Fit DIY: Repair & MaintenanceThreads discussing repairs and maintenance you can do yourself
Welcome to Fit Freak!
Welcome to Fit Freak,
T-bone: Except for the leading edge of the front, and the trailing edge of the rear, which seem to be formed as intakes and exhausts, are the lower edges of the visors flush with the window?
I looks to me, only having seen pictures, that the visors are designed to use the lower pressure of the air rushing by the visors, especially the one at the rear, to really suck the air into and out of the car through the vents. If the lower edges of the visors are flush with the glass, except for the openings in the front and rear, this should work fairly well, without adding much wind-noise.
Sorry about stating the same simple question eight different ways, but when you aren't very smart, it's tough to get your point across...
Yes, the lower edge is flush with the window. There is actually a little rubber strip to make sure that there is a good seal with the window.
Great, thanks for the info. So if I am right, while driving at a decent speed, with the fan switch on the lowest position, you should notice a difference in airflow through the dash vents with the rear windows cracked vice closed.
Quote:
Originally Posted by t-bone
You should be able to find a ton of Mugen stuff in Bangkok. That's where I got mine from.
Yes, but right now my shopping list is a little short. I only plan on getting the visors, LED tailights (red smoke), and a red badge for the hatch. I don't want to get too much stuff, only to find I can't buy the car come December. All the threads about having to wait and the non-availability of the MT have got me worried and looking at alternatives. I'm sure I could sell it on e-bay, but I would hate to buy too much stuff and not be able to get the car for which it is intended, and that I really want - Storm Silver Sport MT!
I notice air coming from my dash vents even with the air switched to OFF and only the front windows cracked down to the Mugen visor seal.
I'm not entirely sure what you are asking about though.
So the authentic Mugen pieces attach with tape and clips. That's disappointing, I was hoping it would just be clips. My Honda Access visors on my DC4 Integra were just clips, granted I had to cut into the weather stripping and drill 1 or 2 holes, no tape was needed.
I just don't want the residue left by the tape if I ever decided to remove them. Don't know how effective Goo Gone would be on tape that's been adhered to black rubber.
__________________
panda scheme in the works (early 2008 debut)
Wheels, Suspension, Stickers, Decals +lots more $uper $ale
All my cars have either had a sun/moonroof, or rear flip open vent windows. Tilting the roof or opening those vent windows increases the flow of air through the dash vents without having to turn on the fan. The Fit has neither a sun/moonroof, or the vent windows, so I am looking for a work-around. Based on what you have said, you found it for me.
Next time you are tooling down the highway, close windows and turn the fan off. Feel the air coming out of the vents. Then crack open the rear windows. You should feel a pretty significant difference in the airflow. That's what I am looking for. I like lots of air. You don't get the noise or aerodynamic waste of windows down, and on those borderline days, you don't have to use the a/c.
On my way to work today I drove with the air switched to OFF, vent switched to outside air, front windows down to the recommended level to allow air flow, and the rear windows closed.
I noticed a good amount of air coming in through my vents. Then I opened both rear windows just a crack and noticed the air flow from the vents decrease.
I think it's because of the design of the Mugen visors already optimize airflow for just the front windows to be slightly open. You don't need to crack open the rear windows to get more airflow. The fit also allows air to flow out the rear hatch too so this may assist in good airflow already. Opening the rear windows a crack may disrupt the laminar flow I think.
My front visors don't actually touch the window.. which i like because i don't want it to scratch up the glass
Mine get close and just barely touch the glass. If it were to touch the glass I don't think it would really scratch it though. That portion of the visor is soft and rubbery.
Quote:
Originally Posted by sillypuddy
we did the install slightly differently, we did the tape first then clip them in place afterwards...
I guess since I did it alone I found it hard to hold everything exactly in place while removing the tape. That's why I put the clips and the window lining first which kind of helped hold the visor in place while I removed the tape.
