Fit DIY: Repair & MaintenanceThreads discussing repairs and maintenance you can do yourself
Welcome to Fit Freak!
Welcome to Fit Freak,
dont forget that the front will need to have an alignment
good diy,
i want to lower my fit, but its already scary over large speed bumps lol
do you guys that have your fit lowered have any problems on steep driveways, speed bumps etc..
i would hate to scrape the front up
looks so good though
yeah, i mentioned the alignment at the end.
i don't have any scraping problems at all, but i have a base model so i don't have a front lip to scrape. when i lived in an area with steeper driveways, my fiance's sport front lips would scrape a little bit, and she isn't even lowered. so depending on your streets, if you have steep driveways in your daily commute, than i wouldn't suggest lowering your car.
I was told from 3 separate places today that the only alignment I can get is with the toe. I need a camber kit. So everyone who has just springs that got an alignment, did you have a camber kit? If not, the alignment is basically useless.
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
I have the SPC camber kit that came with the front bolts and rear shims. Never got the rear shims installed though. tire wear seems normal all around.
so you can just put ur springs on, but you will have camber problems.
__________________
Mugen(Visors, Door Sills, Oil Cap-Red, Radiator Cap, 2 Reserve Tank Cover, license plate Frame, Rear Wing Spoiler) CF Manifold Cover, Benen Rear Tow Hook, ASPEC Axle-Back Exhaust, 20% Tints, LED TailLight Red/Smoked, All Red Hazard Switch, PassSide Visor w/ Mirror, Type R Key Cover, C-Pillar Strut Bar, T1R B-Max CF Intake, Type R Emblem Rear, Takata shoulder pads, Progress Springs & Tokico HP Blue Shocks, Weapon R Engine Damper
i just got the skunk2 springs, got a killer deal at the skunk2 garage sale at their facility, for like 124
my question is, if i do get coilovers in the future, im guessing these springs are pretty useless for the pro-c coilover b/c they are different coil springs right?
and my main reason im on this thread, i need help installing these, b/c i dont even have jack stands anymore, my dad got rid of them...does anyone know when they are having one of those garage meets again?
Yeah Skunk2 Pro C does not use the regular Skunk2 lowering springs. At least that's my best guess. I might be wrong lol. Just go to Midas, they have suspension technicians that know how to install springs I'm sure. Or go to a tuner shop.
__________________
Location: San Francisco(20+yrs)/Westminister(10+yrs), CA
You should contact Gimme...His prices are pretty reasonable for installs...
__________________
AKA:Kenny
May 2007 NHBP Sport Fit JDM Spoon/Showa Suspension
GP Thunder 8500K Plasma White
4700K Xenon FogLights
Megan Axle Back
17" Drag DR9 Silver w\Chrome lip 205\40
Zeta Dead Pedal(Must have for all Fits)
Cargo Cover
Honda Access JDM Visors
Over 63k @ 7/09
since the car will be lower but still using the same shocks, it moves the piston inside the shock upward and closer to the top of the shock,
when you cut the bump stop, it gives you back the shock travel you would otherwise lose
but dont you run the risk of having the shock totally bottom out, that is having the internal piston hit the top of the shock case?
or, as i must assume, is there just way more shock travel available so that even with the Cut bump stop, the car would hit the bump stops before the shock bottoms out?
and as stated in the DIY, there is no need to remove the rear tires....save yourself the time.
that really depends on the type of equipment people are going to be working. if their jack can't get the car up high enough, they will need to remove the rear tires to get the suspension to drop enough for the springs to come out. but if they have a jack that can produce enough height, then what you said is true.
