Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 06-26-2009, 12:01 PM
pbz08gd3's Avatar
pbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to livepbz08gd3 relies on Rep Points to live
WTF? a/c not blowing hard on recycle
has anyone gone through this? ipls help i need my ac fully functional in miami heat pls!!!!!!!!!
__________________
Sponsored Links
  #2 (permalink)
Old 06-29-2009, 10:49 PM
Tranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to liveTranas relies on Rep Points to live
Did you remove the H-VAC at all recently?
The way those "knobs" work is by three little "tubes" that latch onto primative looking white plastic "gears". If you didn't adjust those correctly when you put them back on, your "recycle" mode may not be at it's most optimum.
If that's not the case, it could be due to more intimate reasons... Goodluck.
__________________
I love my Honda Fit.
  #3 (permalink)
Old 06-30-2009, 02:29 PM
pbz08gd3's Avatar
LMAO!!! listen to this:
I'm driving home on friday and my AC stops cooling too! so naturally i take the car to the dealer next morning figuring its warranty work! NEVER! Turns out my radiator support bar was pushed back, my ac condensor was bent and damaged, and my radiator and fans were un-aligned too. So the service guiy says "theres physical damage so warranty won't cover this." i asked how much the condensor alone was and he tells me "$500-$600." what?! so i leave, go to my boys shop, put it on the lift take apart the front end, order a new copndensor from NJ Auto Parts (big ups to them for free delivery) put it all back together, and pay my boy to fill it w/ free-on ($40). AC FIXED!
Oh and BTW the ac wasn't blowing hard on recycle cause there was a pair of panties lodged in the suction behind the glove box. LMAO!!! alls well that end well.
thanks for the help anyways TRANAS!
__________________
  #4 (permalink)
Old 06-30-2009, 03:31 PM
Whoa.. What a day huh?
Well I'm glad you got it fixed, and yeah you gotta be careful what you put in the glove-box. When the glove-box is in the "locked" position, the contents are essentially "vulnerable" to the filter unit and... I suppose if the content in question is, LACEY enough - they could get sucked in.
No surprise with the dealership trying to steal money from you though, that's what they do best. haha.
Enjoy your new A/C!
__________________
Reply
Tags
ac, air, blowing, car, cars, conditioning, fast, fit, fixed, hard, home, honda, unit
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
engine break in questions Lalala218 General Fit Talk 177 11-17-2009 11:11 PM
Noisy ABS on hard braking wskwong 2nd Generation (GE 08-present) 8 12-15-2008 06:09 AM
reduce Laptop Hard Drive Noise... CuTeBoi Fit I.C.E. 12 10-12-2008 11:14 AM
lowering my Fit, ok, how hard is it REALLY? osarias Fit Suspension & Brake Modifications 22 04-10-2008 05:29 PM
Noise from front end under hard acceleration in first gear bschurma General Fit Talk 1 02-17-2007 01:46 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
