink)
Old 05-27-2009, 05:57 AM
raton's Avatar
raton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to live
Just installed the T1R intake. I like it! Just like yawl said....sucker "screams" @ 4000 RPM. Response feels nice in all the gears too.
I had the H-Fit Supa Sucka prior to this; I liked that intake too, but the tiny screw that held both halves of the chamber intake popped out & I couldn't get any new screw to stay put, so....enter the T1R intake. Can't wait to do some more driving & enjoy the feel.
ps: I got a CEL U0155 after installing the intake. It turned out to be my ScanGuage. Apparently, it does that if the SG is connected to the OBDII port BEFORE you start the car. Just had to disconnect the battery (cleared the code), re-connected the battery, disconnected the SG, restarted the car, re-connected the SG, and CEL was gone. Thank God!
__________________
'08 SSM Sport 5-Speed MT
  #59 (permalink)
Old 05-27-2009, 06:10 AM
kingsize's Avatar
thats great to hear randy! im glad you can feel the response too. i bet it will help a lil bit with SCCA also. i love the deep roar sound the intake makes when you pound it, sounds sweet with my HFP muffler. i just got my headers too, cant wait to put it on
__________________
  #60 (permalink)
Old 05-27-2009, 06:35 AM
raton's Avatar
Quote:
Yeah, looking forward to see how the intake feels @ the next event. Right on! Headers! Sweet!! Hmmm....you got a lot of T1R stuff.
__________________
Reply
Tags
carbon, cf, diy, exhaust, fiber, fit, honda, install, intake, integra, prm, rsx, t1r, tightening, tr1
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
T1R Carbon Intake (Dynoed) Revised ! AJ PwR Jr. AJ-Racing.com 152 07-10-2008 03:21 PM
T1R Carbon Intake (Dynoed) AJ PwR Jr. Fit Engine Modifications, Motor Swaps, ECU Tuning 3 08-01-2006 02:54 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
