Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 09-19-2009, 01:11 AM
Perrenoud Fit's Avatar
Perrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to live
The glue you are speaking of is a ribbon of dum dum (no pund intended) and there should be a drain some were in the bottom of the doors. This is the 2nd time I have read about this same issue with the Fit. The window seal won't keep out 100% of the rain from the door cavity thats why the factory uses the plastic and ribbon calk behind the door pannel. The water is suppose to drain out of the door long before it reaches the top of the cavity lip, it seems as if the drain is clogged up?? To check open the door and look to see if there is a small oval hole for the water to exit from the cavity before the gasket.
I repaired a few cars that had rusted bottom edges and it was from clogged or trash slowing down the drain.
__________________
Perrenoud Fit
  #22 (permalink)
Old 09-19-2009, 06:06 PM
Carbuff2's Avatar
Carbuff2 has a spectacular aura aboutCarbuff2 has a spectacular aura about
We had this problem on our 07. Both front doors were leaking onto the front carpets!
Car is still under warranty so had the dealer look at it. Brought this topic in to give them a hint.
It took them two days to fix, but everything seems to be OK.
Funny, I had heard about this problem before (especially regards the rear carpet) so I was looking out for it, but it happened all of a sudden...
__________________
Atwell "Buff" Haines
'07 Fit Sport (MT)
'06 CR-V (MT)
'99 Acura TL (AT)
  #23 (permalink)
Old 10-16-2009, 08:35 PM
vallerys is an unknown quantity at this point
Wow,
This really seems like the problem I'm having with my '07 Fit too! But I just over-mileaged my Warranty. We took it to the dealer, they said the entire carpet from the front Driverside to the back, BOTH sides are completely soaked through!!! They had to take all of the carpets out, order new ones and take all the doors apart before they found a problem in the front door seal - I hope they have it right! Now, they are asking us for $800! So, what do y'all think of that! Oh, it makes me so angry. I have never had the seals removed!
Sandy
  #24 (permalink)
Old 10-17-2009, 04:20 AM
cowflex has a spectacular aura aboutcowflex has a spectacular aura about
damn that sucks for everyone who has this problem. i have a 07 too, but for me luckily so far so good. mang i love the fit but all these little problems hold it back =[
  #25 (permalink)
Old 10-17-2009, 01:33 PM
Carbuff2's Avatar
Quote:
Originally Posted by vallerys View Post
Wow,
Sandy
Have you called Honda Corporate (number in back of the owners manual) to see if they will assume some of the cost? Be polite but firm.
Unless you have mildew or a smell, I question the need to actually replace the carpets. They should dry out in time.
Get back to us with the outcome.
(Our dealer took three days to fix this because they needed to verify the source of the leak and the repair.)
__________________
'07 Fit Sport (MT)
'06 CR-V (MT)
'99 Acura TL (AT)
  #26 (permalink)
Old 10-18-2009, 11:51 PM
krakhed is an unknown quantity at this point
Wow,
Sandy
Did you get an estimate before they did anything? They should have just shop vac'd it and sealed your doors up right. I have water in my back seats floor again b/c I went and installed sound deadening on my front doors and didn't re-duct the seals back in place (waiting on more deadener for my doors).
If it was so bad as to necessitate them taking it all out, that's not normal "wear and tear". Even if you are 5k miles over.
Call corporate....
__________________
2007 Fit Sport AT
Reply
Tags
air, back, car, carpet, conditioner, dripping, drivers, due, fit, footwell, honda, jazz, leaking, seat, underneath, water
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FS: Custom Aspec cat back straight pipe NSfit For Sale / Want To Buy / Classified Ads for USED Fit Items 7 05-01-2009 12:52 AM
FS: Volt and Water Temp gauge, Comp. Tacho YA2_user_GD3 For Sale / Want To Buy / Classified Ads for USED Fit Items 1 02-01-2009 05:33 PM
Fit to be tied! Rattle by right back window. Grrrr. cargirl2B Fit DIY: Repair & Maintenance 11 08-27-2008 07:21 PM
Back splatter zukered General Fit Talk 5 05-20-2008 12:03 AM
Jazz vs Hyundai Getz, Matrix and Kia Picanto SteveCebu Other Car Related Discussions 3 09-15-2005 08:20 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
