Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-28-2009, 06:08 PM
Koi Koi is online now
Koi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to live
PCV hose noise
I've been having occasional rough/low idle problems much akin to vacuum leaks (rpm will keep going up and down from 100 to 500 rpm, chugging the engine) and have noticed an intermittent hissing noise (psshhhh - pshhhhh - pshhhhh) coming from the PCV hose going to the intake. If I pinch the PCV line, the hissing noise stops. Is it normal to be hearing this from the PCV/PCV hose, or is it likely there's a leak in one of my vacuum hoses somewhere? Most of the time the car runs just fine, it's just one day out of a week it'll suddenly start chugging and dying on me, then work fine the next day. I'm going to guess that it's a leak somewhere in a hose, but I'd rather hear what you guys have to say before I take the manifold apart to check the PCV connection.
Sponsored Links
Reply
Tags
crankcase, fit, honda, hoselow, idle, pcv, positive, ventilation
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY CAI using dryer hose claymore Fit DIY: Repair & Maintenance 0 03-27-2008 02:22 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
