Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-22-2007, 07:59 PM
bdhoward is an unknown quantity at this point
Post Change dust/pollen filter (cabin air)
Greetings -- the owners manual does not show where the dust/pollen filter is located.
At 14,000 miles including 2 major cross country trip from Carolinas to SoCal, it is likely pretty funky.
Naturally contacting dealer on phone resulted in a "bring it in" =$$$= rather than any kind of helpful explanation. Arrogant @#$%&'s.
I searched around for obvious panels, removable covers etc. and was stumped. Bet it's somewhere I already checked but missed somehow.
THANKS...
Sponsored Links
  #2 (permalink)
Old 09-22-2007, 08:22 PM
DynamicFit's Avatar
DynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to live
I used to work as a honda tech and in the accords and odysseys they were always behind the glovebox. It will require removing some panels, but can usually be done in about 10 mins if you've done it before. I haven't checked with the Fit yet, but I think there are repair manuals you can look at on the web.
  #3 (permalink)
Old 09-28-2007, 02:09 PM
FrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to liveFrogDaddy relies on Rep Points to live
There are some tabs or slits that need to be broken in the glove box. The allows you to squeeze the glove box inward to let it drop down. The filter is behind that. FYI, don't leave receipts and paper in the glove box it will suck it up it's so close.
  #4 (permalink)
Old 10-09-2007, 10:20 PM
martymcfly's Avatar
martymcfly will become famous soon enough
Send a message via Yahoo to martymcfly Send a message via Skype™ to martymcfly
What is the recommended change interval for this?
Hope this helps - Honda Automotive Parts
  #5 (permalink)
Old 10-10-2007, 02:17 AM
KayJai's Avatar
KayJai is an unknown quantity at this point
Go here:
It's really simply.
http://www.hondafitjazz.com/filter.htm
  #6 (permalink)
Old 10-25-2007, 12:37 AM
m-man@sbcglobal.net is on a distinguished road
about 10K miles or once a year is the avg. schedule
hey on that link with the pictures, my glove box does not have that upper section, is that a euro model or somehting?
  #7 (permalink)
Old 10-25-2007, 09:14 AM
spreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to live
The maintenance minder tells you when it needs changing (change it when you change the engine air filter). I changed mine this week at 27K miles. It was still in pretty good condition and could have gone longer.
  #8 (permalink)
Old 10-29-2007, 10:49 AM
rlhannan is an unknown quantity at this point
Question Where is cabin air filter - 2008 Fit?
My glove box does not have a glove box insert like the service manual at Index of / shows. Can someone provide instructions on finding and changing the filter on 2008 Fit? Really appreciate any pix and details on this. RLH
  #9 (permalink)
Old 11-05-2007, 04:30 PM
Quote:
Hey folks, I'm still looking for some tech info on changing the cabin air filter on my 2008 Fit Sport. My glove box does not have the insert the older service manual shows. Can someone send or post the filter change instructions? Thanks.
  #10 (permalink)
Old 11-05-2007, 05:16 PM
It's behind the glove compartment. To Change it, open the glove box, sqeeze the sides of the glove box to allow the box to "come out" of its housing and dump it's contents onto the floorboard. You will se the white filter housing above the round fan housing. Release the retainers on the sides of this cover and pull it out, you will see the filter.
  #11 (permalink)
Old 08-25-2008, 05:48 PM
doctor J will become famous soon enough
2007 cabine dust and pollen filter DIY
For these who are do not want to be ripped off by the dealer, here is procedure how to change pollen filter in 2007-08 Fit.
1. Empty the glove box;
2. Reach inside, locate the stopper flaps on each side
3. Using both hands simultaneously bend both of them toward the center of the box about an inch
4. Swing open the glove box.
5. Locate filter on the top of the fan housing
6. Press the tabs on the side and remove filter carrier http://farm4.static.flickr.com/3114/...72a416.jpg?v=0
7. Inspect or replace element
http://farm4.static.flickr.com/3227/...0f0881.jpg?v=0
8. Install in reverse order.
No tools needed, takes 320 seconds. Why is the dealer charging $100 for that???
  #12 (permalink)
Old 08-25-2008, 06:12 PM
for those who Really dont want to be ripped, you can buy this filter from Logical Source for $7.00, the dealer wants over $40, i got one and it is exactly the same as the oem, same quality, everything
actually i have the in cabin and the engine air filter, i want to do both, but im waiting for the maitience minder to tell me too, so it stays on schedule
__________________
Best MPG - 44.0
  #13 (permalink)
Old 08-25-2008, 11:40 PM
willy65000 is on a distinguished road
I use the maintience minder for oil changes but would not trust it for pollen and engine air filter intervals. It has every thing to do with how dusty the conditions are where the car is being driven. I was running up and down dirt roads for a week while on vacation and my pollen filter became so clogged that the AC completely stopped blowing. You'll probably just want to give it a visual inspection and then decide.
  #14 (permalink)
Old 08-26-2008, 02:35 AM
Rob22315's Avatar
Rob22315 has a spectacular aura aboutRob22315 has a spectacular aura about
Here's the DIY from this forum on how to change the filter, includes pictures -
http://www.fitfreak.net/forums/fit-y...placement.html
__________________
"Neg-rep'd by Claymore" Crew, Certified Member
VBP Base Fit AT
  #15 (permalink)
Old 08-26-2008, 04:38 AM
wdb's Avatar
wdb wdb is offline
wdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to live
Quote:
Holy moly. Thanks! Bookmarked for posterity.
  #16 (permalink)
Old 08-26-2008, 06:14 PM
WGE WGE is offline
WGE is an unknown quantity at this point
I got some of the TYC cabin air filters from Logical Source. The price is actually something like $7.05. If you order from them make sure they send you the correct filters, TYC 800093P, for the 07-08 Fits. They originally sent me six TYC 800039P's and I had to send them back (we have two Fits, hence the large order). They either had a dyslexic packer of they were upsidedown on the shelf! Nonetheless, they were a very good deal and they are incredibly easy to replace.
  #17 (permalink)
Old 07-21-2009, 12:50 PM
EMC2 is an unknown quantity at this point
AC dust/pollen filter
The dealer recommended that I change the air filter and the A/C dust pollen filter as my car has 43000 km. So I agreed to this (at a cost of over $150).
However, my car does not have A/C. Did I really need to have the dust/pollen filter replaced or did I just get ripped off by the dealer?
  #18 (permalink)
Old 07-21-2009, 01:07 PM
Yea, you were ripped off. Changing the dust pollen filter is a piece of cake. It's behind the glove box on dash (you can find instructions for this lots of places). I buy equivalant air filters and dust pollen filters online. Air filters cost approx $9, and dust pollen filter about $13. Guess your dealer will make payroll this week.
Reply
Tags
2008, air, bdhoward, cabin, changing, conditioning, dust, filter, fit, honda, install, installation, interval, pollen, replacing
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY Oil Change 56k beware hqly Fit DIY: Repair & Maintenance 211 09-06-2009 10:58 PM
Where is the Cabin Filter?? coldstorage5 General Fit Talk 5 06-13-2007 09:39 PM
air conditioner filter (cabin filter) chibitul Other Car Related Discussions 4 10-06-2006 01:44 AM
Civic 2k Cabin filter LesHabs Other Car Related Discussions 2 08-09-2005 11:51 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
