Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 08-09-2008, 08:55 PM
Fit of RAGE's Avatar
Honda Fit Forums Moderator
Fit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to live
DIY: T1R Sway-Bar
As usual, AJR, Fitfreak.net nor I (Fit of RAGE!) is responsible for ANY damages, problems to your vehicle. Please be EXTREMELY cautious and
perform this mod at your own discretion.
I kinda got carried away and ended up in "the Zone" when i was doing this so it's kinda a crappy DIY Anyway,
1) Purchase sway bar
2) Personally, i felt that taking the cat out is VERY useful, so remove cat
3) disconnect the sway bar from the link kits. You'll need an Allen head AND a 12mm wrench.
The reason you need to do this is that if you just use a 12mm, the link kit will most likely spin and you'll never get the bolt off.
4) support the vehicle front AND back as you'll need to drop the engine/tranny cradle a little
5) Unbolt the lower control arm. There are 3 bolts. two shown here and one in front.
6)
7) Now, unbolt the cradle from the car. there are 4 bolts in total. (two were from the control arm)
8) Unbolt the hold down bracket for the swaybar and lower the engine/tranny cradle just enough to get the swaybar out
9) Now, reverse the order. Make sure that you lube up the bushings REALLY well!!!
Sponsored Links
  #2 (permalink)
Old 07-21-2009, 07:55 PM
JCrimson's Avatar
JCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to liveJCrimson relies on Rep Points to live
Send a message via AIM to JCrimson Send a message via Yahoo to JCrimson
i would like to hear review.
__________________
  #3 (permalink)
Old 07-21-2009, 08:05 PM
Quote:
it's AWESOME! great handling!!! Definately a good buy. I highly recommend it to anyone!!!
  #4 (permalink)
Old 07-25-2009, 01:10 AM
tanukifit's Avatar
tanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to live
I did my Blox 24mm front sway bar today. Thanks for this DIY FoR awesome. The only thing I did different I left the Cat on when removing the bar back it all the way till it touches the Cat then pull the front ends of the sway bar down and remove backwards . Installation was the same start with sway bar backwards lift above the front of the cat and swing sway bar foreword. Thanks again for this DIY
Reply
Tags
07, 09, bar, bars, diy, endlinks, fit, fix, front, hoda, honda, rear, strut, sway, t1r
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
STRUT BARS, rear, front, upper lower questions and answers ken1279 Fit Suspension & Brake Modifications 225 11-02-2009 09:58 AM
Front Sway Bar pr0jectezek1el Fit Suspension & Brake Modifications 31 08-04-2008 12:45 PM
progress sway bar installed... lilcat California - Bay Area Community 3 03-11-2008 10:36 PM
Sway Bar installed and question. lilcat Fit Suspension & Brake Modifications 13 03-07-2008 02:37 PM
sway bar endlink FELIXY69 Fit Suspension & Brake Modifications 5 02-22-2008 04:56 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
