Fit DIY: Repair & MaintenanceThreads discussing repairs and maintenance you can do yourself
Welcome to Fit Freak!
Welcome to Fit Freak,
The shop manual says to change it at Maintenance Minder 3 (whatever that means in miles). There's a drain plug and filler plug. Checking the level seems easy, draining seems easy, but how do you fill? Turkey baster?
Sponsored Links
Registered users do not see this ad. Click here to register for free!
i think redline has those pumps you can use. it's similar to the shampoo pump griot's sells.
or try this new funnel.
__________________ 08 FitSport (5MT) Storm Silver - My modded dd 09 FitSport (AT) Taffeta White - My stock GE8 as her dd 04 G35Coupe (6MT) Silver - My modded weekend touring car. 09 370Z (6MT) Silver - My weekend sports car.
Post your questions in my Fit Blog
i had to use two tranny funnels to get the fluid in but i will be useing a diffent method next time haha i jacked up the driver side remove wheel crack the bolt pan lowerd the car drain out then jack up again funnel it in slowly and rebolt think only 1.6 quarts
you can also buy a pump with a small hose attached to it. it's very much like the pumps that are attached to ordinary hand soap containers, except larger and with a small hose from which fluid is dispensed. i forget where i got mine from, but it was probably pep boys; you could probably get it at any automotive store though. you just screw it onto the MTF container and stick the hose into the fill hole, then pump lol.
this is a question i dont have the answer for, nor have i seen it....how many quarts should I buy for a manual transmission fluid change?
__________________
I offer various installs on our car and have done most that can be done. PM for pricing and appts. Not only am I a fan of the Fit, I actually own one http://www.fitfreak.net/forums/gener...tml#post697447
Book says 1.6 qt for a change or 1.7 if you take the case apart. Round up
I had trouble with my last on-the-bottle pump. The straw going into the quart was about 2" off the bottom so I always had to keep extra fluid handy to take up that space. Good idea though, I forgot about this little contraption.
__________________
