Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 11-02-2008, 05:53 PM
throwinafit808's Avatar
throwinafit808 is an unknown quantity at this point
I'm using a 700lbs impact gun what is going on! I notice that the engine keeps turning while we try to get it off and its in gear, I even put my foot on the break but it still just keeps turning. What should i do????
  #22 (permalink)
Old 12-07-2008, 08:54 PM
micro image's Avatar
micro image is a jewel in the roughmicro image is a jewel in the roughmicro image is a jewel in the roughmicro image is a jewel in the rough
Send a message via AIM to micro image
nice DIY -- does anyone know the weight of the T1R pulley?
__________________
Micro Image
~ HONDA FIT PARTS ~
  #23 (permalink)
Old 12-07-2008, 09:37 PM
shazaam's Avatar
shazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to liveshazaam relies on Rep Points to live
Quote:
"The T1R CNC machined from premium Forged T7075 Aluminum billet, and maintains the stock diameter while losing 3.42 lbs from stock which weighs 4.85 lbs to T1R 1.42 lbs."
A&J Racing*::*Engine*::*Pullies*::*T1R Crankshaft Pulley - Honda Fit/Jazz 06-08 (GD3/GD4)
guessin that'll answer yer question.
I'd like to do this...but I'm still savin for coils lol
__________________
if yer lookin for a Fit...$13.5k n an 08' VBP gd3 is yours. Or $4k and a 94' delsol is yours
yumminess
1993 Buick LeSabre - most comfy car...ever.
2008 Honda Fit - funnest and most versatile car...prolly ever.
  #24 (permalink)
Old 12-07-2008, 11:39 PM
awesome, thanks. So the NST pulley is a bit heavier and quite a bit less expensive. You Honda guys always get more choices :smile:
__________________
Micro Image
~ HONDA FIT PARTS ~
  #25 (permalink)
Old 12-18-2008, 11:05 PM
DOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to live
Did it helped on gas??
Marko!!
  #26 (permalink)
Old 12-18-2008, 11:21 PM
Fit of RAGE's Avatar
Honda Fit Forums Moderator
Fit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to live
Quote:
Marko!!
didn't notice anything.
  #27 (permalink)
Old 12-30-2008, 02:32 AM
No_Skillz's Avatar
No_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to liveNo_Skillz relies on Rep Points to live
I doubt that it's going to do anything. A few pounds of rotational weight is negligible compared with the weight of the internals and accessories.
Still, nice DIY info for any underdrive pullies, which might have more of a noticeable result.
Few questions:
1. What is the torque spec on the center bolt of the pulley?
2. Any information if the harmonic balancer is necessary on this motor?
__________________
V8 this...
  #28 (permalink)
Old 08-17-2009, 01:07 AM
Red Diablo is an unknown quantity at this point
how did you remove the drive belt from the car that easy?
__________________
  #29 (permalink)
Old 08-17-2009, 09:59 AM
Quote:
there is 1x 12mm and 1x 14mm bolts that hold the alternator down. plus, youve also got the 10mm adjuster
Reply
Tags
07, 2007, 92, civic, crank, crankshaft, diagram, diy, fit, honda, motor, pulley, pully, system, t1r, tool
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
crankshaft pulley tool 07fitsport Fit DIY: Repair & Maintenance 4 11-21-2009 10:42 PM
GTSpec NEW Parts! Crankshaft Pulley and STB gettinafit Fit Engine Modifications, Motor Swaps, ECU Tuning 37 08-14-2006 08:38 AM
Crankshaft pulley turns but not cam punkyw Other Car Related Discussions 6 05-15-2005 08:30 PM
Honda Crankshaft pulley falls off jjeansonne Other Car Related Discussions 6 05-04-2005 12:16 PM
Crankshaft Pulley Bolt on 1989 Accord SE-i: My story justinreigle (at) gmail (dot) com Other Car Related Discussions 15 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
