Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 03-03-2008, 10:58 PM
Cazzzidy is on a distinguished road
Rear Night Running Lights broken...
Hello all,
I am trying to wire my fit for a utility trailer with a T-One kit. I have successfully wired the vehicle, but while diagnosing a problem with the trailer wiring, I think I may have blown the fuse for the rear running lights by shorting the brown lead.
The symptoms are:
No rear running lights when the lights are set to on.
Headlights, brake lights, blinkers, etc. are fine.
No voltage on the brown trailer wire when lights are on.
I checked all the small fuses, and they look fine. Does any one have any idea what fuse this circuit is on? Any other ideas?
Thanks,
Cassidy
Sponsored Links
  #2 (permalink)
Old 03-05-2008, 08:01 PM
Wow
No one can tell me what fuse handles the taillight circuit?
Some one has got to know! I can't drive at night!
Cassidy
  #3 (permalink)
Old 03-05-2008, 10:44 PM
billmus86's Avatar
iluvspeedbumps
billmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to livebillmus86 relies on Rep Points to live
Send a message via AIM to billmus86
so the little top portion of the lights dont work?, and the bottom doesnt light- unless the brakes are on? and then only the bottom lights right? the top never lights up now?
only one i know off the top of my head is #1 is reverse lights, (not that-that helps)
and please maybe? (just kidding)
__________________
  #4 (permalink)
Old 09-06-2009, 06:24 AM
Black3sr's Avatar
Black3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to liveBlack3sr relies on Rep Points to live
I know this is an old thread but I think I have the answer. A way back in the 60s I was trying to wire my Austin 1100 for my tent trailer. I had similar problems in that could get all the lights working properly but not all at same time.
It turns out you have 3 lights/circuits on the car - brake, running and signal. On the trailer you have two - running and the other is a combo of brake/signal. So I needed to add a small pair of lights to the trailer to act as signal. Geez I spent a day on it before realizing the problem.
__________________
''Life's tough......it's even tougher if you're stupid.''
My site - http://black3sr.com/
Reply
Tags
brake, broken, fix, lights, rear, running
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
STRUT BARS, rear, front, upper lower questions and answers ken1279 Fit Suspension & Brake Modifications 225 11-02-2009 09:58 AM
DIY rear disc slowcarguy Fit Suspension & Brake Modifications 111 10-05-2009 04:56 PM
You know you're a ricer when... Fit of RAGE Off Topic Discussion 20 09-25-2008 10:48 PM
Rear Shocks - need a new design radareclipse Fit Suspension & Brake Modifications 128 06-01-2008 12:46 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
