Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 10-20-2008, 11:00 AM
kylerwho's Avatar
spoon fed
kylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to live
Send a message via Yahoo to kylerwho
i thought mugen changed the height on the plastic assembly so the shifts are shorter.
__________________
high roller #7
Quote:
Originally Posted by dewthedew View Post
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
  #22 (permalink)
Old 10-20-2008, 02:47 PM
tougerunner86 is a splendid one to beholdtougerunner86 is a splendid one to beholdtougerunner86 is a splendid one to beholdtougerunner86 is a splendid one to beholdtougerunner86 is a splendid one to beholdtougerunner86 is a splendid one to behold
I don't know the exact "science" to it, I've just always been told that by autoX and track junkies. It supposedly prematurely puts more wear and tear on your gearbox because the throws weren't meant to be that short from factory, or something of that nature.
__________________
SPOON
  #23 (permalink)
Old 10-20-2008, 03:05 PM
kylerwho's Avatar
spoon fed
it only makes a differance if you are shifting faster than you can push the clutch in so it has a tendency to ruin your synchros.
__________________
high roller #7
  #24 (permalink)
Old 10-21-2008, 03:43 AM
wdb's Avatar
wdb wdb is offline
wdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to live
Short shifters are considered "bad" by some people because they help you shift faster, thereby making it somewhat easier to *possibly* shift faster than the synchros can keep up with, thereby *possibly* causing the gears to grind when they engage. But if they do, you'll hear it, and you'll either shift a little slower or else look in your wallet, decide you can afford it, and keep on slammin'.
You might also wear out your synchros a few thousand miles sooner. Or, you might think to yourself, gosh, how about I only shift like a demon just every once in a while, and not all the time.
While it's not really a fair comparison, the stuff I did to my STi to make the shifts shorter, crisper, and more precise make me smile every time I shift a gear, and I literally have NEVER slammed or jammed or ground teeth on that car in 95K miles. A thing that works well is a joy all by itself.
  #25 (permalink)
Old 10-21-2008, 06:47 PM
Ahh so thats why its "bad" thanks for the explanation, I've been wondering.... I think I will go for a shifter extender before I do a short shift kit though lol. Circuit Hero FTW!
__________________
SPOON
  #26 (permalink)
Old 10-21-2008, 09:31 PM
kylerwho's Avatar
spoon fed
Quote:
run the short shifter kit first or the circuit hero shifter extender will hit the radio.
__________________
high roller #7
  #27 (permalink)
Old 10-22-2008, 01:22 PM
You've tried it? I figured it might do that.
__________________
SPOON
  #28 (permalink)
Old 10-22-2008, 02:02 PM
wdb's Avatar
wdb wdb is offline
Quote:
It might! I have one and it does add quite a bit to the length of the throws. I tried it, didn't like it, took it out, and recently tried it again when I installed the JDM center console. While I definitely like the added height, I still don't like the added motion, and I took it out yet again.
I'm actually thinking about trying the Mugen shifter AND the H-Fit kit together to shorten the throw, and using the Circuit Hero extender to get the height back up where I want it. Crazy, no?
  #29 (permalink)
Old 10-22-2008, 11:41 PM
azkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to live
so has anyone used the T1R shifter???? wtf!
__________________
EVIL Prevails when GOOD MEN DO NOTHING
  #30 (permalink)
Old 10-22-2008, 11:48 PM
Giggles's Avatar
Giggles will become famous soon enough
Quote:
Originally Posted by wdb View Post
Mugen replaces the entire inside assembly. Lever is approximately 1" shorter than stock.
T1R is the lever only. In pictures the lever appears to be about as long as the stocker. I have yet to see a picture of the T1R installed.
I have installed the T1R Shift Lever. It sits at the same height as the stock but a little further forward. Throws between gears are lessened by more than inch. It gives a very nice stiff shift instead of the sloppy feel of the stocker.
One last thing, while I was able to install it myself it was rather difficult to separate the cup that holds the ball from the assembly. But i got it done and will never go back.
Here's some pics (sorry, not that great):
Before
After:
__________________
Byron
2008 BBP FIT SPORT MT
  #31 (permalink)
Old 10-22-2008, 11:51 PM
Quote:
Originally Posted by Giggles View Post
I have installed the T1R Shift Lever. It sits at the same height as the stock but a little further forward. Throws between gears are lessened by almost an inch. It gives a very nice stiff shift instead of the sloppy feel of the stocker.
Before
After:
thanks, so im gonna go get me one
__________________
  #32 (permalink)
Old 10-22-2008, 11:59 PM
Giggles's Avatar
Quote:
You won't regret it. Be sure to check out these threads:
T1R Quick Shifter- Installation Tech !
T1R Quick Shifter Installed!!!
__________________
Byron
  #33 (permalink)
Old 10-23-2008, 02:49 AM
I was actually thinking along those lines myself. Get the throws as short as possible then add a crazy tall shift lever to put it up next to the steering wheel. Thats what I did with my subaru anywho. Tell me how it goes if you do
__________________
SPOON
  #34 (permalink)
Old 10-23-2008, 02:54 AM
kylerwho's Avatar
spoon fed
im not sure the mugen will work with the h-fit mounts. i thought that has already been tried and it doesnt fit under the center console?
__________________
high roller #7
  #35 (permalink)
Old 10-23-2008, 11:07 PM
Giggles's Avatar
I thought this was a thread about short shift kits not tall shifts.
__________________
Byron
  #36 (permalink)
Old 11-03-2008, 12:38 PM
colicab119 has a little shameless behaviour in the past
I love it when people cut their shifters to make them a "short Shift". People the reason its a short shift isnt anything to do with the height of the shifter if you look at stock and after market side by side the aftermarket is actually longer on the bottom portion (OMG!!!!) its all based on a simple lever theory, the longer the piece the shorter the throw
  #37 (permalink)
Old 11-18-2008, 10:47 PM
junktea1's Avatar
junktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to livejunktea1 relies on Rep Points to live
any threads on the skunks short shift kit?
  #38 (permalink)
Old 11-18-2008, 11:08 PM
kylerwho's Avatar
spoon fed
what do you want to know about it? i have it and it lessens the shift a good amount. its worth putting on IMO
__________________
high roller #7
  #39 (permalink)
Old 11-18-2008, 11:17 PM
junktea1's Avatar
i'm debating between a t1r shortshift lever & the skunks' kit. i was surprised that the skunks kit only had some bolts in the kit.
i'm just looking for feedback on this item from ppl who have used/installed it
  #40 (permalink)
Old 11-18-2008, 11:20 PM
kylerwho's Avatar
spoon fed
the skunk kit comes with an adapter to lengthen the stock lever, metal bushings, and longer screws. easy install. better and more firm shifts. plus i cut my shifter lever down to make some nice shifting action.
__________________
high roller #7
Reply
Tags
07, circuit, civic, extender, forum, ge8, hero, hfit, honda, mugen, quick, shift, shifter, short, stock, t1r, thing
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Complete OBD II Codes List sLiVeRwOrM Fit DIY: Repair & Maintenance 13 02-14-2009 06:22 PM
Short Shifter 08_Nick_Fit Fit Engine Modifications, Motor Swaps, ECU Tuning 15 09-25-2008 01:44 AM
WTB: Stock Sport Shift Knob bschook5 For Sale / Want To Buy / Classified Ads for USED Fit Items 7 02-18-2008 01:06 AM
Short Shifter for 1995 EG Gli Civic MikeLikes@gmail.com Other Car Related Discussions 3 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
