Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (http://www.fitfreak.net/forums/)
-   Fit DIY: Repair & Maintenance (http://www.fitfreak.net/forums/fit-diy-repair-maintenance/)
-   -   Wiper fluid pump freezing up? (http://www.fitfreak.net/forums/fit-diy-repair-maintenance/51484-wiper-fluid-pump-freezing-up.html)
kinosh 12-20-2009 08:01 PM
When the temp goes down to +20F or colder, the wiper fluid doesn't come out. I'm using the -20F fluid. Once the temp goes up to around +30F, everything is fine. Does anyone know if the pump freezes up in the cold?
kenchan 12-20-2009 08:33 PM
change washer fluid.
ive run the washer -7F with no issue.
shazaam 12-20-2009 10:20 PM
can check the lines n see if they're frozen n make sure all that's in there's low temp fluid.
FITMugen 12-21-2009 12:17 AM
HotShot
I installed HotShot which is windshield washer fluid heater on my 09 Honda FIT Sport MUGEN. I got it on eBay during Summer for $47. It works really good. It is the same manufacture that supply this product to GM. It melts snow on my windshield within less than 3 minutes.
Windshield Washer Fluid Heater
shazaam 12-21-2009 02:27 AM
what happens if/when it freezes in the lines and/or reservoir?
FITMugen 12-21-2009 03:20 AM
Quote:
Good question but I have not encountered the problem yet. I use anti-freeze washer fluid. I believe that its freezing point is -80 C. Since I live in Maryland so it is unlikely the temperature will be below -80 C.
