Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 07-05-2009, 06:02 PM
RubyQQ1211 has a spectacular aura aboutRubyQQ1211 has a spectacular aura about
Anyone tried to add battery water?
When my GD parked on hills, my batt will indicates it requires mainenance. It's fine on leveled ground. Has anyone tried to open the caps and filled it up?
__________________
07 Fit S MT //// from Blaze Orange Metallic to Pearl Yellow Metallic
Darren
Sponsored Links
  #2 (permalink)
Old 07-05-2009, 07:41 PM
spreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to live
I opened the caps once, no water was needed.
  #3 (permalink)
Old 07-05-2009, 09:30 PM
how did u open it? does it require special tool or you just twisted one of the caps?
__________________
Darren
  #4 (permalink)
Old 07-06-2009, 01:02 AM
Quote:
Screwdriver
  #5 (permalink)
Old 07-06-2009, 08:55 PM
Carbuff2's Avatar
Carbuff2 has a spectacular aura aboutCarbuff2 has a spectacular aura about
Actually, it's best to cut the label covering the fill holes.
But the biggest PITA is, the + terminal covers the left-most filler. (Write down your radio theft code and station presets before moving it!)
__________________
Atwell "Buff" Haines
'07 Fit Sport (MT)
'06 CR-V (MT)
'99 Acura TL (AT)
Reply
Tags
add, battery, crv, honda, level, water
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2007 Honda Fit: Original battery dead at two years Sibyl 1st Generation (GD 01-08) 74 11-17-2009 05:33 PM
Water In back footwell of Fit (Jazz) SUR-V Fit DIY: Repair & Maintenance 25 10-18-2009 11:51 PM
What is the cold cranking amps for 07 stock battery? jchcmax Fit DIY: Repair & Maintenance 5 12-18-2008 09:14 PM
Need more POWER gthumb23 Fit I.C.E. 30 05-30-2008 10:53 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
